Author Topic: Cleaning switches  (Read 2169 times)
Offline TeacherGeek
Cleaning switches
« on: Fri, 17 May 2019, 18:33:08 »
So I harvested some switches off a board. The board was old and had been left out in the weather a bit getting dirt etc into the board.
I was wondering the best way to clean them.
I was thinking of taking them apart and dumping some methylated spirits onto the housing.
Yes, I know this is a lot of work but I am having fun doing it and learning about keebs
Re: Cleaning switches
« Reply #1 on: Fri, 17 May 2019, 18:58:47 »
Why though?
If they're that trashed what's the point?
What switches are they?
I mean if they've literally been out in the weather you might as well run them through the dishwasher.
Switches are so cheap and easy to get nowadays doesn't seem worth it.
Offline TeacherGeek
« Reply #2 on: Fri, 17 May 2019, 19:41:59 »
Because I'm having fun exploring.
So you're saying I can dishwasher them and it'll be fine aye
« Reply #3 on: Fri, 17 May 2019, 19:43:31 »
No that was a joke but I mean if you're exploring give it a shot.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #4 on: Sat, 18 May 2019, 06:26:44 »
Found this on the internet, might help https://forums.tomshardware.com/faq/how-to-clean-and-lubricate-your-mechanical-keyboard.1560147/
Just my thoughts
