Author Topic: [IC] ASK55 - Alps 14.5u Keyboard (Photos & Pre-Launch IC)  (Read 62630 times)
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: [IC] ASK55 - Alps 14.5u Keyboard
« Reply #50 on: Sun, 04 August 2019, 12:23:09 »
I don't know what an 8x14.5u Apple layout is.  Can you post a layout image?
Oh, okay I see.  I had no idea the space bar was that crazy on the M0116.  Does it feel janky?
The M0116 is my favourite layout of all time. Because the spacebar isn't ridiculously long, it's actually pretty well stabilised!
I'll update the original post to make the layouts clear. Thank you!
I had the opposite experience with the spacebar on a M0116. I got a really clean one for a good price awhile back, so I originally planned to just use it as is. Well the spacebar on it absolutely killed it for me,
Because of the switch being offset so far to the right on the spacebar it would bind like crazy & always come back to rest crooked AF. I tried lubing the stabilizers/post & even went as far as hot gluing the wire holders into the plate cause I thought the left one might have been popping out with no luck. Just a bad design choice to put the switch where they did & unfortunately there is not much that can be done to fix that IME. What really kills me is the cap has a post for a centered switch which would have made the spacebar work perfectly.
Anyways, enough about that damned spacebar LOL! I really like this board design you've come up with & will hopefully be joining since I have a batch of very clean SKCM Oranges from my aforementioned M0116 that need a good home. Question though, will you be able to use the M0116s spacebar on a centered switch with this kit? I also like the size of it & think if it was on a centered switch all the problems I had with it on the offset switch will go away.
Bummer that you're not having a good time with it! The only thing I don't like is how they're ABS  :mad: But there may be something in the pipeline for this...
As for using the centre stem: I've just checked versus the PCB and it doesn't support the use of the centre stem. However, with a bit of wire you'd be able to conjure something if you were set on it! That said, the plate is also built with the use of the right-hand stem in mind but it wouldn't be too hard to move!
Thanks for checking it out & the quick response! Kinda a bummer, but like you said if I am determined to get the switch in the center with a M0116 spacebar it is definitely possible with a little planning & elbow grease. Actually who knows being able to build the board myself may allow me to get the offset switch setup working properly. While it was a frustrating experience it probably was more to do with my specific M0116 &/or it's spacebar than the overall design, since the binding I experienced doesn't seem to be be a common complaint with them. Still very interested in the ASK55 either way!
As for the original M0116, AEK, AEKII, etc. spacebars, I agree them being ABS vs all the other old apple caps being PBT is pain. I managed to snag a pretty white AEK spacebar from the guy on e-bay that sells old apple caps, but one of the posts that hold the stab guide is cracked. Then I haven't had much luck retrobrighting any of the yellowed ones I got, so I am most certainly intrigued by the little nugget you dropped about something possibly being in the works about that too!
« Last Edit: Sun, 04 August 2019, 12:25:04 by Rob27shred »
Offline pizza_is_a_lie
  • ISO Master Race
Re: [IC] ASK55 - Alps 14.5u Keyboard (NEW RENDERS)
« Reply #51 on: Sun, 11 August 2019, 15:50:48 »
Nothing major to report over the last week. Manufacturer one is still working on their protos; I'll be placing an order with manufacturer two this week (pending some more funds).
  • ISO Master Race
« Reply #52 on: Mon, 19 August 2019, 14:17:45 »
As you may be aware, we're working with two manufacturers on our last prototype revision. We've requested prototypes of our cases in UV/scratch resistant frosted polycarbonate and 6063 grey aluminium.
Manufacturer one is pricier than manufacturer two. However, their track record is phenomenal; they are the go-to manufacturer for very premium, very special boards. They know the community and they have a very keen eye for detail.
Manufacturer two is less costly. I don't believe that they are as privy to the community though they have worked with a good number of designers and produced successful and desirable boards.
Why am I telling you this?
I'm a sucker for perfection. I set out to deliver a product that I would, first and foremost, be proud to own myself. With this in mind, I've received the prototypes from manufacturer one today and they are bang on the money. They're gorgeous. Flawless, even. I can't fathom how delectable they are. They blow all of the the previous prototypes out of the park.
