Author Topic: [IC] Arc80: Gasket TKL Keyboard by Demo & Airpotter  (Read 135404 times)
Offline pcire
Re: [IC] Arc80: gasket-mount 80% keyboard by Demo & Airpotter
« Reply #50 on: Wed, 22 May 2019, 00:39:45 »
I’ll be in if under $350, even though I’ve spent all my budget for the year :(
Offline Nagato
« Reply #51 on: Wed, 22 May 2019, 06:30:41 »
That's a great tkl design you got there. I'm definitely interested if the price isn't past 400.
Offline Hell-es
« Reply #52 on: Wed, 22 May 2019, 11:46:29 »
How about hot swap pcb ? There are almost no tkls out there - except the drop ctrl with hot swap.
Definatelly very interessted - after think 6.5 was a real nice gb
Offline oldcat
  • 65% is Life
« Reply #53 on: Wed, 22 May 2019, 20:37:50 »
Price will be under $350 I believe
100% under 400
Offline wt5now
Re: [IC] Arc80: gasket-mount TKL keyboard by Demo & Airpotter
« Reply #54 on: Wed, 22 May 2019, 23:59:49 »
Can switch LEDs be soldered on PCB or not?
« Last Edit: Thu, 23 May 2019, 00:02:05 by wt5now »
Offline frankh
« Reply #55 on: Thu, 23 May 2019, 09:01:38 »
if logo on the upper right corner is removed, that would be awesome.
I hope there will be a option for that.
+1
Offline oldcat
  • 65% is Life
« Reply #56 on: Thu, 23 May 2019, 17:15:42 »
It will come with SMD RGB LEDs on every key I believe
Offline oldcat
  • 65% is Life
« Reply #57 on: Thu, 23 May 2019, 17:16:10 »
+1
Yes it will be removed or be some better logo
Offline oldcat
  • 65% is Life
Re: [IC] Arc80: Gasket TKL Keyboard by Demo & Airpotter
« Reply #58 on: Fri, 24 May 2019, 16:25:08 »
changing to plain badge
219872-0
Offline DEMO S
  • Demo Studio
« Reply #59 on: Sat, 25 May 2019, 05:41:14 »
1
PCB maker for premium keyboards.
Instagram: demostudio01
Offline DEMO S
  • Demo Studio
« Reply #60 on: Sat, 25 May 2019, 05:59:48 »
2
Offline oldcat
  • 65% is Life
« Reply #61 on: Sat, 25 May 2019, 13:31:32 »
More details:
PCB is full RGB
Price ~350
FCFS limited GB
Offline sirieous
  • help
« Reply #62 on: Sat, 25 May 2019, 20:57:14 »
This looks so nice wtf
Offline oldcat
  • 65% is Life
« Reply #63 on: Sun, 26 May 2019, 12:37:33 »
Thanks! It is still in the prototyping stage, so any feedback is welcome!
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #64 on: Sun, 26 May 2019, 13:17:09 »
Gasket only on one side?
Offline oldcat
  • 65% is Life
« Reply #65 on: Sun, 26 May 2019, 13:31:29 »
The plate is designed to be mounted to the bottom (like Canoe) with gaskets in between the plate and the bottom. So in theory another top gasket will not affect the typing feel.
That said, Potter and demo said double-sided gaskets can be done easily if that is preferred by the community.
Offline nathanchere
« Reply #66 on: Mon, 27 May 2019, 04:16:56 »
2. Fully customizable Dual-mode PCB (usb type C + Bluetooth), full RGB
3. Premium quality Aluminum 6063
When will makers learn that full aluminium builds and Bluetooth really don't mix?
Offline coffeeshopcoder
« Reply #67 on: Mon, 27 May 2019, 05:25:36 »
Will the honey bush h87a pcb work on this case ?
Offline mkarlsson
« Reply #68 on: Mon, 27 May 2019, 07:08:05 »
If Hiney hears you...
