Author Topic: [IC] Chimera65 - 65% Gasket mounted Keyboard from CannonKeys [GB Final Info!]  (Read 92198 times)
Offline upas
Note: see the 3rd post for final info
Hi again everyone - Upas from CannonKeys here. You might remember my previous design, the Satisfaction 75. I'm here to show my newest project off - the Chimera 65. Like my other ICs, everything from the PCB to the case was designed by yours truly!
Renders: Janglad
IC FORM: https://forms.gle/VffDrtKMDX9ovuRr7
Inspiration:
The name "Chimera" for this board is super fitting. A Chimera is a creature with the head of a lion, body of a goat, and serpent's tail. Basically, a combination of a lot of different creatures. For this design, I drew inspiration from many other keyboards that I admire, and put some of those design elements together in a cohesive way.
Those boards were:
- TGR 910 (Top Right Badge)
- OTD Koala (Side Curve)
- TX boards in general (The ledge)
- TGR Jane (Dual bottom pieces)
- CA66 (Offset Arrows)
- RAMA M60-A (Back accent piece)
- Keycult No 1/65 (Mounting Style)
I also wanted to add my own design element - the bottom is engraved with a beautiful Chimera crest. It looks good in photos, but it looks way better in person! The idea was for the engraving to span multiple parts, similar to how a Chimera is an amalgamation of multiple animals.
A prototype keyboard was shown at the Seattle meetup:
Features:
- QMK and VIA Compatible PCB
- Centered USB-C Unified Daughterboard
- STM32 ARM Processor
- South facing backlight LEDs (single color)
- Poron Gasket Isolation Sandwich Mount
- Poron feet for Desk / Keyboard Isolation
- 7.5 degree typing angle
- 10.86 mm front height (ledge height)
- 17.86 mm front height (not counting ledge height)
- 7 different parts (Top, Bottom, Brass Weight, Back Accent, Bottom Accent, Badge, Plate)
- Super cool Chimera crest engraving created by Hisui
- Fixed plate - your choice of 1 of 2 fixed plates. Materials TBD based on IC.
PCB supports ISO, but plates will be ANSI. Bottom rows: 1.25/1.25/1.25/6.25/1.5/1.5 or 1.5/1.5/7U/1.5/1.5
There are a few parts I might still change, but I'll definitely keep you updated. I like the idea of the double bottom piece, but may change the bottom accent to match the shape of the crest, kind of like how the Singa Unikorn has the brass lion piece bottom. While this would mean the engraving would be limited to a single material, I think it may look a bit cleaner. Please let me know what you think in the IC
The supported layouts are as follows: http://www.keyboard-layout-editor.com/#/gists/dcf11cfb6bc9c806200939aad93e28b2
Colors:
I'm still deciding on final colors, but I have some colors in mind:
Top+Bottom / Back Accent / Bottom Accent / Badge / Bottom Weight
Black Alu / Burgundy Alu / Burgundy Alu / Sandblasted Raw Brass / Sandblasted Raw Brass (Shown in Renders)
Navy Alu / Gold Alu / Navy Alu / Sandblasted Raw Brass / Sandblasted Raw Brass
Dark Grey Alu / Lilac Alu / Lilac Alu / Sandblasted Raw Brass / Sandblasted Raw Brass
The colors won't be mix and match - they will be set color combinations.
If you have any ideas, please leave them in the comment section of the IC form! I may or may not use them.
Current Status:
Two prototypes have been manufactured, and there is a full completed functioning build including PCB. I will make one more round of minor changes, and get that prototyped. Then we will be ready for Group Buy. I want to fulfill S75 before running this board, so that should give you an idea of timeframe.
Expected Price:
This board is 7 separate parts, meaning its going to be expensive. I'd expect the final price for most editions to land somewhere in the $400-$500 range, if not more.
Acknowledgements:
There are a ton of people who helped me throughout this process, again, who I need to thank. This isn't an exhaustive list because I've received help from so many people, but I absolutely need to call out the following folks:
- Otani - Thanks for all the feedback and brainstorming help!
- 159 - GMK Red Samurai is an amazing call - thanks for the advice throughout the process
- Hisui and Rensuya - I couldn't be more thrilled with the artwork. The Chimera crest is fantastic. Thanks!
