Author Topic: [IC] MT3 Serika | IS LIVE! ORDERS CLOSE ON 08/30/19 11:59 PDT  (Read 412132 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] MT3 Serika | Launching In August On Drop
« Reply #500 on: Mon, 08 July 2019, 14:17:29 »
Offline Zambumon
    • Keyset projects
« Reply #501 on: Mon, 08 July 2019, 14:18:06 »
What kind of homing keys are you using, scooped or nippled?  I would assume scooped, but the kit pictures don't actually specify (I only ask because /dev/tty had both, so there's a choice of homing molds in MT3).
Scooped. There are no nippled MT3 molds and the renders don't show nipples, so scoop is implied.
Fortunately MT3 only has the superior homing system: scooped keycaps.
Offline konstantin
  • Formerly constexpr
« Reply #502 on: Mon, 08 July 2019, 14:33:30 »
Looking at the OP renders, it seems that the 1.75u stepped caps lock legend is still Caps↵Lock. Any chance of changing that to Caps like you said? I would prefer to have all one-line legends in this set.
Same goes for the 1.25u caps lock in the Forties kit.
Offline Zambumon
    • Keyset projects
« Reply #503 on: Mon, 08 July 2019, 14:36:37 »
I wasn't convinced by "Caps".
Offline konstantin
« Reply #504 on: Mon, 08 July 2019, 14:38:04 »
How is Caps less convincing than Lock for scroll lock?
Offline Zambumon
    • Keyset projects
« Reply #505 on: Mon, 08 July 2019, 14:41:40 »
I like lock, I don't like caps
Offline konstantin
« Reply #506 on: Mon, 08 July 2019, 14:48:33 »
Well okay, designer's preference is fine, but I don't think you should sacrifice a uniform look across the set by having just the smaller caps lock legends be two-line, while everything else is one-line.
Offline euphxenos
« Reply #507 on: Mon, 08 July 2019, 15:36:29 »
I just took my MT3 /dev/tty round 2 set out of the box and double checked.  There are three F and three J keys.  One each regular, scooped, and nippled.  It's also shown in the base kit render that's still up on Massdrop:
https://drop.com/buy/massdrop-x-matt3o-devtty-custom-keycap-set
Thanks for confirming that they're scooped in MT3 Serika, but I'm confident that you're mistaken about the nonexistence of nippled MT3 molds, given that I've got a couple of nippled MT3 keys in hand.
Offline Digitize
« Reply #508 on: Mon, 08 July 2019, 15:39:05 »
Well that nonuniform look will only happen if you are planning to use the step caps lock keycap. Other than that I don’t see any problems with this “one single” caps lock keycap being on two lines.
Offline eskimojo
    • KeycapLendar
« Reply #509 on: Mon, 08 July 2019, 16:00:13 »
"this issue only occurs if you use the affected keycap"
yes
Offline Zambumon
    • Keyset projects
« Reply #510 on: Mon, 08 July 2019, 16:32:25 »
The files that Drop sent me didn't come with nippled keycaps... And I didn't have any intention to use them, but good to know.
Offline wangledorf
  • Formerly pewing
« Reply #511 on: Mon, 08 July 2019, 17:20:28 »
I'm a big fan of the generic text for the ergo kit but is there any chance of using a different letter than F for the ergodox left hand bottom row? It makes it look like those are function keys.
Offline loopaddiction
« Reply #512 on: Mon, 08 July 2019, 18:32:59 »
All in for:
Katakana
Alphas
Modifiers
Extras Mods
Novelties
Super Homing
Arrows
F-Row
Mac
Frightened at what the total cost is going to come out to w/ shipping & sales tax. But also excited.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #513 on: Mon, 08 July 2019, 21:12:53 »
Are there any convex keycaps in the Split Bars kit?
Offline Zambumon
    • Keyset projects
« Reply #514 on: Tue, 09 July 2019, 02:53:04 »
Unfortunately, no.
Offline megaforce
« Reply #515 on: Tue, 09 July 2019, 11:21:50 »
ne space cadet avail
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline rfvizarra
« Reply #516 on: Tue, 09 July 2019, 11:38:31 »
Hi,
I don't know if it is too late, but I have a suggestion about the ortho kit based on this
https://drop.com/buy/drop-matt3o-mt3-dev-tty-keycap-set/talk/2432700?utm_source=linkshare&referer=F68W7U
Is it possible to user R5 flat to the bottom row? or at least have the space profile used in that 2U and 1U spaces? otherwise is very very uncomfortable to use.
