Author Topic: [IC] Bumper: a 60% keyboard case (Updated 14 SEP 2020)  (Read 32496 times)
Offline johnatzap
    • Zap Cables
« on: Thu, 23 May 2019, 08:16:05 »
UPDATE: 14 SEP 2020
Polycarbonate/Brass Bumper available for pre-order now.
We're offering a limited number (50) of Polycarbonate Bumpers for pre-sale, available now (while quantities last)! A fair amount has changed since our original post, though for the most part the design has remained pretty much the same.
https://zapcables.com/bumper-60-keyboard-case/
Images as well as description of what's included can be seen at the above link. This pre-sale is for the case only, there is no plate or PCB included. Bumper will accommodate a standard 60% PCB.
Bumper
Round with age and groaning from the weight of technological advancement, Bumper is a tray-mount 60% keyboard case longing for the good old days.
Bumper’s main design features are her round, smooth contours and her interchangeable side insert pieces. We refer to them as “flippers.”
Some initial specifications:
  • Measurements: 31 x 13.5 x 3.2 cm / 12.25 x 5.25 x 1.25 in
  • Total weight: 1.8 kg / 4 lbs. assembled (with aluminum body and polycarbonate flippers)
  • Typing angle: 7°
  • Case material options: CNC’d aluminum or polycarbonate
  • Side insert (flipper) material options: CNC’d aluminum or polycarbonate or brass
  • Coating: Cerakote (various colors)
Bumper will come with: 1x body, 2x flippers (1 left and 1 right), M2 screws for a PCB (PCB not included), flat black hex M2 screws for the flippers, mini hex wrench for flipper screws, neoprene non-slip footings with pressure-sensitive adhesive, box, sticker, longing.
There will likely be no 60% PCB. Nor plate. Nothing at all but the delicious, sloping curves of a keyboard case that’s been around the block many times, slapping away would-be interlopers as it goes.
However, there will be downloadable files you can use to produce or print your own flippers! There will also be the opportunity to purchase extra sets of flippers in different colors, so you can get the most out of your Bumper. Swap ‘em, trade ‘em, make your own!
She pops, she rolls, she ramps, she pings. She may even light up. And if you can’t already tell, Bumper likes pinball! You could call it her...inspiration.
GB plans:
  • Date: Will be announced once second round of prototypes is in-hand and confirmed good (which should be the end of July).
  • Quantity: MOQ will be low. Probably 50.
  • Price: TBD. Likely in the mid-$200s.
Initial Prototype & Render Gallery
Interest Check Form
Updates:
June 2, 2019
  • Here's a better look at how the polycarbonate flippers look with the threaded holes tapped and black screws inserted: https://imgur.com/dvYQFYp
  • There has been a lot of interest in a PCB/plate add-on option, so we are exploring those options
  • We've made some small design tweaks to the prototype and are having a new prototype made to share before the GB, so we can communicate clearly how the final Bumper run will look
July 10, 2019
Sorry things have been taking longer than expected, but, hey…things have been taking longer than expected. We have just placed an order for a second round of prototypes (including a polycarbonate keyboard body and a set of brass flippers), which we should have in-hand in about 3 weeks.
Once we get those in, tested for fit, and are feeling good about them, we will be ready to announce an initial small group buy! Details on that will come as soon as we get the round 2 prototypes in the shop and inspected.
Here is a short list of the tweaks we made form the round 1 prototype, based on the feedback we've received over the past several weeks:
  • Tightened the gaps around the border of the keycaps
  • Made the shine-through cutout holes on the sides of the keyboard body into one large hole (where originally it was two separate holes on each side)
  • Slightly tweaked the thickness of flippers and made them flatter on the inside face, which we hope will help the fit and also make it easier to create custom flippers
  • Made case slightly higher profile
  • Made it a 4-post mounting design instead of the traditional 6-post design
We’re really excited to see the new prototypes in person, and think they will yield a pretty sweet, clean (and hefty) board :)
More Discussion in our Discord
« Last Edit: Mon, 14 September 2020, 12:03:37 by johnatzap »
Offline cijanzen
« Reply #1 on: Thu, 23 May 2019, 08:18:10 »
That last render
Love the shape of the board too. I like them curves!
Offline audiosl4ve
  • Just slave
Re: [IC] Bumper: a 60% keyboard case
« Reply #2 on: Thu, 23 May 2019, 08:19:35 »
Looking bumpy. Love it  :thumb:
Offline fcoury
« Reply #3 on: Thu, 23 May 2019, 08:20:21 »
I really like the design, reminds me of the pingmaster profile. The only thing I am not sold is the side glow. I think it may need more diffusion?
