Author Topic: [IC] KAT Atlantis | UPDATE #12: Rama Cap & Artisans 2/27  (Read 363227 times)
Offline Rilow
Re: [IC] KAT Atlantis | UPDATE #3: More kit changes 11/26/19
« Reply #200 on: Thu, 16 January 2020, 15:11:21 »
Shut up and take my money!
Offline Shutter_Shock
« Reply #201 on: Fri, 17 January 2020, 02:53:07 »
Definitely in for at least alphas + text mods. Novelties maybe depending on the state of my budget at the time of GB. I'd probably only use like two or three novelties, so idk about that large a set. They're awesome though!
Offline YMwoo
« Reply #202 on: Fri, 17 January 2020, 22:09:25 »
I'm totally late to the party. Hopefully the timing and the price is right but I'm totally down for Korean Alpha and Icon Mods. I've been looking for mono Korean legends for awhile.
Btw, I'm sorry if I missed this, but personally I think Icon Mods set with Alt Alphas color would look good together with the normal Alpha color (dark alpha, brighter mods).
Offline Korgonaut
« Reply #203 on: Mon, 20 January 2020, 11:51:45 »
Definitely digging the design and this would be my first KAT profile set. Can't wait to see the GB for this!
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
Re: [IC] KAT Atlantis | UPDATE #4 GB date & Vendors
« Reply #204 on: Mon, 20 January 2020, 13:15:58 »
Update #4: Groupbuy starts on March 1st!
Vendors
US: Cannonkeys
EU: Mykeyboard
Oceania: DailyClack
Asia: zFrontier
Canada: Deskhero
New renders and some changes are coming soon..
« Last Edit: Thu, 23 January 2020, 23:55:01 by Rensuya »
Offline nasp
« Reply #205 on: Mon, 20 January 2020, 15:22:03 »
I'd love to see a 40's kit with traditional icon or text mods please and thank you
Offline sevenseacat
« Reply #206 on: Mon, 20 January 2020, 20:09:42 »
Any word on added proxies? Would love to see DailyClack host this for AU!
edit: derp that was posted two posts above this one, I only looked in the first post :D
Offline DrKlaw
« Reply #207 on: Tue, 21 January 2020, 00:28:35 »
It’s a shame the 40’s/Ortho kit doesn’t have a 1u accent enter key, nor any accent space bars. On my board (ErgoDash) I would only get one accent color key (Escape) in the entire kit.  Even buying the creatures kit would only get me one more 1u accent key! With the large number of ortho boards that use 1u enter it would make a big difference to have an accent color option there.
ErgoDash
Offline Rensuya
« Reply #208 on: Tue, 21 January 2020, 00:35:47 »
I see your point, I could possibly still add one. Which would better in your opinion R2 or R1 enter?
« Last Edit: Sat, 25 January 2020, 20:08:32 by Rensuya »
Offline piit79
« Reply #209 on: Tue, 21 January 2020, 01:16:21 »
I see your point, I could possible still add one. Which would better in your opinion R2 or R1 enter?
Another ortho user who likes accented Enters here ;) That would be great! Enter on Planck/Preonic would be R2 (second row from the bottom to avoid any confusion ;)
Offline DrKlaw
« Reply #210 on: Tue, 21 January 2020, 01:55:18 »
That’s awesome, thanks! I’d say R2 will make the most people happy (including me).
Would you consider swapping the plain space bars for accented ones? I can understand that with so many sizes it might not be possible to have both, but if we have to choose one I think most people would prefer the accent color. Then we can do Esc, Space, and Enter like the other kits. After all, isn’t the point of a kit like this to get that pop of color on the accent keys?
ErgoDash
Offline piit79
« Reply #211 on: Tue, 21 January 2020, 02:06:04 »
Well, I'm not sure sure that's actually true... While I personally also like accented spacebars for ortho very much, we must be impartial and don't push our preferences on others :)
That said, I'm all for it if there's support!
Offline nasp
« Reply #212 on: Tue, 21 January 2020, 02:13:14 »
Leave the accent bars out if the kit. If you want accents, which most do, just buy the spacebar kit. I doubt it will cost very much.
