Author Topic: del on HHKB pro2  (Read 4165 times)
Offline d-blank
del on HHKB pro2
« on: Thu, 27 May 2010, 06:58:04 »
I just got my blank key Pro2, I set it on lite extension mode.
when I press the top right hand side del key, nothing happen, aren't both bs, and the del key suppose to work?
Offline ch_123
del on HHKB pro2
« Reply #1 on: Thu, 27 May 2010, 07:03:47 »
Depending on how you have your DIP switch set up -
1) Del is the key marked Delete (button where \| is on a standard US keyboard), and BS is Fn + that key.
2) Backspace is the key marked Delete, and delete if Fn + ~`
I'm not explicitly familiar with the Lite extension mode, but I assume that it's the second configuration of the above two.
EDIT: From the diagram on the other page, Lite extension is the mode I use on mine... So del if Fn + `~
« Last Edit: Thu, 27 May 2010, 07:06:33 by ch_123 »
Offline d-blank
del on HHKB pro2
« Reply #2 on: Thu, 27 May 2010, 07:11:48 »
Quote from: ch_123;187298
I have on lite extension mode, so "bs" key is the delete by itself, but when press fn and del key, the del key doesn't work.
does the del key suppose to work when press fn and del on lite extension mode??
thanks
Offline ch_123
del on HHKB pro2
« Reply #3 on: Thu, 27 May 2010, 07:12:53 »
Del = Fn + ~` (i.e. the key above the del key, which has del written on it's front side instead of the top)
Offline d-blank
del on HHKB pro2
« Reply #4 on: Thu, 27 May 2010, 07:18:37 »
got it. thanks. so it should be fn+shift+del key.
Offline ch_123
del on HHKB pro2
« Reply #5 on: Thu, 27 May 2010, 07:25:33 »
Allow me to put this in the single most unambiguous way possible -
When you are in HHKB lite extension mode, Backspace is this -
And Delete is this -
Offline d-blank
del on HHKB pro2
« Reply #6 on: Thu, 27 May 2010, 07:36:48 »
you are right, I was confuse between bs, and del key. thanks for advise.
Offline itlnstln
del on HHKB pro2
« Reply #7 on: Thu, 27 May 2010, 08:09:25 »
ch_123, did you get a hobo to help you with those pics?
Offline iMav
  • geekhack creator/founder
del on HHKB pro2
« Reply #8 on: Thu, 27 May 2010, 08:25:32 »
Quote from: itlnstln;187318
Admit it...you put those gloves on for the pictures, didn't you?  ;)
Offline d-blank
del on HHKB pro2
« Reply #9 on: Thu, 27 May 2010, 08:29:32 »
I'm new to the HHKB, CH_123 very kind to took those pics. thanks
Offline itlnstln
del on HHKB pro2
« Reply #10 on: Thu, 27 May 2010, 08:51:17 »
I know people get sensitive about their identity being on the web, but damn, it's just a hand, bro.
Offline ch_123
del on HHKB pro2
« Reply #11 on: Thu, 27 May 2010, 09:27:14 »
There's actually a very good explanation for all this...
But I'll leave you folks to guess what it is.
Offline itlnstln
del on HHKB pro2
« Reply #12 on: Thu, 27 May 2010, 09:30:29 »
You didn't want to leave fingerprints?
Oh, wait.
Offline ch_123
del on HHKB pro2
« Reply #13 on: Thu, 27 May 2010, 10:23:59 »
Truth is that when I took those pics, I was about to go out to do some dumpster diving to get a NIC for my new Dolch PAC 64. Hobo gloves are an essential part of my dumpster diving routine.
Offline itlnstln
del on HHKB pro2
« Reply #14 on: Thu, 27 May 2010, 10:26:58 »
To look the part is to be the part.  Well done.
Did you find the NIC?
Offline itlnstln
del on HHKB pro2
« Reply #15 on: Thu, 27 May 2010, 10:32:30 »
I forgot about that movie.  It was pretty good.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
del on HHKB pro2
« Reply #16 on: Thu, 27 May 2010, 10:52:08 »
Tsk tsk tsk CH, I've got assloads of NICs.
Though, shipping alone makes them less desirable than your locally disposed-of examples.
kishy.ca
Offline itlnstln
del on HHKB pro2
« Reply #17 on: Thu, 27 May 2010, 11:13:01 »
Quote from: kishy;187366
So what are you saying?  That they're ****ty?  I wouldn't want any of those.
Offline ch_123
del on HHKB pro2
« Reply #18 on: Thu, 27 May 2010, 11:21:47 »
Found three different 100Mbps NICs, I'm thinking at least one should work.
I got one from college yesterday, but it made the Dolch think that it was a Maths Department X-terminal. That was a rather lolworthy moment.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
del on HHKB pro2
« Reply #19 on: Thu, 27 May 2010, 11:23:03 »
Quote from: itlnstln;187375
Har de har har.
10/100M PCI and 10M ISA...presumably the 486 doesn't have PCI making NIC-finding substantially more difficult.
kishy.ca
Offline clickclack
  • Board Chow EXTRAORDINAIRE
del on HHKB pro2
« Reply #20 on: Thu, 27 May 2010, 12:11:49 »
Quote from: ch_123;187344
LoLz
You're a hand model!?!
And you want to protect your delicate feminine fingies XD
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline didjamatic
del on HHKB pro2
« Reply #21 on: Thu, 27 May 2010, 16:51:38 »
Keepin it real.
Offline ch_123
del on HHKB pro2
« Reply #22 on: Thu, 27 May 2010, 17:34:14 »
Hobo gloves are a terrible idea for typing, they really slow you down...
Dear god, I really brought some **** upon myself...