Something like the MDA Ortho kit https://www.aliexpress.com/i/32934200359.html?spm=2114.12057483.0.0.153430f4ZCLg4D
Cheers,
Rodrigo
Offline dededecline
    • Linktree
« Reply #517 on: Tue, 09 July 2019, 11:45:50 »
Just saw the change to the ergo kit. Bummer, I was definitely excited for such a full ergo kit. I know you can't please everyone though.
Offline equalunique
« Reply #518 on: Tue, 09 July 2019, 12:12:18 »
I feel like R4 bottom row is best for outer mods where you use your pinky, ring, & middle fingers to press them. The inner mods, like the Alt key on an ANSI-layout keeb or the space/layer keys on an ortho board, are all better as R5 because folks tend to use their thumbs for these. Conclusion: Hybrid R4/R5 bottom rows are the best way to make everyone happy.
Sent from my LG-H918 using Tapatalk
Offline dvorcol
« Reply #519 on: Tue, 09 July 2019, 13:24:40 »
Unfortunately, no.
In a comment below someone is requesting 1C and 2C keycaps in the Ergo kit, but it seems that MT3 tooling does not exist.  Please consider adding a “C” to all convex keycap labels in the kit pictures (for example “6.25C”).  This might reduce misunderstanding.
Offline Zambumon
    • Keyset projects
« Reply #520 on: Tue, 09 July 2019, 13:56:15 »
Offline Zambumon
    • Keyset projects
« Reply #521 on: Tue, 09 July 2019, 13:56:34 »
Hi,
Cheers,
Rodrigo
Will think about it.
Offline Zambumon
    • Keyset projects
« Reply #522 on: Tue, 09 July 2019, 14:26:45 »
More eye candy
« Reply #523 on: Tue, 09 July 2019, 14:35:12 »
Will there be any blue child kits?
Offline Zambumon
    • Keyset projects
« Reply #524 on: Tue, 09 July 2019, 14:45:44 »
no
Offline Parva Ovis
« Reply #525 on: Tue, 09 July 2019, 22:09:01 »
Unfortunately, no.
convex 2u exists for MT3; I'm currently typing on it from the MT3 Godspeed kit.
Offline Zambumon
    • Keyset projects
« Reply #526 on: Wed, 10 July 2019, 01:31:49 »
Unfortunately, no.
I wasn't informed about that by Drop and wasn't mentioned about this :(
Even when you check MT3 Godspeed's renders they have been using a regular 2.00 key
Offline coffeeshopcoder
Re: [IC] MT3 Serika | Important Update
« Reply #527 on: Wed, 10 July 2019, 02:14:35 »
MT3 Serika, not Serika MT3 [BRAND/PROFILE] then [NAME OF THE PRODUCT]. We don't say iPhone Apple or HD 6XX SENNHEISER.
Maybe you were just trolling, but it got me thinking...
It’s common and the accepted way to say GMK Serika, or SA Pulse... however ...
Given that this hobby and the marketplace around it has been evolving and maturing, what do designers like you consider the “product” ?
Are you bringing an MT3 set in the Serika colorway or the Serika colorway in the MT3 profile ?
If I were a designer, the fruit of my labor is the colorway and that’s the product being offered in potentially many configurations..
in this sense I would consider key cap profiles as “models” of a product (the colorway).sort of like saying
iPhone XR and iPhone SE.
Or
Zambumon’s Serika MT3 like
Apple iPhone XS
And just like the iPhone has accessories, so do colorways like the
Novelkeys  Serika deskmats like
Otterbox iPhone armour
Massdrop Laser Alt
Maybe colorways have grown up to precede the profile and go beyond just keysets ... Maybe I’m just drunk...
Offline Zambumon
    • Keyset projects
« Reply #528 on: Wed, 10 July 2019, 02:18:10 »
No. They haven't.
Offline OkKarma
« Reply #529 on: Wed, 10 July 2019, 03:14:19 »
If you could follow up with Drop about whether 2U spacebars can be convex, that would be great. As an owner of MT3 /dev/tty, I use a cheap XDA 2U spacebar because with the height and scooping, it is physically painful to use MT3 2U keys as a spacebar.
Offline Zambumon
    • Keyset projects
« Reply #530 on: Wed, 10 July 2019, 06:19:35 »
ok
Offline OkKarma
« Reply #531 on: Wed, 10 July 2019, 06:20:07 »
ok
Cheers!  :thumb:
Offline Zambumon
    • Keyset projects
« Reply #532 on: Wed, 10 July 2019, 06:21:41 »
ok
Cheers!  :thumb:
I'll also ask about other split spacebars.