But, I'm eager to see if a cheaper manufacturer can deliver a product that rivals this quality. So, once I receive the prototypes from manufacturer two, I'll compare them versus the prototypes from manufacturer one in order to decide who we proceed with. I'll share my reasons and justifications. I'd hate to price people out of it however quality is my top priority.
Once this is done, we'll get some glamour shots prepared and then... then we can get hyped!   :D
Offline yui_
« Reply #53 on: Tue, 20 August 2019, 01:29:10 »
You're the designer, and it's your product. I know you'll make the best decision in the end!
So excited for this one!  :thumb:
  • ISO Master Race
« Reply #54 on: Fri, 06 September 2019, 16:28:33 »
Very brief update:
  • Awaiting manufacturer 2's prototypes, in manufacture now
  • New revamped website will go live once manu 2's prototypes arrive
We're not done... we've not even started!  :p
« Last Edit: Sat, 07 September 2019, 11:27:05 by pizza_is_a_lie »
Offline EMC Labs
« Reply #55 on: Fri, 06 September 2019, 19:58:12 »
Very brief update:
Great to hear about the updates.
Offline dom
  • allergic to hypocrisy
« Reply #56 on: Wed, 11 September 2019, 14:17:57 »
Take your time, make it perfect and we'll follow ;)
6063 aluminium sounds perfect ;D and, as a fanboy, I can't wait to see the prototypes, to be honest!
  • ISO Master Race
« Reply #57 on: Fri, 20 September 2019, 11:30:17 »
Thank you for the feedback!
I bring news. The second (cheaper) manufacturer is sending two consignments after missing half of the protos off the first delivery. I've received the first consignment today. First impressions are OK. They're clearly not as good as our more expensive option; they have a few scratches on non-outside edges which I'm not too impressed with. The delivery mess-up doesn't fill me with hope either.
However, I'll await the second consignment before I get some pictures out and come to a decision. Though, early indication would be that I'd be more satisfied with a better quality finish which our first manufacturer has proven that they can deliver.
Offline Jampot_298
« Reply #58 on: Sat, 21 September 2019, 05:18:43 »
Great news! Can't wait!
I'm not sure how other people feel but personally I'd be willing to pay a bit extra in order to have a better quality final product, so I'd be happier with manu 1
Sent from my ONEPLUS A6003 using Tapatalk
Offline dom
« Reply #59 on: Sat, 21 September 2019, 06:16:55 »
Same
  • ISO Master Race
« Reply #60 on: Sat, 21 September 2019, 22:08:59 »
Same
Yeah, it's crossed my mind. I am conscious of the price though I am a sucker for the crème de la crème. I wouldn't be happy with something which wasn't perfect. We'll know more in a week or so. Manu 2, the cheaper manu, have asked for some pictures and details so we'll see what comes of that too.
Offline Jampot_298
« Reply #61 on: Sun, 22 September 2019, 05:03:03 »
Great! Sounds like you're on it! I'm also a sucker for perfection and Im really into boards with small details to appreciate. Thanks for keeping us updated!
Offline sendpie
« Reply #62 on: Sun, 06 October 2019, 04:56:51 »
any minor updates ?
  • ISO Master Race
« Reply #63 on: Mon, 14 October 2019, 11:44:13 »
any minor updates ?
I recognise that it's been a while; I've been caught up with quite a few things out in the real world.
I'm still tasked with liaising with the cheaper manu to see if there's any resolution to their imperfections. Otherwise, we'll crack on with manufacturer one.
Offline Jampot_298
« Reply #64 on: Mon, 14 October 2019, 11:52:40 »
any minor updates ?
Epic! Sounds great, I can't wait for this!
Offline yui_
« Reply #65 on: Sun, 20 October 2019, 15:51:10 »
Are there currently any plans for a wider selection of plate materials? I would personally love for carbon fibre to be offered.
Offline Jampot_298
« Reply #66 on: Sun, 20 October 2019, 16:16:25 »
Same I'd love to know as well!
Offline jrs
« Reply #67 on: Sat, 26 October 2019, 02:05:15 »
When is this running, and how much will it cost?
