Author Topic: hot-swappable pcb for KBD75v2?  (Read 7138 times)
Offline Kukulcanvs
« on: Mon, 06 May 2019, 19:31:35 »
Hi geeks,
I am new to this community and really excited to build my first custom keyboard.
Been looking around and I think I want to go with KDBfans 75v2 as my first build. But it seems that the pcb that's included in the kit is not hot swappable?
So question is how to tell if a pcb is hot swappable or not? Any recommended hot-swappable pcb for KBD75v2?
Offline rondg
Re: hot-swappable pcb for KBD75v2?
« Reply #1 on: Mon, 06 May 2019, 20:40:56 »
I don't think there is a hot-swappable pcb for the kbd75. You have to convert the pcb to hot-swappable yourself.  You can search for hot-swap sockets. I think they are called mil max? Not sure though...
Offline rajendra82
« Reply #2 on: Mon, 06 May 2019, 22:26:45 »
I personally haven't done what this video shows, so take it for what it's worth.