Offline lukelex
« Reply #69 on: Mon, 27 May 2019, 07:23:34 »
Will we have different color options for the top case? Hoping for some yellow tbh
Sent from my SM-G975F using Tapatalk
Offline ricesteam
« Reply #70 on: Mon, 27 May 2019, 08:11:26 »
Roughly, how many kits will be available? Any chance of doing raffle style instead of the nonsense FCFS?
Offline nathanchere
« Reply #71 on: Mon, 27 May 2019, 08:57:10 »
FCFS is much less 'nonsense' than raffle.
Offline iaman
« Reply #72 on: Mon, 27 May 2019, 09:13:02 »
Depends on what you think of as nonsense: several GBs lately have been open for a minute or two before hitting max quantity. FCFS prioritizes fast typists with fast internet with free time in a convenient time zone, and I’m sure plenty of folks consider that prioritization to be nonsense.
Offline lukelex
« Reply #73 on: Mon, 27 May 2019, 09:30:02 »
Nonsense is anything shouted by the ones who didn't get in.
Offline iaman
« Reply #74 on: Mon, 27 May 2019, 10:03:13 »
Cool
Offline oldcat
  • 65% is Life
« Reply #75 on: Mon, 27 May 2019, 20:07:04 »
I believe this has been tested and resolved. Stay tuned for more details!
Offline Ensaum
« Reply #76 on: Mon, 27 May 2019, 20:24:08 »
I think it would be cool if there where an option to have a light pipe for the badge.
What colors options will there be? I might possibly get this in black and pair it with Laser.
Offline oldcat
  • 65% is Life
« Reply #77 on: Tue, 28 May 2019, 16:05:00 »
Black should definitely be an option! There will be a few colorways available I believe. I will let Demo comment on this
Offline jedidood
  • aka neovisual
« Reply #78 on: Thu, 30 May 2019, 23:13:12 »
Silver looks great, I am in!
Offline DEMO S
  • Demo Studio
« Reply #79 on: Fri, 31 May 2019, 00:26:27 »
A quick update: we incorporated the GH and discord community's suggestion, and the Arc80 now features a double-sided gaskets design
Offline oldcat
  • 65% is Life
« Reply #80 on: Fri, 31 May 2019, 18:28:52 »
I love double-sided gaskets.  :thumb: :thumb: :thumb:
Offline poodude
« Reply #81 on: Sat, 01 June 2019, 00:00:27 »
So many TKLs being released in succession. This design is a little too busy for me, I'm a less is more kinda guy.
« Reply #82 on: Sat, 01 June 2019, 07:24:51 »
+1
Offline lukelex
« Reply #83 on: Sat, 01 June 2019, 08:11:05 »
Plenty of folks would also consider getting a medal, for winning a competition, nonsense. Instead of punishing those who did well, these "folks" should focus on making sure that they can make it next time. We can't all be winners.
Offline vi0till
« Reply #84 on: Sun, 02 June 2019, 02:44:49 »
More details:
PCB is full RGB
Price ~350
FCFS limited GB
[/quote
Will you offer WKL layout as well?
Offline iaman
« Reply #85 on: Sun, 02 June 2019, 07:56:04 »
I sincerely recommend that you talk to a therapist about your concept of punishment, buddy
Offline Visionaire
« Reply #86 on: Sun, 02 June 2019, 12:50:17 »
What if I told you that many of the limited availability items are sold before the webstore opens, or are snapped up by bots (which operate faster than you can do by hand...)
Offline lukelex
« Reply #87 on: Sun, 02 June 2019, 17:22:41 »
Nah I'm good. I'll just keep buying keebs instead of trying to come up with random arguments to make me feel better about not getting into a GB.
Offline lukelex
« Reply #88 on: Sun, 02 June 2019, 17:23:55 »
Unless the GB runner explicitly says that a specific behavior isn't allowed, everything is fair game.
Offline Visionaire
« Reply #89 on: Sun, 02 June 2019, 17:38:03 »
Technically it's fair game for scalpers who use bots to sell out concert tickets to flip them too... doesn't make it much fun to be a fan of something...
