Author Topic: Tealios et al  (Read 2732 times)
Offline TeacherGeek
Tealios et al
« on: Wed, 01 May 2019, 02:02:29 »
When I look at aliexpress about tealios, they don't say v2. Does that mean they are v1?
Also can someone explain to me about tealios, healios and zilents? Is it tactile, clicky and linear?
Offline lolafineday
Re: Tealios et al
« Reply #1 on: Wed, 01 May 2019, 05:07:20 »
Tealios = linear
Healios = silent tealios
Zealios = Tactile
Zilents = silent zealios
On aliexpress, kbdfans only have r1 of zeal switches. You will need to to to zeal's site to buy them.
Offline TeacherGeek
Re: Tealios et al
« Reply #2 on: Wed, 01 May 2019, 06:49:54 »
Does anyone know where I can get some Zealios v2 to see which weight I would like? I can't see a sample pack anywhere
Offline dexie
Re: Tealios et al
« Reply #3 on: Wed, 01 May 2019, 08:21:18 »
https://novelkeys.xyz/collections/switch-testers
https://zealpc.net/products/zealio-switch-sampler-pack
ISO Life
Offline TeacherGeek
Re: Tealios et al
« Reply #4 on: Wed, 01 May 2019, 14:21:56 »
Thanks. So expensive...rip
Offline ArchDill
Re: Tealios et al
« Reply #5 on: Wed, 01 May 2019, 15:21:30 »
I have some Tealio r1 and they are amazing. Only other linear I prefer to them are Tuned vin blacks in Zeal housing. I also had someone send me some Zilent 67g and they feel really good. I am thinking about buying some.
Offline dexie
Re: Tealios et al
« Reply #6 on: Wed, 01 May 2019, 23:46:19 »
15-25$ is much cheaper than building a board with expensive switches and then not liking them.
ISO Life
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: Tealios et al
« Reply #7 on: Thu, 02 May 2019, 06:46:22 »
If the seller is KBDFans then it's probably whatever they have on their site (which is v2). Otherwise you'll have to ask the seller.
