Author Topic: [IC] Treasure Type-9 ( Series II ) - USB-C HotSwap 9 keys metal macropad.  (Read 92771 times)
Offline Treasure
  • Industrial Designer / Inventor / Maker
    • Design & Eng
TREASURE TYPE-9 ( SERIES II )
Hello to all,
I am is Eric from Treasure, Industrial Designer from France ( https://www.instagram.com/treasuretypes/ ).
This new project is the follow up of my first macropad keyboard of last year ( Macropad Type-9 :  https://geekhack.org/index.php?topic=91252.0 & macropad.co), in a new and improved version.
Treasure Type-9 is stylish metal macropad keyboard with a lot of keys in the smallest form factor.
On the technical side, the Treasure Type-9 ( Series II ) is now enterly solderless, as it have Kailh hot swap stockets and smd leds already on the PCB.
The kit will be sold with 9 DSA keycaps, a travel case and an USB Type-C to A cable; so you just have to bring your keyswitches !
The aim of this interest check is to find how many people are interested, and discuss about color / finish options.
GROUP BUY IS NOW LIVE : https://treasuretypes.com
Specifications :
  • No soldering at all
  • USB Type-C Connection
  • Kailh hot swap sockets
  • PCB leds
  • Plate for easy mount, for all kind of keyswitches
  • Low Profile custom silicone pads
  • Pre-Assembled PCB with Microcontroller
  • Powder coated case / mirror finish
In the kit, you will find :
  • 1 Unibody CNC aluminum or brass case
  • 1 Pre-Assembled PCB with Kailh hot swap sockets + SMD leds
  • 1 custom metal plate
  • 1 USB Type-C cable
  • 9 Custom DSA Keycaps
  • 9 Keyswitches (Optional)
  • 1 Travel Case (Optional)
Color options - Renders ( Subject to change ) :
Back of the Treasure Type-9 with the silicone feets
Updates:
28-May-2019 :   Initial Post
01-July-2019 :  Plate prototype ( pic )
23-July-2019 :  White version prototype (pic)
28-October-2019 : Project Update and PCB assembly Prototype
13-November-2019 : Full assembly
20-February-2020 : Raw material machining for mirror versions ( Chrome / Black mirror )
04 -March-2020 : Mirror polish done
12-March-2020 : PVD Coating Done
Feel free to comment on the project !
https://www.instagram.com/treasuretreasure.co/
Eric
« Last Edit: Sat, 24 October 2020, 14:02:49 by EricArts »
Offline Treasure
    • Design & Eng
Reserved
Offline Treasure
    • Design & Eng
Reserved
Offline lolafineday
Maybe ambitious but Bluetooth capability would be sick
Sent from my SM-G975F using Tapatalk
Offline indiceiris
will you allow purchasing of just a pcb and plate for people with series I?
Offline sickbabies
Yes! I need a little hotswap numpad to go with my Prime_e once it comes
Offline infinitykw
  • Amazed by the beauty of industrial design
    • zFrontier Profile
Def interested!!! Is it possible to add Bluetooth?
Offline jariss
+1 for bluetooth. Would seal the deal.
Offline Treasure
    • Design & Eng
Hello, no plans to add bluetooth
Yes it will definitively be an option
Offline resurrexia
Would love mirrored rose gold, if colours are still up for debate.
Offline Windeh
  • a no name
Having purchased the original Type-9, it was an awesome little macropad with amazing quality, and I feel somewhat underrated in the community.
Great to see most of the suggestions from the community implemented into Series II.  :thumb:
For the polished Stainless Steel versions, what are the steel grade you'll be specifying? And is there any coating on the chrome version?
Offline uood5
Would rotary encoder support be an option? Would love a BDN9 with an alu case, and that would fit the bill just right
Offline dr_unconscionable
    • [sqeleton]
Interested, depending on final pricing :)
Offline Treasure
    • Design & Eng
Thanks for the support Windeh, i am glad you liked the original version :thumb:. It was a very limited run
Concerning stainless steel grade and coating, i am currently in discussion in this regard with the supplier, I will have the answer next week.
Ok great, final pricing will depend on quantity, i will keep you informed.
Hello uood5, no rotatory encoder option is planned for this product.
Regards,
Eric
Offline Corgiattackkk
Filled out the interest check form! Would definitely be in for 2 when this drops <3.