- riotonthebay - Thanks for sharing all the details I needed to replicate the no1s mounting style
- ai03 - As always, such a great source of advice
- gok - Thanks for helping me figure out some of the ways to make this design better and easier to machine
- Olivia/Wilba - Always eternally grateful for VIA
- janglad - The renders are amazing as always
- All the keyboard designers I drew inspiration from to make this board a reality
Please fill out the IC form: https://forms.gle/VffDrtKMDX9ovuRr7
« Last Edit: Sat, 09 November 2019, 21:53:30 by upas »
Offline upas
Re: [IC] Chimera65 - Cool 65% with Gaskets from CannonKeys
« Reply #1 on: Thu, 08 August 2019, 13:58:37 »
Frequently Asked Questions:
Q: The PCB supports ISO, will there be plate files available?
A: Plate files will be made public as soon as the GB closes.
« Last Edit: Thu, 08 August 2019, 14:13:39 by upas »
Offline upas
« Reply #2 on: Thu, 08 August 2019, 13:58:48 »
Hey guys, some final updates!
All units will go live for GB on November 23rd at 10AM Eastern Time.
The Group Buy will be open for 2.5 weeks. It will end on Wednesday, December 11th at midnight.
Standard Unit
$475 - 120 Total Units
Aluminum Top, Bottom - Main Color
Aluminum Back Accent, Bottom Crest, Badge - Accent Color
Sandblasted Raw Brass Weight and Plate
Colors:  (Main/Accent)
Black/Burgundy
Grey/Lilac
Navy/Silver
E-white Edition
$495 - 30 Total Units
Aluminum Top, Bottom, Bottom Crest - E White
Sandblasted Raw Brass Weight, Back Accent, Badge, and Plate
Special Edition:
$725
10 Total Units (5 Black, 5 Gold)
Note: I really tried to drive this price down, but PVD is expensive, and doesn't scale well with volume either.
"Angelic"
Gold PVD Brass Weight, Back Accent, and Badge
Raw Brass Sandblasted Plate
"Demonic"
Aluminum Top, Bottom, Bottom Crest - Black
Black PVD Brass Weight, Back Accent, and Badge
Black Carbon Fiber Plate
Extras:
Alu Badge   $12
Alu Crest $20
Alu Back   $37
Brass Badge   $12
Brass Back   $50
PCB w/ Cable + Daughterboard   $60
CF Plate   $40
FR4 Plate   $25
The extra accent pieces (Back, Badge, Crest) will be available in the following colors:
Black
Lilac
Silver
Navy
Grey
Burgundy
Every unit comes with the following 7 pieces:
Top, Bottom, Weight, Crest, Back Accent, Badge, Brass Plate
Along with:
Poron Gaskets
PCB w/ JST Cable and ai03 Unified Daughterboard
Hex Head Hardware
Bumpons
Each keyboard will also ship in a custom fitted CannonKeys hard foam carrying case, as well as a microfiber cloth.
Plates will be available in 6.25U and 7U
Extras will go live at Nov 23rd 12 AM EST (00:00), 10 hours before the group buy goes live, so that they can be added to cart ahead of time.
Remember, the group buy goes live at Nov 23rd 10 AM EST
 A google form will be sent after purchase to select options.
Estimated Delivery: May 2020
Photos:
Black/Burgundy (Photo)
Crest Detail (Photo)
Renders:
Navy/Silver:
Dark Grey/Lilac:
Black/Burgundy:
E-White/Raw Brass:
Demonic:
Angelic:
« Last Edit: Fri, 22 November 2019, 20:36:15 by upas »
Offline V. Vega
Re: [IC] Chimera65 - 65% Gasket mounted Keyboard from CannonKeys
« Reply #3 on: Thu, 08 August 2019, 14:04:22 »
This is a beautiful board, I LOVE the layout so much!
If you go with the Dark Grey/Lilac combo I will absolutely get one.
Offline Warrenified
« Reply #4 on: Thu, 08 August 2019, 14:04:50 »
Count me in Upas :D
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
« Reply #5 on: Thu, 08 August 2019, 14:06:10 »
The name suits this Frankenstein of a keyboard, it's a beauty for sure. This cannot come soon enough  :eek:
Offline BrutalBanana
« Reply #6 on: Thu, 08 August 2019, 14:17:39 »
Love the design and loving the layout.
Dark Grey Alu / Lilac Alu is what I would be most interested in. I would be also interested to see if there are more unique color combos added or maybe you get some combos based on some current popular key sets.
Offline bthezebra
« Reply #7 on: Thu, 08 August 2019, 15:27:23 »
I second this
Offline Pigjackal
« Reply #8 on: Thu, 08 August 2019, 15:28:10 »
Interested! Would hot-swap be on the table?
