Author Topic: [IC] love tkl - GB INFO POSTED https://geekhack.org/index.php?topic=102775.0  (Read 25711 times)
Offline elli
love tkl lv80
https://forms.gle/vgRG167w8KvSUxv46
https://discord.gg/3jKPs6g
gb info
design
corsa based case. clean and soft filleted bezels of top case, with interior chamfer surronding the keys. sides are flat and minimal. polypropylene fixing plate is top mounted by 7 nylon screws. the boards front starts at 18mm and inclines at a low angle to allow for a more comfortable typing experience.
weight sits into the case and has a fitting shape of a heart engraved on the back. weight will be uncoated to let patina and have character.
details
case: case is 6063 alu, weight is sand-blasted brass left uncoated
plate: 1.5mm polypropylene fixed wkl plate ( support for stepped and unstepped caps lock, plate files will be provided after gb )
weight: unbuilt ≈ 1.8kg
angle: 3.7°
pcb: uses h87a pcb, not included to save on price and shorten timeframe for shipping ( please be aware of this, reminder look out for hiney's gb that will be happening soon )
unit count: 25-30
colors:
price:
  • base = 350$
  • extra plate = 35$
shipping price:
  • us ≈ 30$
  • rest of na ≈ 50$
  • eu ≈ 65$
  • asia ≈ 75$
  • oceania ≈ 85$
gallery
updates
sep 3rd 2019: proto ordered
sep 16th 2019: updated plate with fillets and actual non meme relief cuts, as well as updated image of plate and added side and back views of the board
sep 18th 2019: picture of blue color chip added. board more so back to original design, 6.7 -> 3.7 degrees. plate back to original, weight redesigned to be reasonable. update estimated board price. no longer selling with pcb to save on costs.
sep 20th 2019: picture of pink proto added as a link on the color. linked my discord i created for updates and random chat etc.
sep 23rd 2019: added photos of proto.
sep 26th 2019: proto has been shipped will be receiving sometime in the following days.
sep 27th 2019: the proto has been received and built. typing video added.
« Last Edit: Sat, 05 October 2019, 11:54:39 by elli »
Offline zekkin
  • my entire life was unlimited zekk works
Re: [IC] love tkl
« Reply #1 on: Mon, 16 September 2019, 11:39:42 »
tips:
- nix the .475mm gap between the plate and top piece (you can offset the plate diameter by another .75mm or so and have no gap)
- leave the 1u switch cutouts between the 1.5u modifiers on the bottom row
- use https://kbplate.ai03.me instead of swillkb for plate generation
- the spacebar cutouts are ridiculous lol
that's all i can see at a glance, hope everything goes well
Offline elli
Re: [IC] love tkl
« Reply #2 on: Mon, 16 September 2019, 11:44:00 »
tips:
I used ai's plate gen just removed fillets when generating it as its easier to work with that way, but will fillet switches and stab cutouts for final and will add the 1u switch cutouts again. Spacebar cutouts are ridiculous on purpose to meme the Korean spacebar relief cutouts lmao.
Offline MoarCoffeePlzzz
  • Formerly Deeptek
Re: [IC] love tkl
« Reply #3 on: Mon, 16 September 2019, 13:29:01 »
Would like to see some profile and back angle shots.
Offline elli
Re: [IC] love tkl
« Reply #4 on: Mon, 16 September 2019, 13:36:47 »
Ill get some renders for those shots going once I am done editing the plate design.
Offline sleepy
Re: [IC] love tkl
« Reply #5 on: Mon, 16 September 2019, 15:31:54 »
Will wait for the proto to see how those sharp looking interior corners come out, but otherwise looks really nice!
Offline elli
Re: [IC] love tkl
« Reply #6 on: Mon, 16 September 2019, 15:58:41 »
:D
Offline eniigma
    • Storefront:
Re: [IC] love tkl
« Reply #7 on: Mon, 16 September 2019, 16:06:29 »
I dig this. Interested! FCFS or...?
Offline elli
Re: [IC] love tkl
« Reply #8 on: Mon, 16 September 2019, 16:11:33 »
indeed fcfs
Offline Myoth
Re: [IC] love tkl
« Reply #9 on: Mon, 16 September 2019, 16:12:00 »
I dig it !! yes, please :)
Offline elli
Re: [IC] love tkl
« Reply #10 on: Mon, 16 September 2019, 16:18:15 »
Offline rrsurmeier
    • Attachments
Re: [IC] love tkl
« Reply #11 on: Mon, 16 September 2019, 17:43:52 »
Like the idea. Adding an e-white version would sell it for me tbh.