  • ISO Master Race
« Reply #68 on: Mon, 11 November 2019, 08:53:05 »
Hey guys, apologies for the lack of updates. Work has been crazy plus me and my better half have just bought a puppy! So, time is a bit here-there.
Keep peeled.  :cool:
Offline Chesebro
« Reply #69 on: Mon, 11 November 2019, 11:21:49 »
Looks great! Cant wait for more updates :)
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #70 on: Tue, 12 November 2019, 23:41:28 »
I'm pretty excited for this. Can't wait! (But I can wait till after December since these next few months are looking pretty expensive at the moment  :p)
Offline Jampot_298
« Reply #71 on: Wed, 13 November 2019, 02:22:31 »
Yep same dude! Im trying to manage my finances properly as well so I can afford this lovely board!
Offline Cods
  • Penumbra SA Mark II please?
« Reply #72 on: Wed, 13 November 2019, 07:51:30 »
I bought a donor (U/S) AEK and Alps keycaps and switches just for this. Sweet.
Model M Industrial, SSK, Unicomp 104, Code TKL MX Green, FC660M MX Green + Clear + White + Grey, FC660C Topre 45g, MagicForce 68 USB and Bluetooth, Whitefox, some optical switch 65% Bluetooth split spacebar thing ... wait, I think I need an intervention. Too late, there’s a couple of new Model Fs on the way.
Too much SA is never enough.
Offline djeucalyptus
« Reply #73 on: Thu, 14 November 2019, 13:16:32 »
Still so excited for this... can't wait! And can't decide which keyset(s) to build this for. So many choices! I'm loving it. And can wait as long as needed to make it happen! (Also, where's the puppy photo?!?)
« Last Edit: Thu, 14 November 2019, 13:18:11 by djeucalyptus »
  • ISO Master Race
« Reply #74 on: Sun, 01 December 2019, 14:39:36 »
I'll get the project rolling again this month with some anticipated dates and better pricing after the Christmas period :thumb:!
Because of the expected low volume (compared to other, more in-demand group buys) and the quality we strive to deliver, it will impact the price. We endeavour to ensure that our cases cost between $350 and $550, depending on chosen options/materials. We'll know more when I get quotes re-validated.
Instead, for now, how about a fresh new website?  :cool:
Offline sendpie
« Reply #75 on: Mon, 02 December 2019, 07:36:12 »
sweet ! thank you for the updates, its been awhile  :)
  • ISO Master Race
« Reply #76 on: Thu, 02 January 2020, 02:43:19 »
Happy new year!
Not forgotten, guys. Don't worry. Though, Brexit is looming so I'll update you if things change on the EU shipping front.
I'll also get an interest check form out to ensure that we can hit the MOQs we require.
 :thumb:
  • ISO Master Race
Re: [IC] ASK55 - Alps 14.5u Keyboard (PROTO PHOTOS)
« Reply #77 on: Thu, 02 January 2020, 16:33:53 »
It's late and I'm getting nagged in to bed. However, we have proto photos!
https://paradigm.parts/projects/ask55
Offline gnhuy91
« Reply #78 on: Thu, 02 January 2020, 20:26:59 »
sexy! love the clear pc build
  • ISO Master Race
Re: [IC] ASK55 - Alps 14.5u Keyboard (NEW IC & PHOTOS)
« Reply #79 on: Fri, 03 January 2020, 08:00:43 »
Pre-launch IC is now UP! Please make sure you register your interest so we can accurately gauge numbers ready for a February launch!
Cheers for the kind words :D I can't emphasise how tidy it really is.
« Last Edit: Fri, 03 January 2020, 08:25:46 by pizza_is_a_lie »
Offline mode
« Reply #80 on: Sat, 04 January 2020, 18:18:33 »
I'm surprised, my M0116 doesn't bind on the spacebar at all, and it's not the cleanest example of an M0116 and I've not gotten around to cleaning it properly.
Offline mounds
  • Builder of things and stuff
    • The Mounds Abides
« Reply #81 on: Sat, 04 January 2020, 21:34:01 »
Do we have any price estimates as of yet?
