Author Topic: [IC] IRON165 by Smith + Rune (GB Dates/Times / FE Raffle Announced)  (Read 323534 times)
Offline steezkeez
Re: [IC] IRON165 by Smith + Rune (protos ordered, other updates)
« Reply #200 on: Wed, 31 July 2019, 00:41:14 »
There’s absolutely no way this is gonna be sub $300... I would be surprised if it was sub $400 to be honest.
Offline SoraNoTenshi
« Reply #201 on: Wed, 31 July 2019, 03:07:14 »
I hope it will be around 400, max.
I wouldn't spend more than 450 tho D:
Offline bobgr8
« Reply #202 on: Wed, 31 July 2019, 13:15:00 »
given the rise of affordable options, I don't think I would spend $300 or more on a 60/65 keyboard, unless it's from key cult or Rama and has impeccable anode
Offline Vireca
« Reply #203 on: Wed, 31 July 2019, 13:43:10 »
What are the affordable options? I didnt see any 65% keyboard sub 300€ recently
Offline zF4TE
« Reply #204 on: Wed, 31 July 2019, 13:53:26 »
The Polaris by ai03, sub 300 gasket mounted beauty
Offline Vireca
« Reply #205 on: Wed, 31 July 2019, 13:59:37 »
Its 60%, not 65% :P
Offline steezkeez
« Reply #206 on: Wed, 31 July 2019, 14:03:35 »
Not trying to be rude but the Polaris is being run through KBDFans and is priced as such. This board is obviously more geared towards the luxury market and I'm sure will be priced accordingly so.
Offline Bhk1004
« Reply #207 on: Wed, 31 July 2019, 14:25:20 »
Didnt we just have issues with kbdfan ran switch opener quality designed by ai03? Kbdfan manufacturing is not top tier, it is budget. Pricing reflects as such.
« Last Edit: Wed, 31 July 2019, 14:30:08 by Bhk1004 »
Offline Vireca
« Reply #208 on: Wed, 31 July 2019, 14:53:28 »
Well, technically kbfans dont manu anything. They are just a shop that work as a proxy and shipping, so the designer dont run all the GB process itself. The problem with the switch openers as ai03 said was that the manu ****ed his measures, they didnt follow the designs exactly. He was really upset
Offline Bhk1004
« Reply #209 on: Wed, 31 July 2019, 15:07:38 »
My understanding is kbdfan shops the manufacturing across his factory contacts. Hence to me its kbdfans Manu. Did ai03 shop and secure his own manufacturing? Asking as I dont know the full background on how the supplu chain was secured. I do know that there is not a high regard to the manufacturing that kbdfan works with.
« Last Edit: Wed, 31 July 2019, 15:09:23 by Bhk1004 »
Offline voxkey
« Reply #210 on: Wed, 31 July 2019, 15:49:45 »
I think it's great that we all have so many options in basically every layout and at every price. There are quite a few projects I'm following closely and planning on joining, or have already joined, at both low price points and higher price points as well.
Specifically for this board, our main focus was on the design and engineering of the board and its feature set. Furthermore, we chose to go with suppliers who are more expensive, but offer consistency and high, repeatable quality.
What this means, unfortunately, is that the price will reflect this. While we will not release final pricing until everything is confirmed, I will say that the Iron165 SE will be priced around other high-end, premium offerings.
Offline steezkeez
« Reply #211 on: Wed, 31 July 2019, 15:58:26 »
For reference, Dixie Mech just released Bauer pricing (Aluminum kit = $460, Brass Kit = $560). I'm guessing IRON165 will be priced similarly.
Offline stuey138
« Reply #212 on: Wed, 31 July 2019, 15:58:50 »
My piggy bank is ready to be shattered to buy the iron, can't wait.
Offline xantiema
« Reply #213 on: Wed, 31 July 2019, 16:13:25 »
That is absolutely overpriced, for what it is
Offline jooobe
« Reply #214 on: Wed, 31 July 2019, 16:37:11 »
They are only doing 20 kits also, so high price is expected
Sent from my SM-N960F using Tapatalk
Offline Nevermore012
« Reply #215 on: Wed, 31 July 2019, 16:42:48 »
(gasket) isolation mount like keycult, i guess
Offline bobgr8
« Reply #216 on: Wed, 31 July 2019, 17:24:33 »
well, the NR65, Polaris60. anyways, I don't think this GB is going to be for me.
Edit: doesn't the mk community really praise kbdfans for their tofu case? Anyways, I've heard horror stories of Korean Kustoms and good QC with Chinese keeb.
I really don't think the price reflects the quality.
« Last Edit: Wed, 31 July 2019, 17:27:50 by bobgr8 »
Offline Clo_0lD
« Reply #217 on: Wed, 31 July 2019, 17:42:29 »
I think many would agree that most of the stuff that Kbdfans makes are good for the price, but if you want better anodization, machining, materials, etc. you're going to have to pay more for those things. Sure, not everything that is priced high is necessarily better quality, but in order to get better quality you will have to pay more usually.
I personally love my Acrylic Tofu, but I'm in on this because I love the design and I want a more premium option that will hopefully deliver on its promises of being a great quality product.
Offline Capsy
« Reply #218 on: Wed, 31 July 2019, 17:43:41 »
There's a place for every product in this community.
While KBDFans produce brilliant products, their anode and finishing is what you expect to get at that price. It's a level or two below the Keycults/RAMA/TGRs. You need to see what keycult refer to as B stock as that stuff will sell as A+ stock in a lot of KBDfans' GBs. So the price you pay for luxury products is the impeccable QC and finish quality.