Offline KingOfMemes
« Reply #4 on: Thu, 23 May 2019, 08:21:36 »
That last render
Those curves are soooo sexy. I also like the idea of modular side weights.
Offline johnatzap
    • Zap Cables
« Reply #5 on: Thu, 23 May 2019, 08:25:42 »
May be possible. We can look into some other material options perhaps. Thanks for the note!
Offline worldspawn
« Reply #6 on: Thu, 23 May 2019, 08:51:17 »
Option for switch installation in the flippers? Wanna get my pinball on  ;)
I can make acrylic laser cut cases/plates PM for info
Offline KingOfMemes
« Reply #7 on: Thu, 23 May 2019, 08:53:25 »
ROFL breh...
Offline lendflat
« Reply #8 on: Thu, 23 May 2019, 08:56:51 »
Polycarbonate body with brass flippers......WOW
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #9 on: Thu, 23 May 2019, 09:01:44 »
You read my mind!
Offline Riba
« Reply #10 on: Thu, 23 May 2019, 09:38:17 »
Really elegant, reminds me of Memotech. :)
I wish it was something like 75% though. Good luck!
Offline Fallakin
« Reply #11 on: Thu, 23 May 2019, 10:04:09 »
I have a dream of Purple with Brass flippers and I have a MIGHTY need.
Offline johnatzap
    • Zap Cables
« Reply #12 on: Thu, 23 May 2019, 10:10:42 »
Now I want this. It'd be cool if the flippers themselves were buttons...paddles, more like. Sounds like a v2 feature ;)
Offline Cee
« Reply #13 on: Thu, 23 May 2019, 11:58:26 »
Looks nice, but any plans to reduce that gap between the case and caps?
Offline cjt9000
  • Beige Man
« Reply #14 on: Thu, 23 May 2019, 12:33:40 »
If you mean the gap between the bottoms of the caps, and the top edge of the case, at least in the renders it looks like it was designed to match the bottoms of GMK caps, I know DSA can tend to have slightly shorter side walls vs GMK, which is why it kinda looks like there's a bit of a gap.
B E I G E
Offline Cee
« Reply #15 on: Thu, 23 May 2019, 13:57:29 »
In the renders gallery look at the pics with GMK Olivia, still has that gap.
Offline johnatzap
    • Zap Cables
« Reply #16 on: Thu, 23 May 2019, 16:22:33 »
Sure, I think I understand what you are talking about there. We don't have plans to make any changes in that respect, but if it seems like something that raises concern for people we can certainly look at it. I'll get some better images of the case with some GMK caps on it tomorrow and post some images that show it a little better!
Offline Vadurr
  • Valar Morghulis
« Reply #17 on: Thu, 23 May 2019, 16:29:51 »
I really dig the design! I have two suggestions that might make it more appealing?
1. The spacing could be tighter around the keycaps.
2. Maybe a little higher profile to completely hide the switches?
Either way its a real dope design! :thumb:
Offline Jkush463
« Reply #18 on: Thu, 23 May 2019, 17:14:55 »
hmm i really like this, any plans for other flipper materials?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #19 on: Thu, 23 May 2019, 20:25:34 »
Love the design! Is be much more interested in a tkl or 1800 layout though.
And that polycarb/brass looks so damn good  :eek: :eek:
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #20 on: Thu, 23 May 2019, 21:06:17 »
The polycarbonate with brass looks fantastic, I'd also love that in the purple. Love the interesting design!
Offline Jonathan0903
« Reply #21 on: Thu, 23 May 2019, 21:45:05 »
Disgustingly, painfully thick. I'll take 5 :)
Offline jariss
« Reply #22 on: Fri, 24 May 2019, 00:04:47 »
Love this! Curious to see how this will compare to a ca66. Will it be as hollow and the sound resonate as much?
Offline jyon
« Reply #23 on: Fri, 24 May 2019, 00:47:20 »
I'm loving that design. Both the white and purple bodies with the black or brass flippers. Absolute beauty
Offline nguyenhimself
« Reply #24 on: Fri, 24 May 2019, 08:41:48 »
Holy crap, this is a crazy look. I'm probably in just for this.
Offline ideus
  • Björkö.
« Reply #25 on: Fri, 24 May 2019, 09:05:07 »
If there is a not so expensive version I may be in. I do have a pretty small budget for KB this year.
Offline johnatzap
    • Zap Cables
« Reply #26 on: Fri, 24 May 2019, 14:11:12 »
We'll get a sound test made soon. It doesn't sound hollow IMO...it is made from a single milled piece of aluminum, so it's solid.
