Author Topic: 5 pin-din keyboard, how can i use it on a modern pc?  (Read 8405 times)
Offline SuccnYeet
« on: Wed, 04 September 2019, 21:03:37 »
I have a keyboard with what looks like a 5 pin male din connector. My PC has  ps2/usb ports,  will a converter allow this to work with my pc? or would it need some sort of input converter?
Offline invariance
  • ...here with all the other boson's
Re: 5 pin-din keyboard, how can i use it on a modern pc?
« Reply #1 on: Thu, 05 September 2019, 03:42:47 »
An AT to ps2 connector should work but more info on the board would help.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline yui
« Reply #2 on: Thu, 05 September 2019, 07:04:49 »
If a little diy does not scare you, there is Soarer's converter, I don't know if there is anything newer with as many features
https://geekhack.org/index.php?topic=17458.0
It should be giving you full nkro and the ability to remap all keys over usb.
Or i heard that simple passive AT to PS/2 adapters exist and work as they use the same protocol, never tried myself.
And maybe other peoples with more experience could help you a lot more with more information about your board.
Offline natAT
« Reply #3 on: Thu, 05 September 2019, 07:57:22 »
I'm only reiterating the good advice, already given by others here.
If lucky, you'll only need a simple DIN-5 to PS/2 converter. Any labels on the keyboard (or documentation etc) indicating "AT" (in reference to the AT protocol) may be a positive indicator this is what's needed.
If it's what you need, then (on AT) DIN-5 to PS/2 adapters are cheap. PS/2 and AT utilize the same protocol and PS/2 and DIN-5 connectors (on AT) are electrically compatible. So adapters are fairly simple (just a wiring conversion) .
Specifying the exact board would be useful.
Offline SuccnYeet
« Reply #4 on: Thu, 05 September 2019, 08:34:37 »
Apologies, of course I should have specified, it’s an IBM Model M122 1986 model
Offline GlennL42
« Reply #5 on: Thu, 05 September 2019, 09:11:47 »
Tough luck for you, IBM Model M122 uses a different protocol and can't be used over PS/2 port with just passive 5 Pin - DIN to  PS/2 adapter, you'll have to use special converter that you can either buy from Orihalcon or make one yourself
Edit: you should try ask around to see if someone in Australia is able to wire one up for you for a fee, will be far cheaper than buying pre-made one
« Last Edit: Fri, 06 September 2019, 04:37:36 by GlennL42 »
Offline yui
« Reply #6 on: Thu, 05 September 2019, 09:46:54 »
I thought only the RJ45 version was completely incompatible and needed the use of a converter i thought other versions only used code set 3 and were somewhat compatible(at least the common alpha parts), I might be wrong but the adapters can be cheap.
And you could even try to get a din 5 plug and plug wires directly into the motherboard sockets, even cheaper but way more risky.
Your choice really.
My only experience with actual IBM model M is a RJ45 122 keys from 1995 and simple passive adapter did not work.
Offline SuccnYeet
« Reply #7 on: Fri, 06 September 2019, 00:15:56 »
God damnit they’re so expensive to get to Australia  :(
« Reply #8 on: Fri, 06 September 2019, 07:20:38 »
Orihalcon makes adapter cables for each type of plug, but yes, they are pricey.
Soarer, in his genius, wrote his firmware to accommodate almost all of the common M/F terminals, automatically. I have always used the name-brand Teensy and they always work perfectly, first go. There are cheap knock-offs on ebay for $5, but they are harder to flash and program, as I understand it.
- Plato
