Author Topic: [IC] FOX × INETT:SQUARE 80% (GB started)  (Read 38675 times)
Offline Simen
Re: [IC] FOX × INETT:SQUARE 80% keyboard
« Reply #50 on: Thu, 09 May 2019, 11:04:29 »
Beautiful! Will the PCB support ISO layout?
Oh, I am sorry to reply that ISO layout is not supported as fixed layout with hop swappable plate and pcb.
« Reply #51 on: Thu, 09 May 2019, 11:07:13 »
this is good
Offline York Chan
Very cool, perfectly integrated with the roadster element :thumb:
Offline apexshikari
Looks fabulous ...
Offline vewy_nice
My next TKL right here...
Maybe I can actually get this one ;)
Offline Simen
Phototype pictures shared. Hope you enjoy it  ^-^
Looks fabulous ...
Thanks  :thumb:
Try my best to alight with trend  :p
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #56 on: Sat, 11 May 2019, 12:03:22 »
It is a beautiful design.
I would like to add PANTONE 802C color.
I also think this color with a black plate would look killer.
The design might be too loud for a lot of people but I honestly love it.
Do you have any of the estimated weights based on the prototypes?
GON NerD TKL DTA Edition
Offline fruitofconfusion
I would be very likely to join if a purple was added, like a few other members mentioned. This is a great board. Forgive me if I missed it, but I’d the PCB USB-C?
Offline Locnguyen1507
Interested! Are there any top view of WKL layout from these prototypes?
im pretty sure those are renders
Offline Simen
« Reply #60 on: Sat, 11 May 2019, 13:18:56 »
Estimated is around 3KG.  Exact weight will be updated once I weight it  :p
Offline Rak8886
Definitely interested!!! Would like navy plate as an option. Planning to go for white case to go with GMK Mizu
Offline Simen
I am taking photos with different keycaps, and will update them later.
Offline vision-quest
I’d be in if there were a dark gray for sure! Such a nice board.
Offline JDragon
Will silver be a color option?
Offline Peiweisgreat
Yeah please have a black pvd option for the weight if you are going to have such a gorgeous yellow as a case option.
Offline Simen
Color options have been decides. Black is also nice and very close to grey, I will update phototype soon. Hope you enjoy it
Offline Simen
oh, silver will be only included as a PVD brass weight option.
Offline Simen
Sure, brass PVD with black was included  :thumb:
Offline eskimojo
    • KeycapLendar
Personally will have to give this a miss due to no ISO, but that yellow is gorgeous - I don't think you'll have any difficulty filling those 50 spots  ;)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
You got my attention with the "fixed layout" part  :cool:
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
I wish i'd be able to afford this, but i always like these interests checks.
Can we get some love for our sandwich boards!  :-*
Just my thoughts
Offline Simen
Re: [IC] FOX × INETT:SQUARE 80% (Update Phototype Pics - May 13th)
« Reply #72 on: Mon, 13 May 2019, 09:17:31 »
Fixed layout is perfect for players , no choice , haha, easy to know how to assemble it without thinking  :p
Thanks a lot
Offline Simen
you should, I don't think the price is very expensive  :p
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #74 on: Mon, 13 May 2019, 10:21:05 »
OoOof, I am not a huge fan of TKLs but gotta admit to a killer design when I see one! These are really visually appealing boards, the extra bit of the plate that extends up through the case to outline all the keys make for a great & striking look with most color combos. Really great work here! :cool:
Offline Uryftw
« Reply #75 on: Mon, 13 May 2019, 11:24:35 »
Is that "border around the keys" gonna be in the final board? If that's the case, I'm really digging it
Offline Damage
« Reply #76 on: Mon, 13 May 2019, 16:49:31 »
Dumb question, maybe, or perhaps it's been covered here, but how if the plate is 4-mm thick, how do the switches snap into it? The tabs on a traditional switch are designed for a specific plate thickness, correct? Is the plate indented to let those tabs nestle into the plate?
This is a bit more of a concern with a hot-swap PCB, since there's no solder holding the switch legs.
Offline pixelpusher
« Reply #77 on: Mon, 13 May 2019, 16:58:11 »
The switch openings are milled out to 1.5mm underneath to let the switches snap in on the top and bottom.
Offline Simen
Re: [IC] FOX × INETT:SQUARE 80% (Phototype + Pristine - May 14th)
« Reply #78 on: Tue, 14 May 2019, 10:39:06 »
Here is a picture for plate for your reference :) hope it can be more clear.
Offline Simen
« Reply #79 on: Tue, 14 May 2019, 10:40:12 »
Absolutely, YES. We already have prototypes and make it in reality  :p
Offline Simen
« Reply #80 on: Tue, 14 May 2019, 10:42:31 »
Thanks. Yes, the 'inner rim' takes us a lot of time to think how to make it in reality. Finally, we found that it can connect with plate. But it actually bring more troubles for plate manufacturing. Hope you enjoy it  :thumb:
Offline vi0till
« Reply #81 on: Tue, 14 May 2019, 22:17:53 »
My question:
1. QMK compatible PCB will not have RGB?
2. GB date has been set?
Offline Simen
« Reply #82 on: Wed, 15 May 2019, 01:02:49 »
My question:
Thanks for looking.
1 YES, RGB light is not shipped with qmk compatible PCB.
2 It should be very soon.  :p
Offline nu_types
  • Formerly Iredeus
« Reply #83 on: Thu, 16 May 2019, 20:29:44 »
No blue option? I really like the blue prototype that you have.
Offline blizzara01
« Reply #84 on: Thu, 16 May 2019, 21:58:20 »
The color outline around the keycaps comes from the plate? I hope there will be no visible gap between the top piece and the outline color of the plate.
Offline Simen
« Reply #85 on: Fri, 17 May 2019, 00:17:14 »
During GB, I am sorry that blue option will be removed since it looks very nice in camera, but you will feel a little disappointed under normal light. Only beautiful options will be available in GB  :thumb:
Offline Simen
« Reply #86 on: Fri, 17 May 2019, 00:19:40 »
Yes, it comes from plate. As my feel for prototype, the gap between inner rim and case is not easy to detect, and we are trying our best to make it as close as we can .
