Author Topic: green alps vs linearized white alps  (Read 4280 times)
Offline TeacherGeek
« on: Tue, 20 August 2019, 18:50:33 »
Do people know what would be the difference between the two?
Offline treeleaf64
    • treeleaf64
Re: green alps vs linearized white alps
« Reply #1 on: Thu, 22 August 2019, 22:41:51 »
There might be  a difference at the little tactile bump at the bottom
Everyone must pay the cat tax
Offline Sup
« Reply #2 on: Fri, 23 August 2019, 13:57:30 »
All linear Alps switches have a very faint tactility when bottoming out.
current
Coming soon
Offline Sup
« Reply #3 on: Fri, 23 August 2019, 13:58:48 »
The difference is weight basically. Linear alps are just Alps switches with out a tactile leave or a clicky one. Only difference would be spring weight if you compare Green alps to Linearized white Alps.
current
Coming soon
Offline 4sStylZ
« Reply #4 on: Fri, 23 August 2019, 16:36:24 »
Also there is no damper on the oem green.
https://deskthority.net/wiki/Alps_SKCL_Green
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #5 on: Fri, 23 August 2019, 17:23:41 »
I was assuming OP was talking about linearizing clicky white ALPS, not damped whites. Although linearizing some damped whites may make for a decent silent linear switch. Shame those have the thinner housings.
Offline garbo
« Reply #6 on: Sat, 24 August 2019, 14:12:32 »
With spring weight accounted for, linearised blacks from a NIB AT101W and the Taobao NOS SKCL yellows feel more or less the same to me, and both are better than the SKCL greens I have simply due to the fact that those aren't super clean.
There are people that would tell you that the older housings are better or that tall switchplates make all the difference, but I don't really buy it. Best to use whatever's available in the best condition, unless you want rare/old switches for the cool factor (which, to be fair, if you're using linear Alps over MX at this point isn't all that unlikely).
Use SPRiT's springs at your preferred weighting if you're OK with his business practices.