I'm really reluctant to release anything before receiving the prototypes but I understand that price is important. What I will share is that, at lowest MOQ, the sets will price between $325 and $475 depending on materials. This includes all fees etc except postage.
I will add that I'm working with a manufacturer who is absolutely at the top of the tree when it comes to workmanship and our prototypes will affirm this  :thumb:
Rough, but still interested in PCB + plates if anything.
Tada68 (Jailhouse Aristotles) / MiniVan (Jailhouse Aristotles) / Planck (Aristotles) / Teensy m0116 (Matias QC) / ALPS64 ('Pine' SKCM White) / Teensy NeXT Non-ADB (SKCM Cream) / ALPS HHKB (SKCM Orange)
  • ISO Master Race
Re: [IC] ASK55 - Alps 14.5u Keyboard (Photos & Pre-Launch IC)
« Reply #82 on: Sun, 05 January 2020, 15:11:57 »
I wonder if the stabs are different based on year/country of manufacture? Maybe slightly different tolerances or something? Not too sure. Much like you, my experience has always been really good  :D
I know how you feel, bud. I really did fight for some cheaper manus but their quality just isn't all that  :-[ This manu is the real deal though, rest assured.
Case aside, the plates are flawless and the PCB works a treat too  :thumb:
Offline gnhuy91
« Reply #83 on: Thu, 23 January 2020, 00:52:54 »
are we still on track for Feb launch?
Offline meatsmoothies
  • howdy!
    • portfolio / store
« Reply #84 on: Mon, 09 March 2020, 20:14:53 »
super excited to see this happen, just found out about this :p
Offline monteyalps
« Reply #85 on: Tue, 10 March 2020, 10:10:20 »
This is a must buy for me, I've got several sets of M0116 keycaps sitting in my office..
Hype!
Offline Cods
« Reply #86 on: Thu, 09 April 2020, 19:43:50 »
Super keen for my first Alps build.
Offline ZyBeR
« Reply #87 on: Tue, 28 April 2020, 16:54:18 »
Any ETA for the GB?
Offline toniwonkanobi
« Reply #88 on: Wed, 22 July 2020, 07:18:03 »
Any ETA for the GB?
Yeah! I'd like to know too :)
Offline Cods
« Reply #89 on: Wed, 05 August 2020, 17:07:18 »
Hey @pizza_is_a_lie - just checking that this is (as per your web page) still alive, but just sleeping for the moment. Very keen!
« Reply #90 on: Mon, 05 October 2020, 08:32:59 »
Same here—very interested in this project. This is the only ~60% project I'm aware of which accommodates the NeXT non-ADB (AAE) ANSI layout. I've pinged the proprietor a couple of times, but I feel like this is on indefinite hold :/
Offline Cods
« Reply #91 on: Sat, 10 October 2020, 22:41:29 »
Offline Icemanrec
« Reply #92 on: Tue, 13 October 2020, 11:20:13 »
is this project still moving forward? im keen to start an alps build, i have the switches and the keycaps, i need the keyboard :)
Offline netbike
« Reply #93 on: Tue, 10 November 2020, 01:58:19 »
Hi there, just received the blank pcb and am going to solder up the board.  Is there any information where I can build the layout and flash the board?
thanks
« Reply #94 on: Tue, 10 November 2020, 06:45:46 »
thanks
Ahh. You got one? Nice! I missed those FS threads on r/mechmarket. Sad. The pizza guy is as unresponsive here as he is on reddit. I was able to exchange a few PMs on reddit, but he ghosted me after that. I hope someone else makes a similar project which supports the NeXT keyboard. I love that thing and its keycaps; no one else has done a similar 60% project supporting that particular vintage board 😢
Offline kajahtaa
« Reply #95 on: Tue, 10 November 2020, 11:34:40 »
Seems like OP had a difficult year.
Hopefully some day the board will run.
Offline treeleaf64
    • treeleaf64
« Reply #96 on: Tue, 10 November 2020, 11:39:01 »
The prelaunch IC link doesnt work
Everyone must pay the cat tax
Offline treeleaf64
    • treeleaf64
« Reply #97 on: Tue, 10 November 2020, 11:40:34 »
Also can we get photos of what the inside mounting looks like?
