Author Topic: [IC] 7V - 75% Keyboard (GB Live!)  (Read 782139 times)
Offline gok_nz
  • Enjoy your PBT
    • Website
« on: Sun, 26 May 2019, 01:15:37 »
7V- designed by gok
0. CONTENTS
  • DETAILS
  • VENDORS
  • CURRENT STATUS
  • GALLERY
  • REQUESTED RENDERS
  • FAQ
  • SPECIAL THANKS
  • UPDATE SUMMARY
  • PHOTOS (In 2nd post. Includes link to build album)
1. DETAILS
  • Case Angle: 7.0°
  • Materials: Aluminium & stainless steel (PVD coated options)
  • Colours: Anodised Black, Grey, Dark Blue & E-white for the main chassis
  • Mounting method: Damped plate over wilba.tech leaf-spring PCB-mount
  • Plate: 1.5mm Polycarbonate with aluminium as an extra
  • PCB: WT75-C (non-hotswap) & USB-C daughterboard by Wilba- configurable with QMK/VIA
  • Weight: 2.6kg fully built
  • Layout options:
2. VENDORS
Price: $450 USD plus shipping for default kit (polycarbonate plate and polished stainless logo and weight)
Timeline: Group-buy starting 10th of April 2020 and will run for 3 weeks.
3. CURRENT STATUS
Group Buy is live. Waiting for the 3rd and final prototype.
4. GALLERY *note that finishes and colours shown in the renders aren't final
Blue anodised case with stainless steel weight & Enjoypbt 3000SAT
Expand below
Black anodised with black PVD weight & GMK Olive + SA Olivia
E-coat white with Enjoypbt Kuro/Shiro
5. REQUESTED RENDERS
GMK Wavez
Expand below
GMK Metropolis
GMK Dracula
GMK Serika
GMK Hammerhead (did this on grey rather than black because it looked better)
GMK Taro
GMK Modern Dolch
GMK Red Alert
GMK Mizu
GMK Striker
GMK Violet on Cream
GMK Vaporwave
GMK Calm Depths
GMK Violet Tendencies
GMK Black Lotus
GMK Bento (colours probably aren't accurate sorry)
IMSTO Black
SA Laser
GMK Dots
Enjoypbt SimpleJA
GMK Rudy
GMK Nord
GMK Red Samurai
GMK Handarbeit+
GMK Oblivion
SA Bliss
GMK Nines
GMK Peaches and Cream
GMK Denim
GMK Café
GMK Jamon
GMK Hero
GMK Voyage
GMK Hyperfuse Origins
GMK Phosphorous
GMK Olivia++
6. FAQ (PLEASE READ BEFORE ASKING QUESTIONS)
Why this layout?
I wanted to provide a similar amount of functionality that a TKL would bring but in a more compact form. Everything apart from the main alpha cluster has been separated to be able to navigate it easier but still be within easy reach. The top right corner has been blocked because I found that you had to move your hand a lot to be able to reach it (I would be using my index finger for this key). All separations are 0.25u for consistency.
Will there be a WKL blocker version?
I probably won't be adding this option for a few reasons. First is that the design is catered towards my personal preferences and I am a WK user and I don't want to deal with an SKU for the machining and lastly, I don't like the look of uneven blockers (Dixie did good with the Bauer layout).
Will there be a WKL 7u layout or 2x3u splitspace?
The layout below was considered but I opted not to include it because it messed up the footprints on the PCB due to the overlaps and I only want to provide one plate.
Likewise for splitspace - the 2 inner stab holes overlap the centre switch mount area on the PCB.
How about ISO?
As with the above, I've opted not to include ISO support because of how it messes with the footprints for ANSI and as selfish as it sounds, this a design that is tailored to my personal preferences and is optimised for that.
Will hotswap be available?
Sorry, only one type of PCB will be available due to its complexity and it would also split quantities which would affect pricing.
Why the gap between the top and bottom?
It is to avoid a standard butt-seam. In architecture, if there is a change in material, there is usually something to mediate between it which we call a negative detail or we'd use a trim. Also, I was aiming for a detail where the shadow line merges into the cutout for the USB port as per the below.