Offline KingOfMemes
« Reply #27 on: Fri, 24 May 2019, 14:11:59 »
Thicc boi
Offline Meursault
« Reply #28 on: Fri, 24 May 2019, 15:01:03 »
The brass bumper model is downright beautiful, it  might even be an upgrade to my £15 aliexpress effort ;)
Offline 1corazon
« Reply #29 on: Fri, 24 May 2019, 19:39:26 »
Count me in and take all my  money!!!!!!!!!!!    ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
I NEED THIS IN MY LIFE
Offline Rayndalf
« Reply #30 on: Sat, 25 May 2019, 20:32:24 »
The threading in the polycarbonate bumpers isn't as pretty as if they were just snug fit, or if they had small clips, but it might be the most secure
Offline Fallakin
« Reply #31 on: Tue, 28 May 2019, 06:11:08 »
Wondering if a layout like this would be possible. Highly interested, especially if I can replicate this layout.
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #32 on: Tue, 28 May 2019, 07:52:06 »
Interested,
+1 for countersunk caps ( A MUST )
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #33 on: Thu, 30 May 2019, 04:53:48 »
No PCB, no plate. This is just a standard 60% tray mount case.
Offline Fallakin
« Reply #34 on: Thu, 30 May 2019, 09:31:19 »
Welp, I'm definitely in.
Offline KingOfMemes
« Reply #35 on: Thu, 30 May 2019, 09:33:42 »
Any chance of HHKB form factor?
Offline Rayndalf
« Reply #36 on: Thu, 30 May 2019, 11:57:10 »
Will there be a limit to how many are made or will it be relatively unrestricted?
Offline johnatzap
    • Zap Cables
« Reply #37 on: Sun, 02 June 2019, 07:39:50 »
There will be a limit, we'll likely cap it at either 50 or 100. We'd like to keep it small at first to help us control the process as best we can, and minimize any impact of unforeseen issues. We'll make sure we communicate the availability when we announce a GB date.
Offline fer.real
« Reply #38 on: Sun, 02 June 2019, 07:57:22 »
Polycarbonate with brass, I'm in.
Offline slimydog
« Reply #39 on: Sun, 02 June 2019, 17:37:18 »
White with brass flippers is so clean.
Offline gregoryturtle
« Reply #40 on: Mon, 03 June 2019, 01:54:12 »
+1 I'm in just for this
+1 To ensuring bottom of keycaps are hidden (high profile case)
Loving this design, thanks for the hard work!
DZ60 | M60A LAKE | M60A KURO
Offline Dreem
« Reply #41 on: Wed, 12 June 2019, 16:48:44 »
I signed up just to say how hot and bothered this got me.
Offline Rayndalf
« Reply #42 on: Fri, 14 June 2019, 23:57:17 »
Agreed, this thing is really hot. Despite the apparent lack of interest I still think its going to be tough to get a spot... a lurker barrage seems pretty likely :p
Offline johnatzap
    • Zap Cables
Re: [IC] Bumper: a 60% keyboard case (Updated July 10)
« Reply #43 on: Wed, 10 July 2019, 16:41:23 »
We hope there is good interest! "Lurker Barrage" sounds like the name of an amazing pinball game, actually.
Offline eskimojo
    • KeycapLendar
« Reply #44 on: Wed, 10 July 2019, 18:05:20 »
I already have too many 60% and may have to prioritise, but i really do love how this looks  :)
Offline Azureshell
« Reply #45 on: Thu, 11 July 2019, 13:03:53 »
I guess I'm jumping on the bandwagon. I thought it was pretty cool, then I saw the polycarbonate brass and whoa.
You mentioned interchange flippers. Will there be options it buy multiple colors or is it just an opportunity for future versions?
Offline johnatzap
    • Zap Cables
« Reply #46 on: Thu, 11 July 2019, 14:58:28 »
There will be the option for additional sets of flippers, yes!
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #47 on: Fri, 12 July 2019, 05:17:32 »
Interested in polycarb+brass, and also interested to know what the typing feel/sound is like.
Offline IvarLJ
« Reply #48 on: Fri, 12 July 2019, 06:10:16 »
Also very interested on this design. Discord link on the latest update doesn’t seem to work, though.
Sent from my iPad using Tapatalk
Offline hottrout
  • I'd Hit Dat Key
« Reply #49 on: Fri, 12 July 2019, 07:56:41 »
You had me at polycarb + brass.
Seriously this is an superb design but I will say this again.  I don't want any more 60%.  Make it 66% at least, 70% or better still give us a full size in this design with ISO included.   There are enough 60% around.
If you were to make it 100% or even 100% - FKeys it would look very like the keyboard of the 1980 Memotech 512 computers.  You could have a black and red plates.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
