Author Topic: [GB] GMK Olive | Closed!  (Read 118204 times)
Offline ramblinrose
Re: [GB] GMK Olive | Closed!
« Reply #150 on: Tue, 04 February 2020, 08:00:14 »
Got mine in as well - very clean set!
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #151 on: Thu, 06 February 2020, 13:46:36 »
Here it is on a 75%
235277-0
Offline pixelpusher
« Reply #152 on: Sat, 08 February 2020, 14:52:55 »
60% group here
235377-0
Offline higgga
« Reply #153 on: Sun, 23 February 2020, 19:33:14 »
Does anybody else have an issue with twisted stems?  Here are some of the more worse ones on mine.  A ton of the other caps are twisted as well, but less so and harder to take picture of.  GMK 3run for comparison.
https://imgur.com/a/UrThTCB
@mgsicker  Maybe something to tell GMK to check so it doesn't happen to other sets?
Offline gridds
« Reply #154 on: Sun, 23 February 2020, 20:07:25 »
You are not alone, seeing similar results.
Offline chits
« Reply #155 on: Sun, 23 February 2020, 20:39:27 »
I am as well.
Offline pixelpusher
« Reply #156 on: Sun, 23 February 2020, 20:53:14 »
Didn't notice it, but from my photo you can see the W and U look a bit off.  Same keys look off in your photos. I can't tell when it's in front of my and i'm typing though, only if I lean over the board and look from straight above.
« Last Edit: Sun, 23 February 2020, 21:01:38 by pixelpusher »
Offline NimbleTortoise
« Reply #157 on: Mon, 24 February 2020, 07:01:04 »
That's why I sold mine, though I was also disappointed in the color matching. $140 for a gmk set and GMK cannot even get the keycaps to be straight. My spacebar was also somewhat warped.
Offline Poesjuh
« Reply #158 on: Mon, 24 February 2020, 07:17:38 »
Same here. I noticed it a few days ago that some of the caps looked a bit off and was wondering if that might have been soldering. I'll take another look tonight when I'm home but good chance I'm encountering the same problem.
Edit; checked, have the same issue. It's mostly (if not only) on R2 though, so that surprised me.
« Last Edit: Mon, 24 February 2020, 15:01:53 by Poesjuh »
Offline Zeelobby
« Reply #159 on: Mon, 24 February 2020, 08:30:23 »
This is my concern with the massive backlog they have. Feel like their QC has dropped significantly.
Offline stevenT
« Reply #160 on: Wed, 26 February 2020, 03:53:00 »
Not only W and U but that whole row looks off, also left shift is a bit weird or was it angle of camera?
« Reply #161 on: Wed, 26 February 2020, 05:11:25 »
From what I remember, the I, Y, and U were really off. Some keycaps below that wrre crooked as well, though not as bad.
Also gmk really needs to work on the numbers legends. None of them look like they're on the same plane and too much thickness inconsistencies.
Offline Poesjuh
« Reply #162 on: Wed, 26 February 2020, 11:25:59 »
Some pictures. Last 2 are Olive only, first 2 with some minimal caps in between.
Offline higgga
« Reply #163 on: Sun, 08 March 2020, 22:07:52 »
I agree that the legends are not great on this as well.  Even before I saw this comment I noticed that the ? looks skinny and the shift is Shift.
« Reply #164 on: Mon, 13 April 2020, 12:37:05 »
Do all sets have issues with twisted stems on some keys? I just ordered this set and didn't see this thread beforehand.
Offline pixelpusher
« Reply #165 on: Mon, 13 April 2020, 13:25:56 »
Most likely, yes.  This also probably effects most GMK sets that have run since olive as well. It really isn’t that noticeable.  People are expecting too much from these plastic bits.  I have seen slight inconsistencies in almost every finished keyboard I own.  You can have issues with keycaps,  switches sometimes have slightly crooked stems, and it is also possible to have slightly rotated switches when using plate mounted switches instead of PCB mounted.  So many variables.  Don’t get too caught up in perfection.  The set is still quite nice.
« Last Edit: Mon, 13 April 2020, 13:28:19 by pixelpusher »
Offline Poesjuh
« Reply #166 on: Mon, 13 April 2020, 16:58:41 »
The twisted stems on my set are 100% noticeable.
Offline oldcat
  • 65% is Life
« Reply #167 on: Mon, 13 April 2020, 17:13:12 »
+1
« Reply #168 on: Tue, 14 April 2020, 16:15:38 »
I guess this is all subjective. I don't mind slightly imperfect legends. But the crooked thing is very easy to notice. Symmetry seems to be a key thing our brains lock on to.
Offline chowder266
« Reply #169 on: Wed, 02 September 2020, 23:00:34 »
Anyone know why the rama cap says RAMA x Olivia and not RAMA x Olive?
Offline Lastpadawan
  • Product design team and Vendor | LastPadawan.Store
    • LastPadawan Store
« Reply #170 on: Wed, 02 September 2020, 23:23:30 »
Definitely hoping I can grab a set of these at some point, I really like the color choices.
Offline pixelpusher
« Reply #171 on: Wed, 02 September 2020, 23:33:08 »
Olivia is the designer of the set.
Offline chowder266
« Reply #172 on: Thu, 03 September 2020, 00:14:24 »
I know, but just historically the engravings for rama keycaps are named after the set, not the designer.
Offline Donnie
« Reply #173 on: Fri, 06 November 2020, 21:17:34 »
Sooo... when's r2? :D
Offline deetits
« Reply #174 on: Sat, 07 November 2020, 00:37:09 »
Second that, need R2.
Sent from my Pixel 4 XL using Tapatalk
Offline IOVERCALLHISTIOCYTES
« Reply #175 on: Sat, 07 November 2020, 00:38:04 »
R2, green alphas kit, more nolives
Offline productkun
« Reply #176 on: Sat, 07 November 2020, 17:55:10 »
Olive++? hmmm
Offline jack.yijugu
« Reply #177 on: Tue, 20 April 2021, 02:57:13 »
Want R2!!!!!!
Offline jack.yijugu
« Reply #178 on: Tue, 20 April 2021, 19:56:30 »
R2.....
Offline silverstreakz
« Reply #179 on: Wed, 28 April 2021, 19:05:22 »
Pls run a R2!! Pretty please....
Offline thechemtrailkid
« Reply #180 on: Fri, 30 April 2021, 13:37:55 »
R2 indeed
Offline WiseLucas
« Reply #181 on: Fri, 30 April 2021, 14:24:13 »
+1 for r2
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #182 on: Sat, 01 May 2021, 04:45:24 »
Damn I didn't know 40% kits had a 1.75 enter these days. Need to get one of those.
Offline Seano
« Reply #183 on: Wed, 15 December 2021, 22:23:27 »
R2 secured, shame there's no signature image