Will there be per key RGB or backlighting?
There won't be any RGB or backlighting provided. The only way to get backlighting would be to solder your own in-switch LEDS.
Can you do some more renders?
I stopped doing renders after deciding on which colours I want to offer. If you are wanting renders done of your keyset, you can ask Abec who I've sent render files of the 7V to.
Do you have a discord server?
I don't have the time to maintain a server but there is an unofficial channel dedicated to the 7V on the Daily Clack discord server here
7. SPECIAL THANKS
  • Thanks to janglad for teaching me how to use fusion
  • Wilba for providing feedback and for the PCB design
  • ai03 for bouncing ideas with me during the initial stages
  • kevinplus for helping me out with sourcing parts and being helpful in general
  • 001anthony for coming up with the layout that this was based on and
  • Minterly, T0mb3ry, Rensuya for providing me with the colour codes or vectors of their keysets
8. UPDATES
14/03/2020 - Timeline and pricing added to Vendors section
11/01/2020 - Final prototype ordered.
15/12/2019 - Photos of the latest prototype added. Status update
27/11/2019 - Vendors announced. Status update
30/10/2019 - Update regarding revised design
12/10/2019 - Prototype photos added
20/07/2019 - Added prototype progress shots and PCB photos
06/06/2019 - Prototype ordered
03/06/2019 - New Render Request renders added
31/05/2019 - New renders added to Request Renders section
29/05/2019 - Added a section for render request
« Last Edit: Sat, 11 April 2020, 19:09:20 by gok101 »
Offline gok_nz
  • Enjoy your PBT
    • Website
Re: [IC] 7V - 75% Keyboard
« Reply #1 on: Sun, 26 May 2019, 01:18:34 »
9. PHOTOS
**LINK TO THE BUILD ALBUM**
Really dark blue with raw polished stainless steel weight and logo - This won't be the blue colour for the production run
Black with black PVD stainless steel weight and logo.
E-White with raw  polished stainless steel weight and logo.
PCB
OLD PHOTOS
Some quick photos. These haven't been soldered and don't have stabilisers so some keys will be wonky, especially the spacebars.
Black with black PVD polished stainless steel weight and logo
PROTOTYPE PHOTOS (FACTORY PICS)
This blue is close to what I wanted but it had a lot of defects so they made a new bath in a different colour that they were going to use for a different client's production run.
Here are some potato pics from the factory. Free pixels included.
Also note that the screws in these photos are just to hold the parts in place for shipping. I've already got hex drive socket screws waiting at home.
Blue (won't be this colour for the GB) with stainless steel weight
PROTOTYPE PHOTOS (FROM OLD MANUFACTURER)
Logo straight off the CNC mill
Photo showing the fit. The logo will be remade to reduce the gap between the top and insert.
Testing out a dark grey anodised colour
« Last Edit: Sat, 28 March 2020, 14:56:59 by gok101 »
Offline nickaster1
« Reply #2 on: Sun, 26 May 2019, 01:19:53 »
Crossing fingers for a sub 400 price tag
Offline jaang
« Reply #3 on: Sun, 26 May 2019, 01:20:13 »
Oof, been seeing the teasers on instagram and love it! Would definitely be interested in this
Offline AlcoholEnthusiast
« Reply #4 on: Sun, 26 May 2019, 01:21:02 »
I'm not in love with the layout personally. That being said, I think the board/weight design is beautiful and looks really well done! Especially the E White/Black weight - that looks incredibly clean.
Offline snelltrail
« Reply #5 on: Sun, 26 May 2019, 01:21:32 »
Happy to see this come to IC! Looks really nice, will be following with interest :)
Also, yay for Designed in New Zealand! :P
Offline crd
  • Discord: crd#7617
« Reply #6 on: Sun, 26 May 2019, 01:21:33 »
My initial impression is that this looks very attractive and I am interested in learning more as it progresses
Offline Sycomore
« Reply #7 on: Sun, 26 May 2019, 01:22:22 »
That e-white is gorgeous. Tickle me curious
Offline Champalan
« Reply #8 on: Sun, 26 May 2019, 01:23:05 »
Been waiting for this. Count me in my guy!