Offline bonk
  • Bonkre 55g
Re: [IC] love tkl
« Reply #12 on: Mon, 16 September 2019, 19:02:39 »
Love it. Just here to show my support! ;)
Shattered Visions of Endgame
Offline elli
Re: [IC] love tkl
« Reply #13 on: Mon, 16 September 2019, 21:16:57 »
Ye I am fairly set in stone with the colors I am using.
Offline Tommicorn
Re: [IC] love tkl
« Reply #14 on: Mon, 16 September 2019, 23:01:54 »
I really love the blue color! I am very interested
Offline SUB01
Re: [IC] love tkl
« Reply #15 on: Mon, 16 September 2019, 23:17:33 »
I think I like the design, but the super harsh lighting on the renders make it hard to actually make out any details of the board. Are there better renders available?
Offline elli
Re: [IC] love tkl
« Reply #16 on: Mon, 16 September 2019, 23:20:56 »
Yeah the renders I did for the back and the side are fairly harsh. I have better renders for a side profile and should post that instead and will get a better render for the back side.
Offline montereysamuel
Re: [IC] love tkl
« Reply #17 on: Tue, 17 September 2019, 03:35:07 »
Will it be Alps compatible?
Offline elli
Re: [IC] love tkl
« Reply #18 on: Tue, 17 September 2019, 03:45:02 »
I will be releasing the plate file once GB has completed, will provide after all invoices have been paid, which means you will be able to make an Alps plate but you'll have to source hiney's Alps PCB yourself.
Offline zekkin
Re: [IC] love tkl
« Reply #19 on: Tue, 17 September 2019, 04:48:26 »
« Last Edit: Tue, 17 September 2019, 07:25:25 by zekkin »
Offline julianquack
Re: [IC] love tkl
« Reply #20 on: Tue, 17 September 2019, 07:53:01 »
Will there be a shipping option for Australia :o???
Offline Honey
Re: [IC] love tkl
« Reply #21 on: Tue, 17 September 2019, 09:36:26 »
very much a fan of this, been waiting for a TKL groupbuy to pop up after the U80A but none interested me until now.
« Last Edit: Tue, 17 September 2019, 11:44:24 by Honey »
Offline elli
Re: [IC] love tkl
« Reply #22 on: Tue, 17 September 2019, 10:37:13 »
yeah kinda didnt think about aus/nz when making this post lmao
Offline nathanchere
Re: [IC] love tkl
« Reply #23 on: Tue, 17 September 2019, 15:20:46 »
Too bad about the WKL only. Looks great otherwise
Offline eniigma
    • Storefront:
Re: [IC] love tkl
« Reply #24 on: Tue, 17 September 2019, 21:57:12 »
estimated timeframe?
Sent from my SM-G973U using Tapatalk
Offline elli
Re: [IC] love tkl
« Reply #25 on: Wed, 18 September 2019, 07:51:10 »
Once I receive my prototype and make sure everything checks out, and once I am fairly certain of a final revision I think it will be ready. So I'm assuming 2 or so weeks after my prototype has been received.
Offline badboy731
Re: [IC] love tkl
« Reply #26 on: Wed, 18 September 2019, 15:11:28 »
congrats! loved it when you posted it in the discord. Will def be watching
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline Vaii
  • wat
Re: [IC] love tkl
« Reply #27 on: Fri, 20 September 2019, 05:43:10 »
Oof this is looking good. Interested to see more of it once the proto arrives!
wtb dark plushberry (mx) bbv2 / starcluster (mx) bbv2
Offline darko
Re: [IC] love tkl
« Reply #28 on: Fri, 20 September 2019, 07:00:33 »
nemaš ISO dostupan?
Offline elli
Re: [IC] love tkl
« Reply #29 on: Fri, 20 September 2019, 07:41:39 »
nemaš ISO dostupan?
no iso available with plate that will come with the board, but you can edit the plate files i will provide to allow for it.
Offline darko
Re: [IC] love tkl
« Reply #30 on: Fri, 20 September 2019, 07:45:01 »
aight, thanks for the reply.
I would really like this pink one for Bliss once it arrives, but with import fees + PCB + extra plate (about 70€ for aluminium TKL) is probably too rich for my blood....
