Author Topic: GENOVATION 35 key programmable num pad $55  (Read 4639 times)
Offline Infinite north
« on: Fri, 04 June 2010, 03:20:54 »
This has cherry switches of some sort in it.
Momentary contact with tactile sound
that could mean blues.
http://www.itdeal.com/p-6625-genovation-682u-35-key-usb-ke.aspx?CAWELAID=517847117
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #1 on: Fri, 04 June 2010, 08:57:04 »
Great, thanks for sharing! Just ordered two of this pads... ^^
Tried to get em elsewhere for some time (also from Genovation directly), but it would have cost at least twice as much!
A Ghost From The Past
  • ~ BOOO ~
« Reply #2 on: Fri, 04 June 2010, 09:12:47 »
Black?
Well, that's the first thing I'll do, painting the case black and replacing the caps with black ones, lol!
  • ~ BOOO ~
« Reply #3 on: Fri, 04 June 2010, 09:21:36 »
Operating force is 0.686N{79gf}
Sounds more like black ALPS... ;D
But yeah, blues are out of question it seems!
Offline JBert
« Reply #4 on: Fri, 04 June 2010, 14:20:58 »
I find it odd that this site has the unit for a third of the price, Fentek for example sells it for more than $140.
Any other keypads out there that also have 35 keys but are somewhat cheaper than $150?
The storage list:
Currently ignored by: nobody?
[/SIZE]
  • ~ BOOO ~
« Reply #5 on: Fri, 04 June 2010, 17:05:04 »
Fully functional item that has been tested and refurbished. It could be packaged in a generic white/brown box or original retail box. Some imperfections are possible. No deep scratches or dents.
And as I paint it black anyway minor scratches are no problem...
Offline kriminal
« Reply #6 on: Fri, 04 June 2010, 17:25:53 »
hmm black switches.... interesting
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
  • ~ BOOO ~
« Reply #7 on: Mon, 14 June 2010, 08:25:29 »
Just received the two keypads I ordered, and now I know whats "wrong" with em... It's just the color! Instead of beige/light-grey, like on the pictures, they are dark grey, actually the same grey as the reply options box of this forum, lol. Perhaps they added too much color to one of their batches? Doesn't matter. I dislike beige anyway, dark grey is much cooler, also I already planed to spray-paint em black... Will post images and/or review late! :)
  • ~ BOOO ~
« Reply #8 on: Mon, 14 June 2010, 10:19:23 »
  • ~ BOOO ~
« Reply #9 on: Mon, 14 June 2010, 10:56:05 »
You know the saying...
Offline Rajagra
« Reply #10 on: Mon, 14 June 2010, 11:18:47 »
Quote from: TheSoulhunter;192981
"Look what happens to the early worm."
Offline didjamatic
« Reply #11 on: Mon, 14 June 2010, 12:10:23 »
"If you're a bird, be an early bird.  If you're a worm, sleep late" - Shel Silverstein