Offline jooobe
« Reply #219 on: Wed, 31 July 2019, 18:48:32 »
Yup, buy what you want, and buy what you can afford
Offline bobgr8
« Reply #220 on: Thu, 01 August 2019, 00:53:31 »
Hence. Waiting for keycult 65
Offline baye12928
  • keyboard fans
« Reply #221 on: Thu, 01 August 2019, 02:08:00 »
$400 is also acceptable.....can not wait to buy
Offline Solotov
« Reply #222 on: Thu, 01 August 2019, 03:26:34 »
Is 910 plate compatible with Iron165?
Flex is love, flex is life.
Offline voxkey
« Reply #223 on: Thu, 01 August 2019, 07:09:26 »
No, completely different plate design.
Offline Solotov
« Reply #224 on: Thu, 01 August 2019, 07:26:28 »
Thanks. One more question.
Will you provide typing sound comparing SE with FE version? Apart from aesthetic factor, I would like to know about acoustic factor as well.  :thumb:
Offline voxkey
« Reply #225 on: Thu, 01 August 2019, 07:35:24 »
Absolutely! We're really curious as well. We've prototyped every option and plan to test everything out.
Offline Solotov
« Reply #226 on: Thu, 01 August 2019, 09:46:02 »
Ayyy, sound great! Can't wait to see the updates on prototypes   :p
Offline kyyyten
« Reply #227 on: Thu, 01 August 2019, 17:25:22 »
Very interested in a ISO board! :D
Offline narunekogi
« Reply #228 on: Sun, 04 August 2019, 05:52:03 »
Yes. Do want.
Offline voxkey
Re: [IC] IRON165 by Smith + Rune (Prices and Vendor Announcement)
« Reply #229 on: Sun, 04 August 2019, 21:17:27 »
Whoops, fixing
« Last Edit: Sun, 04 August 2019, 21:20:27 by voxkey »
Offline ninjacore
« Reply #230 on: Sun, 04 August 2019, 21:28:02 »
Whoops, fixing
Shipping separate? $30-50?
Offline jimboytacos
« Reply #231 on: Sun, 04 August 2019, 21:30:59 »
$885 and $445. Wow. :(
I'm too broke to afford that. I'll see (IC) myself out.
Offline lbaron
« Reply #232 on: Sun, 04 August 2019, 21:33:27 »
Whoops, fixing
Yes, shipping will be separate and depend on where you live.  Shipping from Cannon Keys will mean that NE will be cheaper than say CA.
Offline jimboytacos
« Reply #233 on: Sun, 04 August 2019, 21:53:48 »
When will raffles signups begin? And when will it be drawn?
Offline lbaron
« Reply #234 on: Sun, 04 August 2019, 21:55:24 »
When the group buy launches we will do the raffle for the FE most likely the day before the SE goes on sale.  So for those that miss the FE they can still have option to try for the SE.  This will most likely happen in September.
Offline Clo_0lD
« Reply #235 on: Sun, 04 August 2019, 22:35:33 »
Any idea on how long the FE raffle window will be open for? For example, will it be like keycults 10 min windows or something much longer?
Offline lbaron
« Reply #236 on: Sun, 04 August 2019, 22:48:08 »
We will probably do a similar approach to account help mitigate alt accounts entering multiple times.
Offline bthezebra
« Reply #237 on: Sun, 04 August 2019, 23:00:19 »
NE luck avail
Offline lamenthe
« Reply #238 on: Sun, 04 August 2019, 23:03:07 »
Oh hell yes
Offline baye12928
  • keyboard fans
« Reply #239 on: Sun, 04 August 2019, 23:51:16 »
will Asian vendor be arranged? such as Z-frontier :))
Offline sozo
« Reply #240 on: Mon, 05 August 2019, 01:27:02 »
Nice! I'll start saving up for that FE, as a birthday gift to myself!
Offline xantiema
« Reply #241 on: Mon, 05 August 2019, 04:34:18 »
900 and 450 wow. I guess the Vendor wanted a hefty payday too
Offline eskimojo
    • KeycapLendar
« Reply #242 on: Mon, 05 August 2019, 04:41:55 »
I assume you've somehow obtained the manufacturing costs then?
Offline nguyenhimself
« Reply #243 on: Mon, 05 August 2019, 04:45:39 »
Sometimes I look at expensive kits like Wilba's Thermal (which is still "just" $360 BTW) or the Keycult and think: "Ouch my wallet but yeah I can see why. Fair enough." (After-market price notwithstanding).
This? I dunno. Compared to contemporary keyboard kits, I'm yet able to see why this one is way over $400 yet.
« Last Edit: Mon, 05 August 2019, 04:50:41 by nguyenhimself »
Offline xantiema
« Reply #244 on: Mon, 05 August 2019, 05:03:14 »
Assume away.
Offline xantiema
« Reply #245 on: Mon, 05 August 2019, 05:10:53 »
Assume away.
Exactly. The FE has a representing price for the materials chosen alongside the scarcity, not so much with the SE.
Offline Full
« Reply #246 on: Mon, 05 August 2019, 05:15:10 »
Assume away.
Hi!
« Reply #247 on: Mon, 05 August 2019, 05:45:47 »
If more information about a EU Vendor are there... i might reconsider my max price / kit...
45$ more shouldn't destroy my finances... :D
Offline keyberzerker
« Reply #248 on: Mon, 05 August 2019, 05:58:45 »
yeah you pay 500 for a keeb and then worry for 45 :D pls
Offline harlekein
« Reply #249 on: Mon, 05 August 2019, 07:30:19 »
11% before taxes is nothing to scoff at.
