Author Topic: [IC] GMK Dracula — Group buy is live!  (Read 305612 times)
Offline pikku-allu
  • IG: @kinnalek
« on: Wed, 15 May 2019, 16:00:55 »
> Initializing GB 'Link' ...
$ gmk install -g @dracula/core-module
$ gmk install -g @dracula/highlight-module
$ gmk install -g @dracula/nightmode-module
$ gmk install -g @dracula/whitespace-module
$ gmk install -g @dracula/minify-module
$ gmk install -g @dracula/localization-module
$ gmk install -g @dracula/command-module
$ gmk install -g @dracula/err-module
$ gmk run deploy
> Starting 'deploy' ...
> Uploading: geekhack/interest_checks/gmk-dracula/master.tar.gz
> [=============================] 100% 0.0s
> Initializing IC ...
Welcome to the GMK Dracula Interest Check thread! ▓▒░
Introducing GMK Dracula, a keyset based on the glorious Dracula Theme color-scheme. GMK Dracula turns the software aesthetic into keyboard keyset form, expanding the theme even further with add-on modules. The set features dark greyish blue tones with dark blue-purple-gray alphas. The default legend color is a contrasting neutral/cool white, which adds to the overall legibility of the classic text + icon legends. In addition, the Core and add-on modules include legends and accent keys in various pastel and neon colors, all based on selected Dracula Theme colors.
Update [2019-09-17]
Good news everyone! Update time—finally! The group buy for GMK Dracula is launching on October 4th on Dixie Mech, Mykeyboard.eu, Daily Clack Dracc Dracc Dracc!, and iLumkb!
There are three new kits, see below! All of the existing kits have received updates as well.
> Setting up proxies ...
> Proxy set to 'Dixie Mech' ...
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ GB_INFO.txt ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
├── GB_vendors/
│ └── proxy_list/
│     ├── NA - Dixie Mech
│     ├── EU - Mykeyboard.eu
│     ├── Oceania/Asia - Daily Clack
│     └── China/Asia - iLumkb*NEW
└── GB_date/
    └── Group Buy - October 4th [2019-10-04]
Modules
Core【 MODULE】
The Core Module is the starting point of the set, featuring classic multicolored syntax highlighting of the Dracula Theme. The module offers compatibility for most layouts, while keeping the cost down by not bloating the kit with too much options.
Highlight【 MODULE】
Spice up your set with fully colored accent keys for extra highlighting, featuring cherry-picked theme colors.
Nightmode【 MODULE】
If you enjoy a CLEAN look, it's time to turn on the nightmode for GMK Dracula.
Tone down the look of your set with a unified modifier color-scheme with the Nightmode Module.
Whitespace【 MODULE】
Whether you like to use spaces or tabs for indentation, that's up to you …
Here's some whitespace inserting blocks for everyone to use, including accent colored ones.
Minify【 MODULE】
Here it is! The ultimate kit for 40%, ortholinear, and split layout keyboards. But wait, there's more! Even a second B key is included in case your dog eats the other one.
Localization【 MODULE】
Language support for Nordic (Danish, Finnish, Swedish, Norwegian), German, and UK layouts.
Command【 MODULE】
What did you think it was going to be called? Support for macOS specific keys. Starting at $999.
> 'deploy' encountered an error after 120 ms
> gmk ERR! Error: Fatal: access denied
> gmk ERR! @dracula/err-module not found
░░░░░░░░░░░░░░░░░ ERR! ░░░░░░░░░░░░░░░░░
├── IC/
│ └── GMK_modules/
│     ├── core-module
│     ├── highlight-module
│     ├── nightmode-module
│     ├── whitespace-module
│     ├── minify-module
│     ├── localization-module
│         └── EU.eww
│     ├── command-module
│     └── err-module/
│         └── vim-arrows
├── .ic.config
├── .ne-iso.avail
├── .ne-icon-mods.avail
├── FAQ
└── __feedback__/
    └── form
ERR!【 MODULE】
ERR░R█░▓▓▒░▒▓▒██RR█R!
