Author Topic: [IC] IQUNIX DISCRETE 87  (Read 14113 times)
Offline Levan
« on: Thu, 01 August 2019, 07:23:28 »
Hi,
This is Levan from IQUNIX.
Please check our new design: DISCRETE87
Please feel free to ask my any quesitions!
Offline Xynerorias
  • Lubin' with glicerin
Re: [IC] IQUNIX DISCRETE 87
« Reply #1 on: Thu, 01 August 2019, 07:33:32 »
A bit more details maybe?
Sent from my ONE A2001 using Tapatalk
Offline jooobe
« Reply #2 on: Thu, 01 August 2019, 07:50:34 »
Looks good
Sent from my SM-N960F using Tapatalk
Offline EMC Labs
« Reply #3 on: Thu, 01 August 2019, 08:11:20 »
Wow, two keyboards? Very original idea and amazing design. GL!
Offline jooobe
« Reply #4 on: Thu, 01 August 2019, 08:17:14 »
Is this the only color?
Offline jani80k
  • In the hobby for a good time.
« Reply #5 on: Thu, 01 August 2019, 08:27:50 »
Nice renders.
Offline Poesjuh
« Reply #6 on: Thu, 01 August 2019, 08:36:40 »
Nothing discrete about that badge on the top right imo.
Offline pixelpusher
« Reply #7 on: Thu, 01 August 2019, 08:39:48 »
Any details on mounting or materials?
The top right badge looks off to me.  Would you consider making it shorter so that it doesn’t touch the edge? It would help the board look more uniform if the bezel wasn’t interrupted by the badge.  Also, maybe make the badge match the slanted design of the case and weight?  You could apply the slanted angle of the middle for the edges of the badge. Or at least apply that as a detail to a side or corner of the badge.
Offline Levan
« Reply #8 on: Thu, 01 August 2019, 10:35:49 »
Yes, this is the only colour  for now.
Offline mrkantz
« Reply #9 on: Thu, 01 August 2019, 10:36:35 »
Both of these boards feel like the branding is a little too big and in your face for my taste
Offline Levan
« Reply #10 on: Thu, 01 August 2019, 10:38:20 »
Thank you!!
Offline Levan
« Reply #11 on: Thu, 01 August 2019, 10:43:05 »
Hi,pixelpusher
Thank for you advice, I'll try to shorter the badge see whchi is better!
Offline rowie
« Reply #12 on: Thu, 01 August 2019, 10:57:11 »
Would be nice if you offered the reverse and have pink on the top and then grey badge.  I have so many dark keyboards and need more light colored keyboards. Fantastic job so far. :thumb: I will watch this thread and see where this evolves.
Offline DasGnome
« Reply #13 on: Thu, 01 August 2019, 11:07:16 »
Really appreciate how adventurous this design is. I agree with others that the badge should be shorter, line it up with the key block under it. It's more of a distraction to the interesting "stepped" looked than anything.  I also think the badge would look better in grey.
« Last Edit: Fri, 02 August 2019, 08:34:42 by DasGnome »
Offline jooobe
« Reply #14 on: Thu, 01 August 2019, 11:24:39 »
Maybe etch or engrave just the word discrete on to the case without the badge? You can color in the word with the badge color tho.
SA bliss will look dope on this
« Last Edit: Thu, 01 August 2019, 11:54:55 by jooobe »
Offline breckstar
« Reply #15 on: Thu, 01 August 2019, 18:05:23 »
Design is cool but unfortunately a lot of keycap sets wouldn't fit properly. The 6 key cluster (home, end, pgup, pgdn, ins, del) usually isn't supported for R2-R3 as this design shows.
Offline Mr_BeastQuake
    • Reddit
« Reply #16 on: Thu, 01 August 2019, 18:10:44 »
THROW THEM IN THE TRASH
Offline breckstar
« Reply #17 on: Thu, 01 August 2019, 20:09:18 »
You're right. Will do boss.
Offline NimbleTortoise
« Reply #18 on: Fri, 02 August 2019, 03:50:57 »
There is a difference between discrete and discreet
Offline mlnr
« Reply #19 on: Fri, 02 August 2019, 04:04:33 »
discrete =/= discreet
Offline YellowHalo
  • See You Starside
« Reply #20 on: Fri, 02 August 2019, 04:34:12 »
It's pretty. I imagine GMK Olivia would go very nicely with it.
