Author Topic: [IC] MT3 Serika | IS LIVE! ORDERS CLOSE ON 08/30/19 11:59 PDT  (Read 408470 times)
Offline AlcoholEnthusiast
Re: [IC] MT3 Serika
« Reply #200 on: Thu, 02 May 2019, 22:53:08 »
Would also be interested in R3 Function, though not a dealbreaker by any means.
Offline RominRonin
Re: [IC] MT3 Serika
« Reply #201 on: Thu, 02 May 2019, 22:56:31 »
Susuwatari had a few extra keys. Enabled support for Colemak-DH and -DHm.
Colemak-DH has pretty much became the recommended layout by us Colemak-nerds. Would be awesome if you would consider continuing supporting this layout. Thanks.
The important letters are:
R2 B
R3 M
R4 DH
Nice, will add them then.
I just read this - please ignore me!
Sent from my Moto G (5) Plus using Tapatalk
Offline jortzii
Re: [IC] MT3 Serika
« Reply #202 on: Fri, 03 May 2019, 02:17:27 »
Volcano660 | Satisfaction75 | Think6.5 | TGR Jane V2 CE | Preonic | IC Kira | Drop ALT
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: [IC] MT3 Serika
« Reply #203 on: Fri, 03 May 2019, 03:18:25 »
How about an R3 1.75U Fn or Function, probably in Extension?
me3
Offline adxlk
Re: [IC] MT3 Serika
« Reply #204 on: Fri, 03 May 2019, 03:36:52 »
zambu, can you do a render on blue gray jane v2 please?
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #205 on: Fri, 03 May 2019, 04:56:21 »
I can't.
Offline konstantin
  • Formerly constexpr
Re: [IC] MT3 Serika
« Reply #206 on: Fri, 03 May 2019, 09:14:15 »
Looking good so far. I dig the typeface. Here's a few things I've noticed or would change in the kits:
  • I'm a big fan of System/Sys legends; however, I think the 1.25u System key looks a bit cramped, especially since the 1.25u ctrl legend next to it is Ctrl and not Control. Consider changing the 1.25u winkey legend to Sys. The 1.5u legend in the extension kit should stay System so it matches how the Ctrl/Control and Cmd/Command legends scale.
    Another argument in favor of this is that you're using the short Ins and Del legends in the nav cluster.
  • Use Scroll instead of Lock for the one-line scroll lock legend, it makes more sense.
  • Similarly, consider using Caps instead of Caps↵Lock for the stepped caps lock legend. This will keep the aesthetic clean and without any two-line legends.
  • nvm, I'm blind
  • Add Alt Gr keys to the ISO and/or international kit.
  • Looking at the above posts, I too would like to see a R3 1.75u Function cap, e.g. in the extension kit.
  • I'm sure this has been mentioned before, but is there any chance of getting reverse dye-subbed accents?
« Last Edit: Fri, 03 May 2019, 09:51:33 by constexpr »
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #207 on: Fri, 03 May 2019, 09:53:42 »
1. I prefer to use the whole world if it there's enough room for it.
2. My personal preference is to use Lock for the scroll lock key.
3. Agree.
4.
5. There's no tertiary legends for the international kit. Alt Gr only makes sense in that case.
6. Will think about it.
7. No.
Offline konstantin
Re: [IC] MT3 Serika
« Reply #208 on: Fri, 03 May 2019, 11:02:07 »
Could you elaborate a bit as to why that this? I'm interested in hearing your thoughts on it. Is it because Lock fits nicer in the key, or do you think that legend makes more sense in that context?
Good point.
« Last Edit: Fri, 03 May 2019, 11:18:43 by constexpr »
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #209 on: Fri, 03 May 2019, 12:04:05 »
ERGODOX USERS
Vote here
Updated Cores. Removed Symmetry kits. I will not be adding R2 1U yellow pipe keys, but I'll think about the R3 1U yellow ' ".
ERGODOX USERS
Vote here
« Last Edit: Fri, 03 May 2019, 12:05:57 by Zambumon »
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #210 on: Fri, 03 May 2019, 12:05:28 »
I like to use Lock, similar to how I like to use System for the OS key.