Offline mdlt97
  • This **** is still better than Keebtalk
« Reply #9 on: Sun, 26 May 2019, 01:23:15 »
these are the nicest renders ive ever ****ing seen lol
boards looks nutty as well
TX60 | Duck TC-V3 | Duck Eagle V2 1/1 Bottom | Zephyr r2 | Duck Sidewinder | Mech27v2 | TX75 | LZ CLS | Duck Viper v2 | Orion v3 | HHKB pro 1 | TGR 910 | Omega60
Offline Eastji
  • draw 2 cards
« Reply #10 on: Sun, 26 May 2019, 01:24:41 »
Interested my dude!
Offline tootle
« Reply #11 on: Sun, 26 May 2019, 01:25:15 »
Very interested. That e-white looks great.
Offline gnhuy91
« Reply #12 on: Sun, 26 May 2019, 01:25:39 »
ne wkl blocker avail
Offline nulltorious
« Reply #13 on: Sun, 26 May 2019, 01:26:59 »
Amazing! I'm definitely interested! Been waiting for a while for this one :thumb:
Offline jaang
« Reply #14 on: Sun, 26 May 2019, 01:27:30 »
Would also be interested in WKL blockers if possible, still love the board however!
Offline tanvir175
« Reply #15 on: Sun, 26 May 2019, 01:33:10 »
Offline skrunk
« Reply #16 on: Sun, 26 May 2019, 01:34:25 »
I'm interested, but an option for a left winkey blocker and 7u space would make me even more interested...
Past Keyboards : LZ CLS, Unikorn, Noxary X65, KFE CE, HHKB Pro2, Realforce TKL
Current Keyboards: FC660C, HHKB Pro1, GSKT-00
Offline jariss
« Reply #17 on: Sun, 26 May 2019, 01:36:10 »
Yes please. Need some 7v.
Offline blizzara01
« Reply #18 on: Sun, 26 May 2019, 01:38:38 »
We neeeeeeeeeeeeeeeed it!!!!!
Offline neojonathan
« Reply #19 on: Sun, 26 May 2019, 01:39:00 »
Wow the design is awesome !! Hope this makes it into GB !
Offline wt5now
« Reply #20 on: Sun, 26 May 2019, 01:55:43 »
Good~~~~~~~~~~~~~~~!!!!!!! I'll absolutely in!!!
Offline vonswoopington
« Reply #21 on: Sun, 26 May 2019, 02:02:36 »
Very interested in that blue
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline Furikurichemy
« Reply #22 on: Sun, 26 May 2019, 02:12:51 »
Yes please!
Offline Esheu2
« Reply #23 on: Sun, 26 May 2019, 02:21:18 »
I keep looking at the badge and all I can think of is Louis Vuitton lmao.
Looks real nice tho. Might have to jump in.
Ojou
Offline PikaJoyce
« Reply #24 on: Sun, 26 May 2019, 02:27:02 »
The answer is yes.
I'd still love more details and continued updates to see where this project ultimately ends up.
Offline stoic-lemon
« Reply #25 on: Sun, 26 May 2019, 02:28:19 »
This is a stunner.
Offline Moridin
    • Infinite Diaries
« Reply #26 on: Sun, 26 May 2019, 02:51:48 »
Interested with a hot swap PCB.
Offline LuiKang
« Reply #27 on: Sun, 26 May 2019, 02:53:37 »
Beautiful design. The 7V logo looks great!
Offline TheMnBN
« Reply #28 on: Sun, 26 May 2019, 03:05:43 »
Love the weight design and 75% layout that has separate arrow cluster.
Looking forward to more details on mounting system and internal design.
Offline rondg
« Reply #29 on: Sun, 26 May 2019, 03:22:52 »
I am in! Keyset and case! YES!!!
Offline LuiKang
« Reply #30 on: Sun, 26 May 2019, 03:28:58 »
Would love to see WKL support.