Deprecated Module Versions:
> Starting subtask 'rebuild' ...
> Starting subtask 'renders' ...
Renders
Album with all the TGR renders: https://imgur.com/a/Kk1WKmF
TGR Jane V2 CE
TGR-910
'Wickle Tickle'
board and renders by Kingk22
More renders coming soon …
Colors
The colors are to be matched as close to the Dracula Theme colors as possible using custom colors, the base colors are very dark grayish blue. A GMK stock color may be used for the white alpha legend color.
The plan is to match the colors to Pantones first, then order plastic color chips, which GMK can then match their plastics to. I think this method allows for a great range of colors to choose from, but still retains the color matching accuracy with plastic chips from Pantone.
A color comparison with other popular/similar GMK sets:
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ COLOR_COMPARISON.md ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
├── The colors are represented as accurately as possible using the correct color codes, using neutral lighting.
└── The second version has a neutral background color instead of a stylized one for an even more accurate comparison, as perception of color is relative to the surroundings after all.
Gloomy Colors™
│   Color   │   Hex    │     RGB     │      HSL      │   │
│ Modifiers │ #282a36  │    40 42 54 │ 231° 15% 18%  │ ■ │
│ Alphas    │ #44475a  │    68 71 90 │ 232° 14% 31%  │ ■ │
│ Legends   │ #f8f8f2  │ 248 248 242 │ 60° 30% 96%   │ ■ │
│ Pink      │ #ff79c6  │ 255 121 198 │ 326° 100% 74% │ ■ │
│ Purple    │ #bd93f9  │ 189 147 249 │ 265° 89% 78%  │ ■ │
│ Cyan      │ #8be9fd  │ 139 233 253 │ 191° 97% 77%  │ ■ │
│ Yellow    │ #f1fa8c  │ 241 250 140 │ 65° 92% 76%   │ ■ │
│ Green     │ #50fa7b  │  80 250 123 │ 135° 94% 65%  │ ■ │
│ Red       │ #ff5555  │   255 85 85 │ 0° 100% 67%   │ ■ │
FAQ
> ne icon mods avail
> At least not in the base kit
Changelog
│                 Commit                  │     Date     │ Branch │
│ feature: added color comparison         │ [2019-06-08] │ master │
│ feature: announced vendors              │ [2019-05-30] │ master │
│ feature: added feedback form            │ [2019-05-22] │ master │
│ fix: added Full HHKB layout support     │ [2019-05-22] │ master │
│ (2x R4 1u Ctrl/Alt + 2x R4 1.5u Super)  │              │        │
│ feature: added initial IC               │ [2019-05-15] │ master │
  • Added color comparison [2019-06-08]
  • Announced vendors [2019-05-30]
  • Added feedback form [2019-05-22]
  • Added full HHKB layout support (2x R4 1u Ctrl/Alt + 2x R4 1.5u Super) [2019-05-22]
  • Added initial IC [2019-05-15]
TODO
  • Add 40's/ortho/split module
  • Add feedback survey form
  • Deskmats
Acknowledgements
  • Huge thanks to Oblotzky for advice and suggestions regarding the kits and everything else.
  • Shout-out to Qlavier for feedback on the project!
  • Big thank you to Dixie for everything!
  • Thank you Yuktsi for providing the TGR board models for rendering
  • Thank you Kingk22 for the 'Tickle Wickle' renders
All the renders, kit designs, novelties and graphics are done by me, if not stated otherwise.
« Last Edit: Fri, 04 October 2019, 17:16:41 by pikku-allu »
Offline pikku-allu
  • IG: @kinnalek
Re: [IC] GMK Dracula
« Reply #1 on: Wed, 15 May 2019, 16:01:09 »
reserved
« Reply #2 on: Wed, 15 May 2019, 16:04:29 »
im sure people won't compare this to oblivion
Offline wixxzblu
« Reply #3 on: Wed, 15 May 2019, 16:07:04 »
i like this just as much as nord  :thumb:
Offline hayt
« Reply #4 on: Wed, 15 May 2019, 16:07:39 »
Nice, hot
Offline mwahlig
« Reply #5 on: Wed, 15 May 2019, 16:09:51 »
Nice! I use a slightly tweaked Dracula theme in Xcode :) Looking forward to seeing the ortho kit.
