Author Topic: Help me choose my next keyboard  (Read 2182 times)
Offline senencito1
« on: Mon, 03 June 2019, 09:44:35 »
I want to replacemy work keyboard and I'm stumped on what direction to take.
My current setup is
Home - massdrop ctrl with halo trues. I really dig this setup and wouldn't mind going even smaller with something like the Alt. The halo trues feel real nice and wouldn't mind staying with similar switches. Smallest I would go is something with arrows keys, I use these a lot.
Work - ducky one 2 white with cherry blues. I don't love blues as much as I expected. Before this one I had a ducky one 2 with cherry Browns which I liked better.
https://imgur.com/a/zvrTk6H/ photos of my keyboards here
I need a numpad and layout for work as I do quite a lot of sql programming and data analytics with accountants. At home I do mostly photo editing and writing so I prefer a smaller layout.
A coworker has offered to buy the ducky for almost wait I paid for so that part is easy.
I also have a set of wavez keycaps on the way and some switches left over (kailh speed silver) so it need be I can buy barebones.
Here's some ideas I have :
1.Buy a massdrop alt and a numpad. Move the ctrl to the office with the numpad.
2.Buy the massdrop shift and wait till January, the 1800 layout is quite nice .
3.Wait for the ducky wireless keyboard and buy it when it becomes available.
I'm trying to move everything to usb-c so I won't consider micro USB boards.
What do you all think?
Offline nelamvr6
Re: Help me choose my next keyboard
« Reply #1 on: Mon, 03 June 2019, 11:03:29 »
Since you want a full size keyboard, and your coworkers are OK with clicky switches, the answer is obvious: IBM Model M.
Keychron Q6 w/ Zeal Clickiez | IBM Model F AT | Leopold FC660C | HHKB Type S
Offline senencito1
« Reply #2 on: Mon, 03 June 2019, 12:48:10 »
OH man. I've never tried one of those. Hadn't even considered
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #3 on: Mon, 03 June 2019, 14:05:50 »
If you can restore the beamsprings on the IBM Beamspring, its challenging but quite worth it.
Just my thoughts
Offline nelamvr6
« Reply #4 on: Mon, 03 June 2019, 14:11:28 »
A beamspring would be amazing, but they are a lot harder to get, more expensive, harder to convert to be able to talk to a modern computer.
Plus, the Model M has the instantly recognizable layout that would take zero time to get used to...
Offline swedishpiehole
« Reply #5 on: Mon, 03 June 2019, 15:29:31 »
My thoughts exactly.
Offline Sintpinty
    • My Roblox Profile
« Reply #6 on: Mon, 03 June 2019, 20:17:54 »
Yep, i would reccomend the Ibm Model M over the Beamspring because it's easy to restore.
Just my thoughts