Offline DrKlaw
« Reply #213 on: Tue, 21 January 2020, 02:22:36 »
I don’t understand the logic. If most *do* want the accents, why leave it out of the kit?
ErgoDash
Offline Symbiote
Re: [IC] KAT Atlantis | UPDATE #2: Deskmat added & more kit changes!
« Reply #214 on: Tue, 21 January 2020, 03:13:56 »
Ergo
Personally, I'd prefer:
- two 1U R1 shift keys
- a 1UC R1 space key
- a 1U R1 enter key
- a 1U R1 backspace key
I appreciate the feedback and interest in interest in my set! I will look into updating the ergo kit. The French kit key you pointed out was an error I forgot to fix.
Excellent, everything I asked for! Now I have to buy it :-)
Offline Rensuya
Re: [IC] KAT Atlantis | UPDATE #5: New Novelties 1/24/2020
« Reply #215 on: Thu, 23 January 2020, 23:58:27 »
Update #5: New novelites kit!
I have made a few changes to the novelties kit. You will find I cut the busy looking R1 1.5 novelties and added some more simple designs.
New renders showcasing a lot of the new novelties and alternative alpha kits are coming soon!
« Last Edit: Sun, 26 January 2020, 21:33:37 by Rensuya »
Offline TonyPia
« Reply #216 on: Fri, 24 January 2020, 00:26:10 »
Awesome! It looks way better than before.
Offline nasp
« Reply #217 on: Fri, 24 January 2020, 00:42:11 »
Two reasons:
1. Not everyone wants the bar. Most might, but then for those that don't you are adding an extra set of bars to the 40's/ortho kit.
2. If you put the mini bars in the 40's/ortho kit, then those who have boards larger than 60% that use mini bars will have to buy the 40's/ortho kit, which is at least double the cost of a spacebar kit.
Offline Shaphyna
« Reply #218 on: Sun, 26 January 2020, 20:28:51 »
Hoping that ILUMKB could be a possible vendor for Asia or Southeast Asia?
Offline Rensuya
Re: [IC] KAT Atlantis | UPDATE #6: Final Kits 1/26
« Reply #219 on: Sun, 26 January 2020, 21:37:09 »
Update #6: Final kits are up & Groupbuy starts on March 1st! :cool:
Vendors
US: Cannonkeys
EU: Mykeyboard
Oceania: DailyClack
Asia: zFrontier
Canada: Deskhero
Final renders and prices are coming soon..
« Last Edit: Sun, 26 January 2020, 21:42:20 by Rensuya »
Offline sevenseacat
« Reply #220 on: Mon, 27 January 2020, 00:16:03 »
awesomeeeeeee
Offline YMwoo
« Reply #221 on: Mon, 27 January 2020, 21:41:52 »
2 questions:
  • Will there be any cable collaboration
  • Just to be sure, there's no Enter for ergo kit? both normal and accent.
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #222 on: Tue, 28 January 2020, 01:26:18 »
2 questions:
Iirc there have been talks about cable collabs.
Offline Symbiote
« Reply #223 on: Tue, 28 January 2020, 03:28:39 »
There's a 1U enter (next to the 1U space), but the only 2U vertical enter I see is in the numpad kit.
Offline YMwoo
« Reply #224 on: Tue, 28 January 2020, 05:33:12 »
thanks! i definitely missed that.
though personally i was looking for 1.5u key
Offline Rensuya
Re: [IC] KAT Atlantis | UPDATE #7: New Deskmat 1/28
« Reply #225 on: Tue, 28 January 2020, 21:27:25 »
Update #7: New Deskmat, enter the Kraken! :cool:
Offline YMwoo
« Reply #226 on: Tue, 28 January 2020, 21:46:58 »
Personally prefer the old deskmat much better
Offline Kawamashi
Re: [IC] KAT Atlantis | UPDATE #7: Enter the Kraken!! 1/28
« Reply #227 on: Wed, 29 January 2020, 02:02:32 »
So do I !