Offline voxkey
« Reply #9 on: Thu, 08 August 2019, 15:44:07 »
 :thumb: :thumb:
Offline Lil
    • designedbydark
« Reply #10 on: Thu, 08 August 2019, 16:29:04 »
In my opinion the burgundy colour of the render is better than the orange-red of the prototype
Offline evorus5
« Reply #11 on: Thu, 08 August 2019, 16:57:10 »
Awesome design but the layout isn't for me. Love the Canon blocker though 👍🏽
Offline Little4Real
« Reply #12 on: Thu, 08 August 2019, 18:28:30 »
Tsangan bottom row (1.5/1/1.5/7/1) and I'm in
Offline upas
« Reply #13 on: Thu, 08 August 2019, 21:23:54 »
This doesn't really work with this layout, with the offset arrows. 1.5/1/1.5/7/1/1 works on the PCB, so if you really wanted that, you could get a plate made.
1.5/1/1.5/7/1 will be available on my Brutal65 (details on that coming later), which will be a much cheaper board.
Offline bengine
« Reply #14 on: Fri, 09 August 2019, 00:19:00 »
Ne Chimera60 or Chimera75 in the pipeline?
Offline Sycomore
« Reply #15 on: Fri, 09 August 2019, 00:34:19 »
Well thanks Upas, i now know 100% that i need this keyboard to sit alongside my upcoming satisfaction.
Offline skrunk
« Reply #16 on: Fri, 09 August 2019, 02:12:46 »
Any chance of a left winkey blocker?
Loving the design by the way! :thumb:
Past Keyboards : LZ CLS, Unikorn, Noxary X65, KFE CE, HHKB Pro2, Realforce TKL
Current Keyboards: FC660C, HHKB Pro1, GSKT-00
Offline _senya
« Reply #17 on: Fri, 09 August 2019, 02:25:19 »
IMO this was the best board on that meetup. I came back to it 3 times. Interested.
Offline SoraNoTenshi
« Reply #18 on: Fri, 09 August 2019, 08:41:02 »
Ayye. Kewl stuff, unfortunately it looks like it is out of my price-range.
But definetly something cool i will follow.
Offline nasp
« Reply #19 on: Fri, 09 August 2019, 10:36:51 »
Love everything about this! Looking forward to seeing the 2nd proto
Offline breckstar
« Reply #20 on: Fri, 09 August 2019, 12:43:10 »
Every thought about making the surrounding bezel equal distance or close to equal around the keycaps particularly this build has smaller side and top bezels compared to the bottom bezel.
Offline Slimjim095
« Reply #21 on: Sat, 10 August 2019, 06:26:47 »
Would there be different color badges?
Offline upas
« Reply #22 on: Sat, 10 August 2019, 16:28:57 »
This isn't currently planned
Offline upas
« Reply #23 on: Sat, 10 August 2019, 21:53:41 »
In order to support multiple layouts on the PCB, I'm not planning on making it hotswap.
I'm glad, because that's the color I'm going with :)
Thank you for the kind words!
It's due to the offset arrows. This bezel configuration looks best given the edge.
No blockers planned!
No plans on offering different color badges as part of the GB, but I can release the 3D model for the badge so others can get some made after the GB runs.
Offline Tre3Cycl3S
« Reply #24 on: Mon, 12 August 2019, 15:45:35 »
Really like the design! Very interested.
I’m not too sure how I feel about the engraving at the bottom. I prefer something simpler (your logo seems perfect here, but it’s already on the blocker, so maybe it’ll be repetitive). Perhaps having the engraving entirely on a single piece like you mentioned might be able to get me totally onboard. But this is a minor point.
Will you be considering adding an option to add foam (between PCB and plate)?
QFR           HHKB Pro-2     JD45         VE.A                    XMIT 61-Key       JD40 Mk.II                    Realforce 87U     M65-A                 Custom:Annie      NightFox      Pearl                  E6-V2 R2                          Norbaforce
MX Blue     45g Topre        MX Blue     R5 67g Zealios     50g Hall Effect     Modded Gateron Red     55g Topre           R5 78g Zealios     62g Ergo Grey     Hako True     R9 62g Zilent     Lubed Holy Trash Panda     OG Sony BKE Domes
Offline gotham
« Reply #25 on: Tue, 13 August 2019, 13:09:44 »
All in on this one  :thumb:
Offline BanglesOtter
« Reply #26 on: Tue, 13 August 2019, 16:23:08 »
This looks pretty cool, love the badge and everything.
Bangles Otter
Don't have a build yet. Soon (tm)
Offline dannyny
« Reply #27 on: Tue, 13 August 2019, 20:30:16 »
nice logo. in for one if the price is right.
