Author Topic: How to remove keycap from space bar on Bloody B930  (Read 12983 times)
Offline trybik123
« on: Mon, 03 June 2019, 08:39:27 »
Hello,
does anybody know how to remove a keycap from the space bar on Bloody B930?
It seems like I can't do that from the outside like on other keyboards with Cherry switches.
Other keycaps are removable like on Cherry, only the space bar is attached to something.
https://www.bloody.com/en/product.php?pid=11&id=207
Offline Auxo
  • Formerly CJD_Anthony
Re: How to remove keycap from space bar on Bloody B930
« Reply #1 on: Thu, 06 June 2019, 21:29:10 »
If you can get some close up pix of your board, that would be helpful. I've never heard of this brand
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #2 on: Fri, 07 June 2019, 09:28:13 »
Bloody is a keyboard company that makes optical switch boards.
Their keyboards are recognized by the bloody hand on them. Whats unique about these keyboards is that you can set an actuation point for macros and customize the switch itself.
Just my thoughts
Offline Warrenified
« Reply #3 on: Sat, 08 June 2019, 17:00:36 »
I use two wire keycap pullers like these: https://www.amazon.com/WASD-Keyboards-Wire-Keycap-Puller/dp/B00AZCGF7K
Worst case you can pull out your bottom row modifier caps and use your two index fingers to lift from the bottom of the sides of the cap upward. Make sure to pull upward and not at an angle. I don't recommend doing this method since you can ruin your cap, but if you don't want to spend the money, it is an option.
Offline Goodman74
« Reply #4 on: Sun, 14 February 2021, 15:31:32 »
!!! Bloody spacebar attached It by two screws from opposite side.
Remove it before lift spacebar
Offline Rx003
« Reply #5 on: Fri, 19 February 2021, 01:51:50 »
First time hearing this board maybe you can enlighten us more with a couple of pics? Hope you get sorted this out well if ever!