Offline Kawamashi
« Reply #228 on: Wed, 29 January 2020, 08:25:52 »
The old deskmat is not an option any more ?  :(
Offline rewke
« Reply #229 on: Wed, 29 January 2020, 11:01:27 »
I for one much prefer the new one, but different strokes for different folks!
Offline Rensuya
« Reply #230 on: Wed, 29 January 2020, 11:49:03 »
Working on another deskmat option that's a bit more minimal to go along with the kraken.
Offline DrHigsby
  • The doctor is in.
« Reply #231 on: Wed, 29 January 2020, 12:21:32 »
The kraken deskmat just ramped my interest up to 11. Great work!
Offline octix
« Reply #232 on: Wed, 29 January 2020, 14:35:46 »
Woah, that new deskmat is amazing!
Discord: octix#0478
Offline Rensuya
« Reply #233 on: Thu, 30 January 2020, 12:01:48 »
Let me know what you guys think of this possible 2nd deskmat to go with the Kraken!
Offline SuddenlyDonkey
« Reply #234 on: Thu, 30 January 2020, 12:15:58 »
That original deskmat was money!  Is the original, off the table?  Nothing wrong with the newly added ones but a disappointment as I was looking forward to the original.
Offline Vizir
« Reply #235 on: Thu, 30 January 2020, 12:27:03 »
What did the original look like?
Sent from my Pixel 4 XL using Tapatalk
« Reply #236 on: Thu, 30 January 2020, 15:20:15 »
Offline Vizir
« Reply #237 on: Thu, 30 January 2020, 15:33:59 »
Thanks
Offline Kawamashi
« Reply #238 on: Thu, 30 January 2020, 16:01:08 »
OG deskmat was hot as f**k, latest one is nice, the Kraken inspired one is not for me.
Offline Rensuya
« Reply #239 on: Thu, 30 January 2020, 16:30:12 »
https://www.strawpoll.me/19325275/r
Here I made a simple little straw poll for me to gather some feedback
Offline Surefoot
« Reply #240 on: Thu, 30 January 2020, 17:04:28 »
Release the Kraken !!
Offline vannams
« Reply #241 on: Fri, 31 January 2020, 00:58:18 »
Is there any way we can also have actual creatures that will fit r2,3,4 (column keys) in the creatures kit. What really got me interested in this set was the chimera65 render with creatures as novelties. If you are offering both the kraken mat and the runic mat, having actual creatures would fit the kraken desmat more imo (then people can use runic novelties with the rune deskmat).
Offline kungpaogao
« Reply #242 on: Wed, 05 February 2020, 00:13:49 »
I love the colors of this key set, but I really don't like the icon mods. It would be nice if there was a more standard icon mod set, instead of this "script" stuff.
Offline Jhambone9160
« Reply #243 on: Wed, 05 February 2020, 08:30:44 »
The icon mods are one of my favorite parts of this set.
The only thing I do not care for is the text colored homing bar on the homing keys. looks cheap.
« Last Edit: Wed, 05 February 2020, 08:32:33 by Jhambone9160 »
Offline eskimojo
    • KeycapLendar
« Reply #244 on: Wed, 05 February 2020, 09:29:20 »
That's just to show which keys will be homing, the actual keys won't have that.
Offline Rensuya
« Reply #245 on: Wed, 05 February 2020, 09:34:40 »
There is a text modifiers kit for those who don't like the atlantean icons.
Offline Bubblegum
« Reply #246 on: Wed, 05 February 2020, 10:02:03 »
Homing seem to be missing for numpad 5. At least the bar isn't pictured.
Offline piit79
Re: [IC] KAT Atlantis | UPDATE #8: New renders! 2/5
« Reply #247 on: Wed, 05 February 2020, 17:26:27 »
Unfortunately not for 40s/Ortho... Understandable but regretable :)
Offline Rensuya
« Reply #248 on: Wed, 05 February 2020, 17:27:12 »
Update #8: Some revised and new renders are on original post! :cool:
More renders and prices are coming soon..
« Reply #249 on: Fri, 14 February 2020, 12:14:02 »
Any updates on pricing?