Edit: Nvm now I've read the FAQ :)
« Last Edit: Sun, 26 May 2019, 04:00:35 by LuiKang »
Offline would?
  • Formerly wouldworks
    • Finder Works
« Reply #31 on: Sun, 26 May 2019, 03:48:51 »
You're insane Gok, i LOVE this
Offline PotatoTM
« Reply #32 on: Sun, 26 May 2019, 04:10:25 »
Really nice, curious to see the mounting method when revealed
Offline bobdenard
« Reply #33 on: Sun, 26 May 2019, 04:20:36 »
Looking great so far, love the layout personally! 2019 is definitely the year of the 75 :)
Offline lechapps
« Reply #34 on: Sun, 26 May 2019, 04:30:32 »
Really nice. I would be very interested in this if it gets to GB stage
Offline TuCZnak
« Reply #35 on: Sun, 26 May 2019, 05:32:39 »
Design is nice, layout not so much. Right side of bottom row looks kinda weird.
Also ne ISO avail
Offline KaosJ
« Reply #36 on: Sun, 26 May 2019, 05:36:22 »
I like it, the only question is: why the gap?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #37 on: Sun, 26 May 2019, 05:43:42 »
It's because I don't like butts seams. In architecture, if there is a change in material, there is usually something to mediate between it which we call a negative detail or we'd use a trim.
Offline gt1989
« Reply #38 on: Sun, 26 May 2019, 07:38:13 »
I'm definitely interested in this.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #39 on: Sun, 26 May 2019, 07:55:51 »
Just some of my initial thoughts.
  • Dig the logo alot. I think that looks quite nice.
  • Not so much a fan of offset arrow cluster, but can live with it. Not a breaking point.
  • I do think WKL with 1U left blocker and 7U spacebar will look really nice. Will be the first high end 75% to support left 1U blocker. I'll be your early supporter if that turns out to be the case.
  • Have you tried reaching out to Rama Foundry? I think they might be able to to help.
    Offline ilouis_07
    • Never Forget Your Origin
      • ILUMKB
    « Reply #40 on: Sun, 26 May 2019, 08:09:35 »
    I think that is chamfer
    Offline KaosJ
    « Reply #41 on: Sun, 26 May 2019, 08:14:46 »
    Make sense, keep it 1.25 1.25 1.25 6.25 1.5 1.5 please
    Offline OtherAndrew
    « Reply #42 on: Sun, 26 May 2019, 08:32:39 »
    nice layout
    6u space layout is cool
    Offline Krakyn
    « Reply #43 on: Sun, 26 May 2019, 08:32:56 »
    Not a fan of 75% layouts, but just wanted to pop in and say that the weight/backplate design is really nice.
    Offline 8six753o9
    « Reply #44 on: Sun, 26 May 2019, 08:44:35 »
    Yes please! I love the blue color.
    Offline Vigrith
    « Reply #45 on: Sun, 26 May 2019, 09:13:00 »
    The layout (the 125 125 125 625 15 15 version) is beautiful, the case is very nice, overall a great project honestly. I never like 75% boards, this is way better than the usual ways to approach it.
    Offline kgorin
    • Formerly aka_gk
    « Reply #46 on: Sun, 26 May 2019, 10:09:41 »
    Great, another 75%! 👏
    not a fan of the logo though, smh it reminds me of the Louis Vuitton logo, which I think downgrades the design a little bit 🤔
    « Reply #47 on: Sun, 26 May 2019, 10:12:12 »
    Great, another 75%!
    I was just typing this lol, looks golden on the weight but I think another key in that top corner would make this a fully endgame board, why waste a spot where a key could go with branding
    Offline moh18one
    « Reply #48 on: Sun, 26 May 2019, 10:20:08 »
    It looks f***ing good even if I prefer 6 degree (or less) cases
    However, If your keyboard supports 6U spacebar, why not 2*3U?
    Offline apexshikari
    « Reply #49 on: Sun, 26 May 2019, 10:41:08 »
    Perfect very much. The blue is just gorgeous. Count me in even if this turns into a private gb.
