Author Topic: LEDs not working on PCB  (Read 2446 times)
Offline TeacherGeek
« on: Wed, 05 June 2019, 00:18:49 »
So I got some LEDS and all of them worked on my PCB except this purple one. The legs were particularly longer too.
I was wondering why this might be? The head seemed to be the same size as the other colours.
Re: LEDs not working on PCB
« Reply #1 on: Wed, 05 June 2019, 09:21:28 »
Did you install it the right way around?
Offline TeacherGeek
« Reply #2 on: Wed, 05 June 2019, 23:28:04 »
Yeah, I tried both ways. The LEDs worked on another PCB but not the one I wanted them on.
Same store, different colours but one colour didn't work.
Offline Sup
« Reply #3 on: Thu, 06 June 2019, 04:02:19 »
What PCB? can you show the soldering. Could be that it may miss a component. I had this once with a GH60.
current
Coming soon
Offline TeacherGeek
« Reply #4 on: Thu, 06 June 2019, 14:20:37 »
i put in another LED and it works on the same slot.
The non working LED works on another PCB.
This is what makes it  weird for me. Do LEDs need a certain voltage and the first PCB doesn't have it?
« Reply #5 on: Thu, 06 June 2019, 14:36:30 »
A LED (every diode actually) has a minimum voltage. Check the "forward voltage" in the data sheets for your LED's and compare.
I believe LEDs selected for a keyboard should be very power-efficient types: very bright with low current draw. A properly designed keyboard PCB should always dim the LED to a fraction of its full brightness by using PWM, not by reducing the voltage.
