Author Topic: I need advice on springs mod for Tealios switch.  (Read 2812 times)
Offline dgNam
« on: Sun, 04 August 2019, 22:36:05 »
I decided to use tealios switch for my next custom build. However, the tealios stock springs seem too light to me.
I’m currently using cherry mx back & clear and for this build, I’m looking for something right inbetween them.
After review some srings product on SpritDesign, I think 78 or 85 might be good for me, but I’m not sure what is the best in oder to get some thing right inbetween cherry black & clear.
So please give me some advice:
-   What is the difference between P & S (sprit design springs)? I read your description but my English level couldn’t help me to understand how they work :(
-   Please give advice, 78 or 85, S or P?
-   I planed to use GPL 205 g0 lubrication for switchs & springs, is this ok?
Thank you for your kind attention & really looking for your help.
Offline heyitsqi
Re: I need advice on springs mod for Tealios switch.
« Reply #1 on: Mon, 05 August 2019, 16:39:45 »
1. In all honesty I can't feel the difference between S and P springs in a blind test. I however used the lighter version so maybe someone can chime on the heavier ones if there's an actual noticeable different (I have the 63.5S/P, 65S/P)
2. See above about S vs P, 78 or 85 is really up to you since it's such a personal thing.
3. Should be fine.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #2 on: Wed, 07 August 2019, 22:26:20 »
Tealios come in 4 different weight springs... 62, 65, 67, 78.
I would avoid buying from SPRiT at all possible because he has scammed people in the past and still has not corrected his actions as far as i understand.
If you want something heavier than a Cherry Black, I would say yes the 85g would be a better choice.
-Dana
Offline jakereps
« Reply #3 on: Wed, 07 August 2019, 23:50:00 »
Tealios v2 only come in 67g. I think the range you provided is for Zealios.