Offline Boy_314
Re: [IC] MT3 Serika
« Reply #211 on: Fri, 03 May 2019, 12:06:24 »
i like this
Offline mwahlig
Re: [IC] MT3 Serika
« Reply #212 on: Fri, 03 May 2019, 12:35:49 »
One question regarding the profile for the 40s. This is intended to be used for Planck/Preonic, right? How does the bottom row R4 feel. I have one SA set with R4 bottom row and it does not feel right in same cases. My Preonic case has no angle at all. Is this not a bit uncomfortable to type on? The Ergo kit has R5 for the thumb cluster. Why not use R5 also for the Ortho/40s kits?
Yeah, I wish that the ortho kit had R5 for the bottom row like dev/tty and godspeed. R4 is gonna feel weird.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #213 on: Fri, 03 May 2019, 12:39:08 »
The rest of the set all has R4. Doesn't make much sense to use a different row profile for a particular form factor.
Edit:/dev/tty had R5 because the set included both R5 and R4 bottom rows for the whole set.
« Last Edit: Fri, 03 May 2019, 12:42:23 by Zambumon »
Offline mwahlig
Re: [IC] MT3 Serika
« Reply #214 on: Fri, 03 May 2019, 13:32:09 »
Good point. Looking forward to this set regardless!
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #215 on: Fri, 03 May 2019, 13:54:17 »
Friendship regained with Oblotzky. Extension kit updated
Offline kakiharaOne
Re: [IC] MT3 Serika
« Reply #216 on: Fri, 03 May 2019, 14:01:27 »
Oblotzky, remember you also need an R1 1.5u backspace in extensions too... remember
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #217 on: Fri, 03 May 2019, 14:14:44 »
That was already in the modifiers. Backspace didn't fit on the 1.5U key, I opted to use Erase.
Offline kakiharaOne
Re: [IC] MT3 Serika
« Reply #218 on: Fri, 03 May 2019, 14:18:02 »
I’m just trying to not have to buy Ergo for one key.
Offline Oblotzky
Re: [IC] MT3 Serika
« Reply #219 on: Fri, 03 May 2019, 14:18:51 »
Think he's talking about Vortex Race support, R1 not R2
Offline kakiharaOne
Re: [IC] MT3 Serika
« Reply #220 on: Fri, 03 May 2019, 14:21:02 »
This would be for the original M0110 layout. But it would help my case if there were other boards with it!
Offline wangledorf
  • Formerly pewing
Re: [IC] MT3 Serika
« Reply #221 on: Fri, 03 May 2019, 15:29:44 »
Glad to hear you're considering the yellow ' " key! Any chance of adding the R2 1U yellow pipe key to the forties kit at least? I can understand if not as it's not the default planck/preonic layout but I'd be lying if I said I wasn't sad :P
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #222 on: Fri, 03 May 2019, 16:17:26 »
Same deal as the yellow tilde. If I add them, I have to add them all, so that's four extra keys.
Re: [IC] MT3 Serika
« Reply #223 on: Fri, 03 May 2019, 16:42:37 »
make em another kit so that the people with bad taste have to suffer
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #224 on: Fri, 03 May 2019, 17:10:53 »
These kind of request often happen with sets with a lot of kits, the more you offer, the more people ask for.
After some thinking about the yellow tilde and yellow R2 1U pipe keys, I am not going to add them. The current 40s kit is already at the limit of what I want it to be, adding more cosmetic keys (that is, that they do not provide any extra layout coverage) is something I'd not like to do.
Offline wangledorf
  • Formerly pewing
Re: [IC] MT3 Serika
« Reply #225 on: Fri, 03 May 2019, 17:40:46 »
Understandable, I'll probably end up just filling those spots with the TURBO and HYPE novelties instead. :)
Out of curiosity, would you ever consider a generic legend forties kit? Sorta like how GMK Oblivion uses Git commands for mods or assembly instructions for the Assembly kit?
Offline Techno Trousers
  • ʘ_ಠ
Re: [IC] MT3 Serika
« Reply #226 on: Fri, 03 May 2019, 17:52:11 »
I don't think this was answered, but any chance for R5 space bars added to the 6.25 kit? If everyone is going R4 only bottom rows in MT3 sets, I'll need to stock up on R5 space.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #227 on: Fri, 03 May 2019, 18:00:36 »
MT3 Serika will use R4 space bars.
