Author Topic: KBDFANS8X MkII  (Read 31192 times)
Offline HungerMechanic
Re: KBDFANS8X MkII
« Reply #50 on: Sun, 12 January 2020, 12:42:09 »
Yeah, I ended up getting a Leopold customized with the money I had earmarked towards the mkii.
And since it still isn't available, I'm getting a Leopold customized again, this time with Ergo Clears or OUTEMU Silent Forest.
I guess it would have been much faster and more reliable to join the JER-A06 GB that was happening around the same time.
Offline tron
Re: KBDFANS8X MkII
« Reply #51 on: Sun, 12 January 2020, 14:45:12 »
I got mine in before the holidays. It's a decent board for the price. When I purchased it I was under the impression the caps lock led could be set to indicator and toggle on/off like the scroll lock led.
Offline Surefoot
Re: KBDFANS8X MkII
« Reply #52 on: Mon, 13 January 2020, 00:23:11 »
You can solder a LED yourself, and use QMK for on/off...
Offline tron
Re: KBDFANS8X MkII
« Reply #53 on: Mon, 13 January 2020, 18:42:54 »
I have an led in there but don't know how to manually program the caps lock led to toggle on/off in sync with the caps lock. I use QMK configurator and toolbox.