Offline dhb82
« Reply #6 on: Wed, 15 May 2019, 16:11:41 »
ne NorDe avail?
Offline LXVRGS
« Reply #7 on: Wed, 15 May 2019, 16:13:06 »
god yes the dracula color scheme is my all time favorite.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #8 on: Wed, 15 May 2019, 16:14:43 »
Or Penumbra?
Text editor color schemes are great choices for keyset colorways IMO.
Offline heskew
« Reply #9 on: Wed, 15 May 2019, 16:16:35 »
* heskew grabs dracula theme for vs code...
Didn't know this theme existed. Looks like you've put some good effort into this ic and it think I might need this....
Offline horribleatcalculus
« Reply #10 on: Wed, 15 May 2019, 16:18:25 »
cadet alphas pls
Offline heskew
« Reply #11 on: Wed, 15 May 2019, 16:19:03 »
Yeah, and others. That's fine.
Offline badchad
« Reply #12 on: Wed, 15 May 2019, 16:23:38 »
Love it and second the cadet alphas
BAD
Offline IOVERCALLHISTIOCYTES
« Reply #13 on: Wed, 15 May 2019, 16:25:53 »
...novelties?
Offline dydy124
« Reply #14 on: Wed, 15 May 2019, 16:44:25 »
If this makes it to Group Buy, count me in for sure!!
Offline neojonathan
« Reply #15 on: Wed, 15 May 2019, 16:45:58 »
Love this !!!!
Offline godlikekitten
« Reply #16 on: Wed, 15 May 2019, 16:47:33 »
Reminds me of Monokai almost, definitely in on this.  Cadet alphas would be  :eek:
Offline dallman5
« Reply #17 on: Wed, 15 May 2019, 16:55:00 »
This is amazing! Its very much improved since the original reddit post. The error module kit is so cool  :thumb:
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #18 on: Wed, 15 May 2019, 16:57:00 »
Offline ZG2047
« Reply #19 on: Wed, 15 May 2019, 16:59:06 »
This is a good alternative to GMK Oblivion V2 I'm tempted.
Offline Starius
« Reply #20 on: Wed, 15 May 2019, 16:59:20 »
 You had me with ERR! modules.
 :thumb:
Offline cyriously
« Reply #21 on: Wed, 15 May 2019, 17:03:27 »
Amazing. Git mods like oblivion would be perfect!
Offline wholypantalones
  • text and icon mods plz.
« Reply #22 on: Wed, 15 May 2019, 17:03:52 »
I likes it.
« Last Edit: Wed, 15 May 2019, 21:19:59 by wholypantalones »
« Reply #23 on: Wed, 15 May 2019, 17:16:39 »
Dracula is a great color scheme and this is a nice homage to it. Obviously this will be in competition with Nord and Oblivion, which is fine. This one brings some nice innovation to the table with the highlight and error kits. Good job.
That said, I think the renders have more of a purple cast than I expected. Maybe it's just an optical illusion.
Offline bard
« Reply #24 on: Wed, 15 May 2019, 17:43:28 »
looks like I might have a matching caps to my vim and terminal  :thumb:
please remember about erog users :D
Offline MrCoolPants
« Reply #25 on: Wed, 15 May 2019, 17:54:31 »
Would totally be in for a base set with the Nightmode and ERR kits as well.
Offline futurecrime
  • Get Zooted
« Reply #26 on: Wed, 15 May 2019, 18:12:20 »
This is a really nicely formatted IC. I'd definitely be up for checking out the GB post if it happens.