Offline digid3ar
Re: [IC] MT3 Serika
« Reply #228 on: Fri, 03 May 2019, 21:07:53 »
damn i really would like to have at least a keyboard with ñ, but a whole set for that one key  :(, i hate to be in that tiny segment of the market.
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] MT3 Serika
« Reply #229 on: Fri, 03 May 2019, 21:23:16 »
IN for Hangul legends. Only kind of joking. Not really, I want Hangul on Serika so bad.
But yes, I'll be getting it in whatever form Zambumon goes with.
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: [IC] MT3 Serika
« Reply #230 on: Fri, 03 May 2019, 21:32:24 »
Think I'm looking at my first MT3 set here. I also think Hangul sub legends would look killer on this set. Maybe a possibility on a future run of Serika?
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #231 on: Sat, 04 May 2019, 02:33:01 »
Not going to happen.
Offline Stewiedk97
  • Professional overcomplicator
Re: [IC] MT3 Serika
« Reply #232 on: Sat, 04 May 2019, 03:27:34 »
Does this mean serika deskmats are coming back?
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #233 on: Sat, 04 May 2019, 03:52:57 »
Novelkeys still had stock of the Serika light ones until very recently. Hexagon Dark has been out of stock for a while now, so they might re-stock them soon.
Offline mkarlsson
Re: [IC] MT3 Serika
« Reply #234 on: Sat, 04 May 2019, 05:54:57 »
I guess you missed the gmk jamón GB, it had plenty of them
Offline kissingyou
Re: [IC] MT3 Serika
« Reply #235 on: Sat, 04 May 2019, 05:58:00 »
Ready
Offline ladysleep
Re: [IC] MT3 Serika
« Reply #236 on: Sat, 04 May 2019, 10:32:19 »
longing for the GMK Serika!!!
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #237 on: Sat, 04 May 2019, 11:17:14 »
This is the IC for MT3 Serika.
Re: [IC] MT3 Serika
« Reply #238 on: Sat, 04 May 2019, 14:14:09 »
the man can dream
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #239 on: Sat, 04 May 2019, 14:16:23 »
the man can dream
I will start thinking about it in 2021, you can set a reminder and ping me in 3 years about it. In the meantime: let's celebrate MT3 Serika.
Re: [IC] MT3 Serika
« Reply #240 on: Sat, 04 May 2019, 14:21:02 »
the man can dream
!remindme 3 years
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #241 on: Sat, 04 May 2019, 15:54:07 »
Ergodoxusers
FILL THIS FORM
I'll be closing it on Sunday.
Offline lolafineday
Re: [IC] MT3 Serika
« Reply #242 on: Sat, 04 May 2019, 17:31:20 »
Pleaseee add 1.75 shift that is accented black. Thanks
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #243 on: Sun, 05 May 2019, 03:44:23 »
No.
Why just R4 1.75U shift in dark grey? Why not all the Shifts?
Offline fombat
Re: [IC] MT3 Serika
« Reply #244 on: Sun, 05 May 2019, 04:13:54 »
SO MANY SETS TO BUY but very down
Offline nickaster1
Re: [IC] MT3 Serika
« Reply #245 on: Sun, 05 May 2019, 07:41:19 »
What is it with the ugly font may I ask? I think we can do better than sticking with this basic font.
Offline Zambumon
    • Keyset projects
Re: [IC] MT3 Serika
« Reply #246 on: Sun, 05 May 2019, 07:47:06 »
I knew it. I should have used comic sans instead.
Offline nickaster1
Re: [IC] MT3 Serika
« Reply #247 on: Sun, 05 May 2019, 07:48:28 »
Dang it man. You read my mind right there
Offline lendflat
Re: [IC] MT3 Serika
« Reply #248 on: Sun, 05 May 2019, 08:25:12 »
Does it not make sense to for the spacebar kit to offer yellow and grey spacebars instead of cream and grey since cream is already part of the modifiers kit?
Offline laserbeamspewpew
Re: [IC] MT3 Serika
« Reply #249 on: Sun, 05 May 2019, 09:00:54 »
No.