Offline piit79
« Reply #21 on: Fri, 02 August 2019, 06:01:03 »
Yep. I'd just ditch the PrtSc/Scroll Lk/Pause keys and keep Ins/Del/Home/End/PgUp/PgDn where they should be.
Offline breckstar
« Reply #22 on: Fri, 02 August 2019, 06:42:13 »
Offline DasGnome
« Reply #23 on: Fri, 02 August 2019, 08:37:52 »
Great idea! Hope OP takes these suggestions.
Offline depletedvespene
    • Keyboard-related resources.
« Reply #24 on: Fri, 02 August 2019, 09:39:12 »
Ditching the supranav keys for no reason is an objectively terrible idea (YMMV). If nothing else, they can be put to good use for other things, like volume control.
Besides that, I agree that moving the nav keys (Ins, Del and HUDE) one row down isn't a good idea, either.
Offline GeekMaker-IC
« Reply #25 on: Fri, 02 August 2019, 11:26:13 »
COOL BOARD
Offline Desolace
« Reply #26 on: Mon, 05 August 2019, 02:17:18 »
Very interested! I agree with the others that the design would benefit from reducing the size of the badge.
Offline 8BitDuck
« Reply #27 on: Tue, 06 August 2019, 16:35:13 »
Will there be ISO support?
« Reply #28 on: Tue, 06 August 2019, 19:35:23 »
this is good and will go unnoticed
Offline lamenthe
« Reply #29 on: Wed, 07 August 2019, 03:58:07 »
One of the more unique board designs in a while. Great work!
Offline vidoardes
« Reply #30 on: Wed, 07 August 2019, 08:03:10 »
It's a really nice shape, just not a fan of the pink. Hope it gets the traction it deserves though!
Offline Fried Doggy
« Reply #31 on: Thu, 15 August 2019, 11:46:55 »
Nice keyboard, Just wondering if there are any dates or prices on the board?
Also just a suggestion instead of having a badge in the top right corner maybe and engraved logo of "Discrete" would look alot better, so you would have your branding and not make the top of the board look clustered. But apart from that the board is very unique especially the bottom.
Offline SUB01
« Reply #32 on: Thu, 15 August 2019, 12:23:33 »
LOL ^this. Could maybe do with a bit thinner bezels but really nice design guys!
edit: I am very dumb.
« Last Edit: Thu, 22 August 2019, 00:40:47 by SUB01 »
Offline foxlive
  • The quick brown fox jumps over the lazy dog
« Reply #33 on: Thu, 15 August 2019, 16:14:26 »
Nice and creative design! We want to know more!
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #34 on: Thu, 15 August 2019, 16:25:12 »
Really hope the three TKL boards you've been posting here all see the light of day soon!  ;D
Offline shansoft
« Reply #35 on: Thu, 15 August 2019, 17:42:54 »
The keys on the top right if they can be in their original position would be much better.
The keycap height won't match properly and it does seem off to me.
Offline EvaoftheIvy
« Reply #36 on: Thu, 15 August 2019, 20:11:06 »
Looks good I happen to be looking for nice TKL and similar boards anyways hope to see more details :)
Offline jedidood
  • aka neovisual
« Reply #37 on: Sun, 25 August 2019, 04:21:55 »
You have my attention...
Offline jimboytacos
« Reply #38 on: Sun, 25 August 2019, 18:35:51 »
I gotta say that this is the first keyboard that just looks very different and I appreciate that this is in the community.
Offline SUB01
« Reply #39 on: Sun, 25 August 2019, 21:38:57 »
I think the bezels are a bit too fat, reminds me of 2014 gaming laptop monitors. Also if those copper accents are actually all copper that is going to be hella expensive. Still, well done.
Offline foxlive
« Reply #40 on: Mon, 26 August 2019, 16:02:04 »
As much as I like my bezels fin on my smartphone, I ****ing love them fat on my keyboards ahah (EXENT is definitely my favorite board ever!)  :))
