Author Topic: Frosted acrylic case for KBD75v2 PCB  (Read 2442 times)
Offline chakkii
« on: Wed, 29 May 2019, 22:59:11 »
Hey, do any of you know if there is a 75% frosted acrylic case which will the the KBD75v2 PCB?
Only found one on aliexpress called YMDK 84 but it’s more a low profile case and I also don’t know if it will fit or not :P at least the usb connector seems to be in the right position.
Do you guys know any alternative? Or a case with "higher“ profile? As high as the original case.
Would appreciate the help :)
Offline Sup
Re: Frosted acrylic case for KBD75v2 PCB
« Reply #1 on: Thu, 30 May 2019, 07:47:00 »
As of today 0 cases expect that low profile one and i am pretty sure i read somewhere it's compatible KBD75 PCB.
current
Coming soon
Offline chakkii
« Reply #2 on: Thu, 30 May 2019, 14:47:51 »
Too bad :(
But thanks for the help, I’ve messaged the seller and let’s see if it’s compatible :)