Offline equalunique
« Reply #533 on: Wed, 10 July 2019, 10:54:40 »
ok
Cheers!  :thumb:
ErgoDox kit with convex bars would be revolutionary
Offline Zambumon
    • Keyset projects
« Reply #534 on: Wed, 10 July 2019, 11:34:10 »
ok
Cheers!  :thumb:
Ergo kit won't have convex 2U. This is also the case for GMK sets.
Offline carlouws
« Reply #535 on: Wed, 10 July 2019, 12:22:58 »
Would it be possible to move the arrows from novelties into the arrows kit? If not, that's okay but I would like to know the reasoning behind this move. I find it curious. Thanks!
Offline Parva Ovis
« Reply #536 on: Wed, 10 July 2019, 13:23:07 »
Unfortunately, no.
I bought the split spacebars kit and the 2u spacebars kit; 2u were all convex, the rest were all concave. The renders for both kits show concave, so it was a surprise to me as well.
Offline Zambumon
    • Keyset projects
« Reply #537 on: Wed, 10 July 2019, 14:35:55 »
Edit: question was regarding the text arrows. Not the icon ones.
Arrow kit will be for the icon-only.
« Last Edit: Wed, 10 July 2019, 15:03:28 by Zambumon »
Offline Zambumon
    • Keyset projects
« Reply #538 on: Wed, 10 July 2019, 14:37:38 »
Unfortunately, no.
Thanks for the pic!
Offline dvorcol
« Reply #539 on: Wed, 10 July 2019, 16:16:23 »
Unfortunately, no.
This is one reason to label all convex keycaps in the kit renders.
Offline Zambumon
    • Keyset projects
« Reply #540 on: Fri, 12 July 2019, 18:03:48 »
A new round of samples is in the works. Small tweaks here and there.
Offline sachin3767
« Reply #541 on: Mon, 15 July 2019, 04:43:36 »
MT3 SERIKA: FINAL KITS
@Zambumon, been drooling over these renders for a while now but just spotted...
that the UK ISO kit doesn't have the R1 2 and 3 keys with the Katakana legends???
 Whitefox|Granite    Tex Yoda II     Exent | dev/tty      MX Master       Planck|Big Bang
Offline Zambumon
    • Keyset projects
« Reply #542 on: Mon, 15 July 2019, 05:24:31 »
No, and I would have to add an off-center `¬, R1 2"フフ, 3£アァ, as well as R3 '@ケロ, and off center #~ to fully cover the UK layout.
I did consider adding them, but there were a bunch of factors (mainly kit size) that made me think about it and this is why I ended up just including 2 extra keys.
One of my priorities for the ISO UK kit was to make it as small as possible (with the requirement of including the accent `¬, and accent enter key), and initially I thought about not even including Katakana support, which is something that has happened before with some GMK sets. Since I wanted to have a minimal impact, I opted just to include the two backslash keys, since they would provide with some basic ISO support.
Anyways, I'm open for discussion on this topic, and I'd like to know what you guys think about it. The current kit could be around the $12 or $15, and with the new additions it could be around $20 or $24, and while the price differencial might not seem so much, it could be a dealbreaker for some people.
Offline eskimojo
    • KeycapLendar
« Reply #543 on: Mon, 15 July 2019, 05:41:57 »
Personally I'd never use the katakana keys, but having them added wouldn't be a dealbreaker for me as an ISO UK user.
The kit being cheaper is nice, but I don't mind paying a little more to support others.
Offline Surefoot
« Reply #544 on: Mon, 15 July 2019, 07:02:09 »
Same situation here, i wouldnt mind either way, i'll get the ISO UK kit in any case.
Offline hottrout
  • I'd Hit Dat Key
« Reply #545 on: Mon, 15 July 2019, 08:21:39 »
It is good to have the UK support.  I also don't mind paying a little more for the full set of UK keys but that said I am ok with either decision.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline sinnyc
« Reply #546 on: Mon, 15 July 2019, 09:45:42 »
The Ergo kit looks great but I'm confused about why the bottom row legends are F1-F5 and M1-M5.  Are they not sequential (like X1-X10) just to differentiate between the two sides without using blanks?
Offline Lisinge
« Reply #547 on: Mon, 15 July 2019, 14:57:25 »
Any possibility of including a control key to replace caps lock in the main modifiers kit?
All other mt3 kits have done it this way. The mod kit even includes hhkb backspace key and split right shift, but still lacking that caps lock replacement...
Offline Zambumon
    • Keyset projects
« Reply #548 on: Tue, 16 July 2019, 03:08:48 »
That key is on the extension kit alongside the 1.75U function key and the 1.5U system keys.
Offline Zambumon
    • Keyset projects
« Reply #549 on: Tue, 16 July 2019, 03:11:07 »
Yes, I didn't want to use the same letters for both left and right.
