Author Topic: [IC] GMK 9009 R3 - Launching September 1st  (Read 204038 times)
Offline bobgr8
Re: [IC] GMK 9009 R3
« Reply #200 on: Fri, 26 July 2019, 03:38:51 »
The pricing
Pricing is TBD. But I can tell you this: it'll be cheap, and it'll be cheap from day 1 ;)
Render gallery
 what is "cheap" for a gmk?
Would it be cheaper than $120 for ePBT currency on kbdfans?
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #201 on: Fri, 26 July 2019, 04:30:16 »
How much was the base set for the last group buy?
I don't know how much it was, but I can 100% say it was more expensive than this one is going to be because there were way more keys included in the core set. Jan mentioned this one would cheap from the get-go
Offline kgorin
  • Formerly aka_gk
« Reply #202 on: Fri, 26 July 2019, 04:31:26 »
https://unicode-table.com/en/2387/
https://unicode-table.com/en/2325/
The two icons are distinct.
GMK's Alt icon is kind of a compromise between the two: it's missing the arrow like the Mac Option icon, but it's flipped around like the standard Alt icon.
Yeah, I understand they are distinct. It's just that I find frustrating the need to find a middle ground between the icon that's actually used and the one that's barely used. We can leave it at that
The set is a great classic nonetheless
Offline OracleKev
« Reply #203 on: Fri, 26 July 2019, 05:43:55 »
How big will be needs to augment R2 sets with R5 rows?
Guess I can lean on the Modern kit and source R5 arrow keys from vintage sets.  :p
Just wondering if others are thinking about doing the same thing.
Offline hansikhouse
« Reply #204 on: Fri, 26 July 2019, 08:59:02 »
Prices on their last GB can be found here - https://dixiemech.com/gmk9009, base going for $125 at 500 MOQ. Hoping it'll be at this or less!
Anyone own and/or compare this to the ePBT set on KBDFans? I'm pretty sure I want this to be my first GMK set, just wanted to see if anyone had input on this, especially with color vibrancy comparisons.
« Last Edit: Fri, 26 July 2019, 09:05:14 by hansikhouse »
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #205 on: Fri, 26 July 2019, 09:48:28 »
Pricing will be announced at a later date, but yes the base kit will be quite a bit cheaper than the previous round obviously! That much I can say :)
Offline jihadu
« Reply #206 on: Fri, 26 July 2019, 10:14:58 »
Looking forward to it! I will finally be able to build a classic looking board with an ivan enter
Offline rockydbull
« Reply #207 on: Fri, 26 July 2019, 10:41:43 »
The pricing
Render gallery
Looking at the base kit and peering into my crystal ball (no guarantee of any accuracy) I would say somewhere from $99-$109 for the base kit. GMK will always be more expensive on a per key basis than epbt (for lots of reasons), but the entry point will likely be lower than the ebpt 9009 set.
Offline jihadu
« Reply #209 on: Fri, 26 July 2019, 12:28:29 »
What is an "ivan enter"?
It's a old layout available on the GH60 PCB and the GH60 satan. It's essentially a split ansi enter (instead of a full 2.25 u enter key , you use a 1u and a 1.25u key). It's pretty memey and that's the only reason I want to build a board with it. Like this
Offline JSaintS
    • JSaintS
« Reply #210 on: Fri, 26 July 2019, 12:33:34 »
So it has the shape of an ISO return key, sort of, but it's still ansi? What do you map that added key to?
Offline jihadu
« Reply #211 on: Fri, 26 July 2019, 12:33:41 »
Fun fact: it's named after former community member IvanIvanovich who ran alot  Group Buys and ended up scamming a lot of money after not fulfilling them.
Offline jihadu
« Reply #212 on: Fri, 26 July 2019, 12:34:21 »
No clue. I have never used it before
Offline depletedvespene
    • Keyboard-related resources.
« Reply #213 on: Fri, 26 July 2019, 12:54:05 »
Oh, it's a TIE: an R3 1.25U key, that comprises the area common to ANSI and ISO Enter keys, freeing up the other side (be it the 1U key in R3 or the 1.5U key in R2 for other stuff).
