Please refer to the GB thread / Discord for latest updates - https://geekhack.org/index.php?topic=102334.0
For quick update summary, please scroll down to the newly added Update Summary!Order Overview is >>>http://tiny.cc/nk9jdz<<<, please check if there is any problem; if you see a question mark on your order, it means that you didn't fill in your Google form properly, please amend your responses before the deadline or you risk an order cancellation.Should you be interested in subscribing to our news update via email, please kindly fill in the form here - https://forms.gle/Z4uWKJ8TLLhnPkqD7 or join Thic Thock's Discord - https://discord.gg/nQ6g5UC![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 227297-0](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=227297;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 227299-1](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=227299;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 227301-2](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=227301;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 227303-3](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=227303;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 227305-4](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=227305;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 227307-5](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=227307;image)
Disclaimer: we do not officially support this color combo because PC and aluminium version are manufactured by 2 different factories and we cannot guarantee the compatibility will be perfect. (although in this case it is)
Thank you for coming in.
BOCC is an embodiment of utility and aesthetics. This unique layout not only serves properly on a daily use basis, but also is a great layout to display the beauty of our beloved keysets in a unique form.
The design philosophy of this board is inspired by the first carrier of this unique layout - Kmac Mini. The robust utility it offers and the aesthetic of the whole board is pure joy to look at. We hope not only to bring back this layout to our beloved community, but also we would like to try something new this time - a non-traditional mounting system.
Traditional top mounting system requires the screws to lock in the plate from the bottom case to the top case, while having the PCB suspended in between when it is fully assembled. We hope to alleviate, if not eradicate the reverbs that the suspension of the PCB would cause, thus, the mounting system we proposed will be having the PCB screwed and locked in to the bottom case, while the plate will be screwed in and locked in place on the top case.Another thought we put into this design is that we hope that whoever appreciate hot-swappable PCB could easily change the plate by unscrewing it off the top case and swap it to another material to experience different typing feel. Last but not the least, user can enjoy the plateless set up on this mounting system as well.
Specification of the board:Aluminium Version Unlimited7 Degree
6063 Aluminum
PVD Brass weight
Aluminium plate
Sidebar weight (PVD Brass)
Non-hot swappable Backlit RGB PCB - QMK compatible (ISO supported)
USB-C Port
Double Lock Mechanism
Color options:
- AnodizationRed
Pale Turquoise
Pink
Black
- ElectrophoresisWhite
Yellow
You are able to choose their favourite color combination. You can only match color that is under the same coloring category - eg. Yellow cannot match with Black, Baby Blue cannot match with White.
We will be using the latest electrophoresis technology; the finish will be more durable in terms of scratch resistance and wear resistance.
Polycarbonate VersionLimited quantity of 20Unlimited7 Degree
Mitsubishi polycarbonate
Aluminium plate
PVD Brass weight
Non-hot swappable Backlit RGB PCB, QMK compatible (ISO supported)
USB-C Port
Special Edition - BOCC SETotal of 7, 2 available for public(1 Piano Black, 1 Rose Gold)
7 Degree
PVD Brass
PVD Brass weight
PVD Brass plate
USB-C Port
Serialized
Renders for BOCC SECredit to Kingk22
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225662-6](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225662;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225664-7](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225664;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225666-8](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225666;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225668-9](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225668;image)
Sidebar weight customization
This will be implemented in both version, we are looking to expand this service on extras as well. This option will have extra cost.
Supports WKL
- 1.5 / 1 / 1.5 / 7 / 1.5
Supports ISO & split left shift (Hot-swappable PCB - no)
Supports Split Backspace
Renders:![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225725-10](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225725;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225672-11](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225672;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 222122-12](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=222122;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 222124-13](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=222124;image)
Credit to Kingk22
Keycaps: ePBT G81-SAV Reload
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225471-14](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225471;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225473-15](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225473;image)
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures 225475-16](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225475;image)
*Please note that although render colors are not representing the final product, most of the renders above reflect their color faithfully;
however, Baby Blue is not perfectly accurate to the sample that we are looking to get, the final product should be more light. The color of Cyan/Tiffany Blue in the render should be very close to the actual color now.