Offline click clack jack
« Reply #27 on: Wed, 15 May 2019, 18:12:34 »
Oh **** this is hot!!
Offline qwertzhz
« Reply #28 on: Wed, 15 May 2019, 18:29:23 »
Big fan of Dracula, count me in! Looks like it'll be really cool. I'd be in for a base & highlight set.
Offline juliandoucette
« Reply #29 on: Wed, 15 May 2019, 18:34:28 »
Looks amazing so far! Count me in!
Offline OtherAndrew
« Reply #30 on: Wed, 15 May 2019, 18:35:14 »
Please consider adding R3 1.75u ERROR! novelties.
Offline FunTyme
  • Formerly known as Edrylle
« Reply #31 on: Wed, 15 May 2019, 18:45:52 »
I can get behind this 100%!
hbcp
Offline flippanteer
« Reply #32 on: Wed, 15 May 2019, 18:46:55 »
Totally behind! Interested!
Current boards: FLX Virgo w/ NK Drys, E8.5 w/ NK Drys, LZ Physix w/ H1s,  Moon TKL w/ MX Zilents, HAD66 [Alice layout] w/ NK Creams, KBD75v1 w/ Zealios 67g v1
Purchased boards: Infinitum
Past boards: Trinity w/ Tealios v2, Lubrigante w/ Holy YOK Trash Pandas, Kumo w/ Novelkeys Cream, Diverge 2 w/ MX Browns, Planck w/ MOD-H, Anne Pro w/ MX Blue
Offline Vigrith
« Reply #33 on: Wed, 15 May 2019, 18:48:17 »
Love everything about this except for the wacky coloured mods. I'm just not big on that at all, for any set, it almost works here but still. Great set though honestly.
Offline vicissitude
« Reply #34 on: Wed, 15 May 2019, 18:53:25 »
Interested.
Show us more novelties.
Offline forevermadrigal
« Reply #35 on: Wed, 15 May 2019, 19:13:31 »
That's gonna be a yes :cool:
Offline KevlarBear
« Reply #36 on: Wed, 15 May 2019, 19:15:57 »
The kit with nightmode looks really nice, in!
Offline fcoury
« Reply #37 on: Wed, 15 May 2019, 19:31:28 »
OK, this is incredible. Quickly becoming one of my most wanted sets.
Offline rondg
« Reply #38 on: Wed, 15 May 2019, 19:31:49 »
Looks nice
Offline vonswoopington
« Reply #39 on: Wed, 15 May 2019, 19:35:07 »
love the error modules.  i'm in
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline OracleKev
« Reply #40 on: Wed, 15 May 2019, 19:45:38 »
Like how colors and theme are blended together :thumb:
Offline mrpetrov
« Reply #41 on: Wed, 15 May 2019, 19:48:48 »
Really thoughtful and beautiful. Well done and yes please.
Offline rondg
« Reply #42 on: Wed, 15 May 2019, 19:49:44 »
Took a second look at the error module and I'm really loving it! I am definitely in!
Offline weaston
« Reply #43 on: Wed, 15 May 2019, 19:50:00 »
This is such an awesome set, really hoping it happens.
 :thumb:
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
Offline DJSwayde
« Reply #44 on: Wed, 15 May 2019, 20:11:25 »
This is probably my favorite GMK set in years. So dope.
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Sage (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
Offline le_wraith
« Reply #45 on: Wed, 15 May 2019, 20:20:59 »
this is so tight, especially b/c I use Dracula in WebStorm  ;D
Offline rkarp
    • hypertext.dev
« Reply #46 on: Wed, 15 May 2019, 20:33:34 »
my fav color scheme - I'm in...
Offline bthezebra
« Reply #47 on: Wed, 15 May 2019, 20:36:01 »
I don't code but I like!
Offline sirosoup
« Reply #48 on: Wed, 15 May 2019, 20:36:29 »
Love it.
Offline dantambok
« Reply #49 on: Wed, 15 May 2019, 20:44:02 »
very nice!  :thumb:
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