Offline DuellM
  • Keyboard Fatty
« Reply #28 on: Tue, 13 August 2019, 21:13:06 »
Any chance for an all white version, missed out on the e-white satisfaction 75 (fraud alert >:D, ended up getting the blue instead). I really want an all white keyboard  :(.
Sent from my Pixel 3a using Tapatalk
« Last Edit: Wed, 14 August 2019, 08:02:40 by DuellM »
Offline upas
« Reply #29 on: Tue, 13 August 2019, 22:43:59 »
Some renders with GMK Voyage on the Navy/Gold Chimera
Note for the logo to match the accent color, you'll have to infill with paint.
The badge will be brass.
Offline bthezebra
« Reply #30 on: Tue, 13 August 2019, 23:09:09 »
More like oof-pas
Offline cinnabolt
« Reply #31 on: Wed, 14 August 2019, 00:39:35 »
Looks soooo good. Count me in for a navy kit. Looks so good with GMK Voyage which I am excited for as well.
Offline MeloDet
« Reply #32 on: Wed, 14 August 2019, 09:16:08 »
Stop making such nice keyboards UPAS! Gonna have to buy this one too now. Looking forward to seeing the grey and lilac one.
Offline Faust_
« Reply #33 on: Wed, 14 August 2019, 11:19:08 »
Will there be split backspace support?
Offline chive_
« Reply #34 on: Wed, 14 August 2019, 11:20:47 »
Loving the look of this board! Out of curiosity, has anyone seen any sort of ergonomic advantage to the separated arrow/FN/PgUp/Down keys versus other 65% boards? I figured it'd help prevent accidental presses, but anything else there?
I noticed the new navy renders have a different spacing on the bottom row as well, I think I like that more!
Also this
« Last Edit: Wed, 14 August 2019, 11:38:50 by chive_ »
Offline nasp
« Reply #35 on: Wed, 14 August 2019, 11:43:03 »
Here's the layout options. I found it in the first post.
Offline jewel
    • none
« Reply #36 on: Mon, 19 August 2019, 23:04:16 »
Any updates on this IC?
Sent from my LG-H932 using Tapatalk
Offline Karosu
« Reply #37 on: Mon, 19 August 2019, 23:20:04 »
im in :D
Offline upas
« Reply #38 on: Mon, 19 August 2019, 23:24:39 »
I've designed a new bottom that's more similar to the Singa Unikorn. It's being manufactured and once that's done, I can move on with making decision :)
One thing I have decided - the Dark Grey / Lilac combo will definitely be offered!
Offline MeloDet
« Reply #39 on: Fri, 23 August 2019, 10:35:27 »
That's awesome! Looking forward to seeing some renders of that colorway!
Offline DasGnome
« Reply #40 on: Fri, 23 August 2019, 10:58:53 »
Dang, might finally have to sell some stuff to fund this beauty!
Offline blitz
« Reply #41 on: Fri, 23 August 2019, 12:55:20 »
I know it's not mix and match but would there be extra back accent pieces?
Offline iammeuru
« Reply #42 on: Fri, 23 August 2019, 21:01:48 »
So I'm late to the party chatting about this here, but having seen this at the seattle meetup, and having a lot of time with it after the meetup, I have to say that this is an absolute must buy for me this year... from here to the end of the year, there are literally three must buy boards, and this is one of them... it's awesome!
Offline Tekniqs
« Reply #43 on: Fri, 23 August 2019, 22:51:49 »
this board is for sure on my list as well.
what's the other two if you don't mind me asking?
Offline forevermadrigal
« Reply #44 on: Sat, 24 August 2019, 17:06:00 »
Is the layout on the proto going to be supported?
Offline upas
« Reply #45 on: Sat, 24 August 2019, 18:40:55 »
I'll definitely consider this. I really like the set colors, but this would allow people to make their own combinations without having to pay for 2 boards.
Yes, all of these layouts will be supported:
Offline child
« Reply #46 on: Sun, 25 August 2019, 03:26:48 »
Can a combination of these be used, eg. 1.25, 1.25, 1.25, 6.25, 1.5, 1.5 ?
Offline bthezebra
« Reply #47 on: Sun, 25 August 2019, 08:11:40 »
Please do consider it :)
Offline nasp
« Reply #48 on: Sun, 25 August 2019, 10:00:09 »
Yes, according to the KLE that should be possible
Offline FredBananaz
« Reply #49 on: Sun, 25 August 2019, 18:04:15 »
Ooh, this looks good. Definetly interested in this keyboard