This was common on some old IBM terminal keyboards (look up the IBM 4704 keyboards: F107, F77, F62 "kishsaver" and the pingmasters, too).
When Ellipse's F77 is out, I'm going TIE on it, too.
« Reply #214 on: Fri, 26 July 2019, 12:55:06 »
All the more reason to go with the "TIE" name and abandoning the "Ivan" name.  :thumb:
Offline jihadu
« Reply #215 on: Fri, 26 July 2019, 13:09:43 »
What does TIE mean, btw?
« Reply #216 on: Fri, 26 July 2019, 13:14:58 »
"Tiny Intersection Enter" (as it covers the area common to ANSI and ISO Enter keys, much like BAE would be the union of both areas).
Offline jihadu
« Reply #217 on: Fri, 26 July 2019, 13:28:06 »
That makes sense.
Offline bobgr8
« Reply #218 on: Fri, 26 July 2019, 13:55:09 »
whoa that sounds awesome man!
Please have an Asia vendor that ships to India. This would BE my first GMK!
if this is $100, with taxes, I can afford this!
« Last Edit: Sat, 27 July 2019, 03:02:46 by bobgr8 »
Offline ctrlshiftba
    • ctrlshiftba
« Reply #219 on: Sun, 28 July 2019, 08:55:22 »
this has to be the first GMK base kit I've ever seen that doesn't have the extra 2.25 shift included. any chance it could be moved in?
Offline konstantin
  • Formerly constexpr
« Reply #220 on: Sun, 28 July 2019, 10:58:18 »
It should definitely stay in the Addition kit imo. It's only used in one layout which isn't really all that common.
Offline RominRonin
« Reply #221 on: Sun, 28 July 2019, 14:00:28 »
Hey, nice to see that understated classics are not forgotten.
Given the improvement of the modifiers is a significant one, and given that there are many out there who own R1 and R2 sets, not to mention Original Classic sets, is there a possibility you might offer the modifiers as a stand-alone kit, separate from the alphas?
Apologies is that has come up int he thread already, I admit to not having read through each reply at this stage.
Offline jani80k
  • In the hobby for a good time.
« Reply #222 on: Mon, 29 July 2019, 07:15:26 »
I'd put colored ISO enters in the Addition Kit. ePBT has them.
« Reply #223 on: Mon, 29 July 2019, 07:47:53 »
Will you be posting the revised kits soon? (there's one change still to be made to the (initial) Addition kit  ;) ).
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #224 on: Mon, 29 July 2019, 10:33:34 »
I'd love to get this set, but I don't think I would unless the ISO support was done properly. Accented enter keys, a NorDeUk kit or UK-ISO included with ISO etc.
Offline jay6889
« Reply #225 on: Tue, 30 July 2019, 03:03:34 »
Any chance for Vim kit?  :)
Offline yokern
« Reply #226 on: Tue, 30 July 2019, 04:11:31 »
I filled out the form. Will you email me when the kits are about to drop or will you do it here?
« Last Edit: Tue, 30 July 2019, 04:13:31 by yokern »
Offline ZyBeR
« Reply #227 on: Tue, 30 July 2019, 07:14:41 »
A Nordic kit would be nice :)
Offline forevermadrigal
« Reply #228 on: Tue, 30 July 2019, 07:32:14 »
I’m sure they’ll announce gb date here
Offline ideus
  • Björkö.
« Reply #229 on: Tue, 30 July 2019, 14:38:28 »
+1++1+++1
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #230 on: Wed, 31 July 2019, 04:17:51 »
Offline ideus
  • Björkö.
« Reply #231 on: Wed, 31 July 2019, 07:25:53 »
+1++1+++1
It is possible 😁
Awesome setup. Is it hand wired? Where did you get that nice case?
Offline bizun
« Reply #232 on: Wed, 31 July 2019, 09:55:40 »
Its Grid 600.
Offline RETURNISO
« Reply #233 on: Wed, 31 July 2019, 10:10:05 »
+1++1+++1
It is possible 😁
Yeah its a Grid 600, No handwire lol  ^-^
Its 9009 R1 with a Intl. Kit from R2. Relegendables from a g80-8113
Offline D3LTA
« Reply #234 on: Wed, 31 July 2019, 10:26:53 »
Would also be interested in a colevrak kit.
