Author Topic: MassDrop ALT worth saving or time to build new?  (Read 2498 times)
Offline terminaldawn
« on: Sun, 18 August 2019, 14:27:43 »
I have a MassDrop ALT low profile with MX Browns.  Its SUPER Pingy... I heard I can put Zealios switches, lube them and add some foam in bottom of case to fix... but if I am going to go through all that trouble I am considering just building instead.
My requirements are as follows:
- 65%
- RGB
- USB C
- Hot Swappable Switches
- No pingy noises, nice solid sound...
1. Should I try to fix up the MassDrop ALT, is it fixable ?
2. If I go and just build something new is there anything else I should consider that meets my requirements (I was looking at the DZ65RGB / DZ68RGB)?
Thanks for any help in advance!
Offline 1391401
  • MX CLEAR
Re: MassDrop ALT worth saving or time to build new?
« Reply #1 on: Sun, 18 August 2019, 16:29:28 »
I've never experienced pinging so I googled it and found this video -
weirdly enough his "after" results sound exactly like the tofu I just built and I didn't have to do any of that.  I guess my point is he built that board too and was unhappy - probably the best approach is to really understand what the problem is and fix it.
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