Offline iaman
« Reply #90 on: Mon, 03 June 2019, 09:40:20 »
  • You're assuming that I've got some kind of beef about not getting into a FCFS GB, which is absolutely not the case; I'm pretty new to this community and nothing has been quite what I wanted, so I've never even tried to get into a FCFS GB (or a raffle for that matter)
  • I literally only stated what each of those methods prioritized and gestured at the fact other members of this community feel differently from you about those methods
  • The literal concept of a limited sale already asserts your claim of "We can't all be winners" regardless of how that sale is conducted. Your statement was not in any way related to the concept that was presented
  • You can't "do well" in a raffle; that's sort of the entire point. Therefore, you can't be punished for doing well
I never even tried to argue that I personally prefer raffles to FCFS; I live in a pretty decent timezone for most of this stuff, so I have the privilege to not be particularly affected by these things. It sounds like you're in a similar boat, whether that is due to the timezone in which you live or the way you've structured your life; that's pretty great for you, and I'm glad you can get the boards you want to get! Other folks don't necessarily have the privileges we have, but I don't think their lack of those privileges means they shouldn't get the nice things we can get. I think looking out for folks who have less privilege than yourself and listening to them when they feel like things are conducted in a way that is unfair to them is an important aspect of building and maintaining any community.
« Last Edit: Mon, 03 June 2019, 09:45:45 by iaman »
Offline lukelex
« Reply #91 on: Mon, 03 June 2019, 10:03:45 »
I ain't assuming anything. None of my comments are directed to anyone in particular. Hence the regular use of "those".
Welcome  :). It's always nice to have new faces around.
I'm sure you'll eventually find something that tickles your fancy.
Great. It's always nice to have different opinions being voice. Hail to freedom of speech.
So we're in aggressive agreement.
You can't "do well" in a raffle; that's sort of the entire point. Therefore, you can't be punished for doing well.[/li][/list]
If the justification for running a raffle is that most people feel outlied than you'd be indeed punishing the ones that were "doing well", on the FCFS model, by being faster or smarter by using bots.
Nor have I ever said that you did.
Great. Good luck (probably not the best expression given the context) when you do enter one  :cool:.
I'm in a horrible timezone for most FCFS. They usually go live between 1am and 6am for me.
Neither do I. But complaining and blaming the model instead of adjusting yourself is recipe for endless frustration and long GH rants. Neither will get them pretty boards.
This is where we disagree. Fairness has nothing to do with it. Everyone has their own personal definition of fairness and it's a constant struggle that will never end. So instead of trying to reach this unachievable goal we should make sure that GB runners can do better at providing more boards then more people can have pretty boards on their desks.
Offline eskimojo
    • KeycapLendar
« Reply #92 on: Mon, 03 June 2019, 10:10:07 »
holy mother of barely relevant wall of text
Offline lukelex
« Reply #93 on: Mon, 03 June 2019, 10:12:32 »
You're welcome  ;D
Offline oldcat
  • 65% is Life
« Reply #94 on: Mon, 03 June 2019, 22:11:56 »
haha
Offline Bhk1004
« Reply #95 on: Tue, 04 June 2019, 08:33:51 »
haha
BRASSSSSSSSSSSSSSSSSSSSS
or PC would be cool... Steel??????????????????
Offline oldcat
  • 65% is Life
« Reply #96 on: Tue, 04 June 2019, 21:09:45 »
haha
New renders. Hmm more brass????
Offline gotemall
« Reply #97 on: Tue, 04 June 2019, 22:33:06 »
More details:
PCB is full RGB
Price ~350
FCFS limited GB
FCFS  doesn't bother me but the real question is what is meant by "limited". If you mean limited like say other GB that consist of 20keebs, where you have stuff selling out in less than 30 secs?
However if you mean limited GB like say 100-150 keebs, than thats is fine; as that would give those who want to get the board to actually have more than a few secs to try and get them.
Any Idea on how man they are planning on?
Offline DEMO S
  • Demo Studio
« Reply #98 on: Tue, 04 June 2019, 22:35:22 »
haha
hello bro  ;)
Offline Nintenga
« Reply #99 on: Tue, 04 June 2019, 23:05:16 »
What are the chances of alps compatibility
Curious as well! alps + gasket mount seems to be a great combo