Group Buy information:Price:
300USD + Shipping
Extras such as plates (PC, Brass - sand blast, CF, Aluminium) and PCB (non-hot swappable and hot swappable) will be available when the GB starts.
Sales type:
BOCC (Alu & PC / extras) sales on
https://thicthock.com.
Group buy date is now set from
7th September 00:00 GMT+8 to 3rd October 00:00 GMT+8- Google form will no longer accept editing of your responses 1 days - 4th Oct, 2019 GMT+8 00:00 after the conclusion of the GB. All options will be final by that time. Those who had received email notification on requesting the amendment of your Google form, please edit it ASAP; failed to do so will result in cancellation of your order.
- Acceptance of refund or cancelling order will no longer be available 1 day - 4th Oct, 2019 GMT+8 00:00 after the conclusion of the GB.
BOCC SE sales will be held through a Vickrey Auction.
The Vickrey Auction form will be live on
5th September 22:00 GMT+8 to 6th September 22:00 GMT+8 (24 hours)
Vickrey Auction Instructions:
1. You place your bid (baseline bid is 400) - the maximum amount of bid you're willing to pay, without knowing others bids.
2. After filling in the form, you basically wait until the auction ends.
3. The event holder will announce the 2nd highest bid and it will be the pricing for BOCC SE.
e.g.
#1 - 1000
#2 - 960
#3 - 950
#2 is the 2nd highest bid, SE's price will be set at 960 for all winners.
4. The winners will receive notifications and invoices subsequently.Rules:
- One entry per household
- Duplicate entries will result in getting the participant disqualified immediately without warning and notice
- 2 SE kits will be available for bidding; Piano Black #4, Rose Gold #6
- Top 2 bids will be taking the spots; the price will be referenced at the second highest bid in this case
- Highest bidder will be able to choose which color, second bidder will have to take whatever that is left
- The bid you place represents the maximum bid you are willing to pay; but the final price of BOCC SE will be determined by the second highest bid
- Baseline bid will be starting from 400.
- Invoices will be sent to the winners immediately after the closing of the form.
- Winners will have up to 24 hours to pay their invoices; failed to do so will result in passing on their spot to others.
- Winning bid does not include shipping fee.
Please read the following before entering your bid
- BOCC SE is limited edition, only 7 will be made, 5 of which are allocated to family and friends
- BOCC SE will be shipped
AFTER regular BOCC's shipment is fulfilled
- The shipping fee for BOCC SE will not be cheap due to the material nature of the board is waaaay heavier than regular BOCC
To enter BOCC SE Vickrey Auction, please press
>>>here<<<Form status:
Closed; invoice sent!Vickrey Auction was concluded with 42 (1 duplicate entry) entries.
The bids are as follows.
![[IC] BOCC - End on 3/10 | Order Overview | Actual product pictures](https://geekhack.org/index.php?PHPSESSID=23pmdjjsobkpf4medgvprp1043jrgegq&action=dlattach;topic=101417.0;attach=225811;image)
The final price for SE is set to be 958.
Winners have responded and received their invoices, all SE are now claimed.