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
« Reply #235 on: Wed, 31 July 2019, 12:30:00 »
Were the renders made with the final alignments as well? If not it would be good to have them updated, just to see how things will look like.
Renders were not made to spec with the flat vector that was incorrect. They are closer to correct. But once again, nothing is perfect since these are just representations of the product before it exists.
« Last Edit: Wed, 31 July 2019, 12:32:54 by GarrettSucks »
Offline steezkeez
« Reply #236 on: Wed, 31 July 2019, 15:48:45 »
Need this for my J80! Hoping GB starts soon :)
Offline CandyKeys
  • Just doing EU things.
    • CandyKeys EU MK Store
« Reply #237 on: Wed, 31 July 2019, 17:44:41 »
Good luck on the set from the south!
The CandyKeys Mechanical Keyboard Store
Offline Flexerman
  • Thanks for all the fish
« Reply #238 on: Thu, 01 August 2019, 05:25:40 »
Please, please, please add the 2 and 3 for UK-ISO support, I don’t care which set I don’t mind paying more for it.   :thumb:
Offline tronix_41
« Reply #239 on: Thu, 01 August 2019, 05:27:18 »
+1 for international kit
Offline dumhevae
« Reply #240 on: Thu, 01 August 2019, 05:56:34 »
NorDeUk kit would seal the deal for me on this one
Offline dexie
« Reply #241 on: Thu, 01 August 2019, 08:14:41 »
ISO accents and R0 would be an insta-buy from me
ISO Life
Offline jani80k
« Reply #242 on: Thu, 01 August 2019, 08:24:02 »
Could you make the accents a separate kit? That alone would sell a  lot for all the OG keycap users...
Offline jani80k
« Reply #243 on: Thu, 01 August 2019, 08:25:01 »
... oh, and an international kit would be nice, too. It would make MOQ on such a popular set for sure. Another option would be to use alphas from OG keycap sets.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #244 on: Thu, 01 August 2019, 08:34:24 »
ISO accents and UK ISO in some form would make the difference between me buying/not buying this set.
Offline hottrout
  • I'd Hit Dat Key
« Reply #245 on: Thu, 01 August 2019, 11:37:41 »
Ditto, just add the missing keys and I am in as well.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline gidimi
« Reply #246 on: Thu, 01 August 2019, 15:37:07 »
Same here. At the very least ISO accent would be awesome.
« Last Edit: Thu, 01 August 2019, 15:39:45 by gidimi »
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #247 on: Thu, 01 August 2019, 16:44:12 »
Hey everyone!
Here are some kit updates!! :)
Obscure kit
The kit is further streamlined, with unnecessary duplicate keys removed. Added is fuller support for Minivan type layouts and a mod coloured quote key for ortho users.
Addition kit
Due to popular demand: inclusion of full ISO-UK support and the addition of accented ISO UK enters! The alternative 65% row is also completed for more options there.
Also some cool added renders on the J-01 by Jae from Top Clack!
I'm very excited to bring this classic back, we'll continue working on this behind the scenes and will be back with more updates soon!!!  :D
Offline kakiharaOne
[IC] GMK 9009 R3
« Reply #248 on: Thu, 01 August 2019, 17:03:16 »
Hey everyone!
Obscure kit
Addition kit
Is the top row in the obscure kit R1 or R2?
Edit: Never mind. Looks like that is a 1.75 backspace, not 1.5. Any chance of adding an R1 1.5 backspace?
« Last Edit: Thu, 01 August 2019, 17:05:50 by kakiharaOne »
Offline konstantin
« Reply #249 on: Thu, 01 August 2019, 17:23:32 »
Would you consider moving R3 PgUp, R4 PgDn from Addition to Base now that the former kit's been expanded? I think R3, R4 are arguably at least equally as common as R2, R3 in the wild nowadays (especially considering how many Alts Drop has sold). We're also seeing more and more sets putting these keys in their base kits.