Offline LXVRGS
Black mirror would be cool filled out the form
Offline thornkin
What is programmability like on this? QMK?
Sent from my SM-G973U using Tapatalk
Offline Treasure
    • Design & Eng
Yes it is QMK compatible
Offline Jackorias
  • Jack, UK.
Filled out the form. Would definitely be interested in the mirrored black or nardo grey!
Offline Treasure
    • Design & Eng
Hello to all.
The Case samples are on their way. I will post photos once i recieve them !
Offline ZG2047
J'aime bien c'est jolie . La fourchette de prix ?
« Last Edit: Thu, 20 June 2019, 18:05:58 by ZG2047 »
Offline EMC Labs
Very nice!
Offline amuri99
good maybe useful! wish it
Offline Treasure
    • Design & Eng
Thanks  ;)
Price will depend on quantity. Interest check is still on progress.
Offline Treasure
    • Design & Eng
I just recieved a picture of the plate prototype.
The case will come later
Offline amuri99
i need it
Thanks for the update! Looking forward to seeing the completed macropad & the GB <3
Offline Treasure
    • Design & Eng
Hello To all.
Quick update : The PCB design is done ( Backlight + Hotswap + USB-C + 9 keys )
Offline hottrout
  • I'd Hit Dat Key
bluetooth would make this a must buy.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline baoduy23
just wonder smd leds is not RGB right?
Offline Treasure
    • Design & Eng
Hello,
Yes, I choose single color led to keep the PCB as small as possible for 9 keys.
Offline Treasure
    • Design & Eng
Case Proto
Offline Choobies
That looks great!  Is that the Nardo Grey?
Offline travwal
Case Proto
Looks awesome! Thanks for the update.
Are you waiting on any more prototype colors?
Offline Treasure
    • Design & Eng
Hello,
Thanks
Yes i am waiting for the shiny / chrome one
Offline Treasure
    • Design & Eng
With the metal plate and Kailh Box Heavy Yellow switches
Offline indiceiris
excited for gb, looking forward to buying plate+pcb !
Offline antx1701
Even though it doesn't match anything in my setup, I'm definitely in if it's below $100.
Offline voight-kampff
Re: [IC] Treasure Type-9 ( Series II ) - USB-C HotSwap 9 keys metal macropad.
« Reply #38 on: Thu, 08 August 2019, 08:27:23 »
Can't wait for this
Sent from my MIX using Tapatalk
« Reply #39 on: Thu, 08 August 2019, 08:28:08 »
I would just need a 60 or 65%keyboard in stainless steel also
Offline bricra1983
« Reply #40 on: Fri, 16 August 2019, 14:38:50 »
This is a great little thing.  Love it.
Offline Karni
« Reply #41 on: Sun, 08 September 2019, 14:24:22 »
just found this little beauty, any updates?
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #42 on: Tue, 24 September 2019, 17:17:05 »
Very interested.
But have never joined a group buy before.
Do you only sell in larger quantity?
Offline wmc123
« Reply #43 on: Wed, 25 September 2019, 01:23:01 »
Any chance the same red as the previous model will be back?
« Reply #44 on: Wed, 25 September 2019, 08:28:01 »
is this dead?
Offline indiceiris
« Reply #45 on: Thu, 17 October 2019, 20:06:16 »
ne updates
Offline Treasure
    • Design & Eng
« Reply #46 on: Mon, 28 October 2019, 06:52:51 »
At the moment there is no plans to sell it again
Hello to all,
I just recieved the PCB pre-production model.
and I am reviewing the cases prototypes from different suppliers
Same for the Packaging and assembly PCB.
Update : For the case it will most likely be PVD Finish Brass instead of Stainless Steel.
I will keep you updated for the definitive material choice
Eric
Treasure
Offline Deadboy
  • I have a bad feeling about this.
    • KN1GHT
« Reply #47 on: Fri, 01 November 2019, 09:07:20 »
Oh my, i need this. I've been looking for something like this.
Offline Treasure
    • Design & Eng
« Reply #48 on: Wed, 13 November 2019, 15:21:14 »
Hello to all
Series II prototype with White smd leds, white keycap and white case
Offline Choobies
« Reply #49 on: Mon, 18 November 2019, 08:54:06 »
It looks so nice!  Excited for this.  Which finish is that?