Update Summary:1/10 GMT+8 Updates
- Added actual product pictures
- Video in the making
- Typing sound can be found on Discord
28/9 GMT+8 Updates
- Added Order Overview, please check if you have time
26/9 GMT+8 Updates
- BOCC GB extended
- Added ecoat finished early birds pictures
15/9 GMT+8 Updates
- BOCC Aluminium Early Birds Pictures add
- Officially change Cyan/Tiffany Blue to Pale Turquoise
7/9 GMT+8 Updates
- BOCC GB is initiated
- BOCC SE Vickrey Auction is concluded and related data has been revealed
5/9 GMT+8 Updates
- BOCC SE Vickrey Auction baseline bid added
- BOCC PC prototype pictures added to #2
4/9 GMT+8 Midnight update
- BOCC SE announcement
- BOCC Group Buy date announcement
- Extras - PVD Brass option has been taken away (guys, don't panic, it's plate, not weight)
- Sales details have been updated
- Will no longer update change-log because the functionality of these two areas are essentially the same
27/8 GMT+8 Afternoon update
- BOCC PC prototype done - added pictures
- BOCC Alu prototype in the making
14/8 GMT+8 Afternoon update
- Removed extra free plates offered in PC version due to the decreased cost
- Added clarification on whether spilt backspace is supported or not - the answer is yes
14/8 GMT+8 Evening update
- Cap quantity of PC version is lifted, it is now unlimited
- Cost finalization - 300USD + shipping
- Supports WKL
- Color options updated
- Customers are able to choose their color combination (for more details, please refer to the above)
- Prototype ordered - demo ETA late August (we're making a full disclose and in-depth tear down on the demo regarding the mounting system and other noteworthy stuff)
- Vendor announcement - Thic Thock
20/7
- Removed PVD Stainless Steel option due to the higher manufacturing cost
- Updated the "In Progress" section
- Price of the board is yet to be determined until the prototype order is made, since the render is delayed, it is also delayed as a result
3/7 GMT+8 Afternoon update
- Cap quantity of Aluminium version has been lifted, PC version is still in consideration - but rest assured, the quantity of PC will
- be increased nevertheless
- Aluminium version will now have an identical design to PC version (yes, mounting system too)
- Both version now comes with non-hot swappable backlit RGB PCB with the kit - hot swappable PCB is still available on extras (yes, we heard you loud and clear)
- PVD Stainless steel option for sidebar weight will be added to options
- Sidebar weight customization will be open for both version, it will cost extra
- Price for both version is now subject to change due to the massive changes we are implementing on this project
- USB-C will be supported
- There will be only "Bocc" engraving on weight
- WKL layout has been chosen - 1.5/1/1.5/7/1.5/0.5/1/1/1 - poll will begin in GH thread soon - if this turns out to be green light, it will serve as an option instead of replacing the original design, so don't need to be worried for those who do not prefer WKL layout
- Color option has been deducted to Black, White, Blue and a new color added - Red
- Blue and Red will be fine tuned - expect the renders for it probably next week
- Color finish will be Electrophoresis - so long ano
In Progress:- Aluminium early birds are going to be at my possession possibly on 20, will release tear down and typing demo 1-2 days afterwards
Checklist:Initiation of IC ✔
Gather and process interests and comments ✔
Update the final design ✔
Finalize on all options ✔
Make prototype ✔
Proceed to GB ✔
Changelog: Small update
14/8/2019 - 1:27AM GMT+8
Big Update
- Updated Specs
- Updated Sales Type
- Updated Cost
- Updated Renders
- Updated Summary Update
- Updated In progress
- Updated Checklist
20/7/2019 - 8:55PM GMT+8
Small update
- Updated "In Progress"
- Updated "Update Summary"
- Updated some details of the product
3/7/2019 - 3:27PM GMT+8
Big updates
- added Update Summary section
- finalized aluminium version design
- color finish determined
- color options renewed
- added sidebar weight options
- retail price removed - bargaining
- cap quantity of alu version is lifted
3/7/2019 - 1:58AM GMT+8
Updated IC form questions
- added WKL questions
- added unifying design poll
Updated certain aspects of group buy details
- Extras for plate and PCB will be opened
- ISO will be supported
- Color render clarification
- added In Progress section
3/7/2019 - 10:59PM GMT+8
Updated renders
2/7/2019 - 1:12PM GMT+8
Removed bluetooth from the PCB of PC version
Added RGB to the PCB of PC version
Added IC form on top of the thread
Added GMK laser render
2/7/2019 - 2:58AM GMT+8
For differentiating the Kmini series, we've decided to change its name to Bocc
Renders will reflect correct name later when we update it
Some clarifications on certain specification