Offline audiosl4ve
  • Just slave
Re: [IC] love tkl
« Reply #31 on: Fri, 20 September 2019, 07:49:20 »
You can always use plateless
Offline elli
Re: [IC] love tkl
« Reply #32 on: Fri, 20 September 2019, 11:13:05 »
um,, no ?  :blank:
Offline IOVERCALLHISTIOCYTES
Re: [IC] love tkl
« Reply #33 on: Fri, 20 September 2019, 16:32:49 »
someone just saw my screen while I was looking at these. Can I attempt to buy 2
(one pink, one blue) in the one minute that this group buy is gonna run for? I solemnly swear its not for resale.
Offline elli
Re: [IC] love tkl
« Reply #34 on: Fri, 20 September 2019, 19:15:35 »
umm,, it really depends. if you are putting in a purchase for someone else i would expect it to be delivered to two different addresses, and if youre able to put in two different orders that are clearly going to two different people that should be fine with me. if you were going to get it shipped to the same address i wont allow that, only one board per address.
Offline Honey
Re: [IC] love tkl
« Reply #35 on: Fri, 20 September 2019, 21:00:50 »
I assume the kanji that was planned for the plate was scrapped? Was it too font-like as you mentioned in the past?
Re: [IC] love tkl
« Reply #36 on: Fri, 20 September 2019, 21:25:02 »
Copy that. She may not be interested in sitting around and F5ing but we’ll see. Thank you!
Offline elli
Re: [IC] love tkl
« Reply #37 on: Sat, 21 September 2019, 12:47:41 »
answered on the discord for you but will answer for others, scrapped as it didnt look the greatest and the person i commissioned cancelled.
yeah like i said you can place it for them, but clearly needs to be different addresses, name and email.
Offline vaughno
Re: [IC] love tkl
« Reply #38 on: Sun, 22 September 2019, 19:18:37 »
Cute
Unikorn | Orion v3 | GSKT-00
Offline appaboy
Re: [IC] love tkl
« Reply #39 on: Wed, 25 September 2019, 00:21:27 »
very cute, i love the uncoated weight to get patina'd  :thumb:
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline woodruff
Re: [IC] love tkl
« Reply #40 on: Wed, 25 September 2019, 02:09:54 »
nemaš ISO dostupan?
spends 400 usd for a keyboard
has to waste time making his own plate
Offline Esheu2
Re: [IC] love tkl
« Reply #41 on: Wed, 25 September 2019, 03:23:51 »
nemaš ISO dostupan?
It's almost as if you don't have to spend money on it if it doesn't suit you.
Ojou
Offline eniigma
    • Storefront:
Re: [IC] love tkl
« Reply #42 on: Wed, 25 September 2019, 06:10:58 »
nemaš ISO dostupan?
it's all up to the GB runner, people design keyboards that suit their needs. if you need ISO, you should design one that supports it. otherwise, don't blast the runner for not supporting your needs.
Offline woodruff
Re: [IC] love tkl
« Reply #43 on: Wed, 25 September 2019, 06:49:16 »
The whole point of interest checks, is to raise interest and suggestions. It happens in all the IC threads, exactly in this subforum, is this new for you?  :)) :)) :)) :)) :))
Offline eniigma
    • Storefront:
Re: [IC] love tkl
« Reply #44 on: Wed, 25 September 2019, 11:25:31 »
there are better ways to "raise interest" than making a witty joke at the runner's expense.
Offline elli
Re: [IC] love tkl
« Reply #45 on: Wed, 25 September 2019, 13:59:16 »
Well I have indeed gained plenty of interest and have gotten some suggestions, like from zekkin, and fixed those things. This board was designed mainly to be fixed because it's my board and also it lowers the price of machining as they don't need to program their CNC machines for both plate files, so it doesn't really make sense including when I am only doing 25 boards.
Offline Esheu2
Re: [IC] love tkl
« Reply #46 on: Wed, 25 September 2019, 15:50:02 »
What you were doing was not making a suggestion. What you were doing was being abrasive, entitled, and sarcastic towards a designer who owes you nothing
Is being a decent human a new concept to you?
Ojou
Offline SUB01
Re: [IC] love tkl
« Reply #47 on: Wed, 25 September 2019, 15:51:25 »
M8 not to bash you or anything, but you aren't entitled to any changes made to the final product. What makes it in and/or doesn't is dependent on the GB runner's discretion. The runner was being nice and offered to make you a plate if you provided the designs, yet instead of doing anything productive you only made fun of his/her sincerity in making this project succeed.
Offline elli
Re: [IC] love tkl
« Reply #48 on: Sat, 28 September 2019, 23:46:26 »
thought id mention that the corners arent a problem on the proto, they are ever so slightly rounded due to the fact the board is blasted then anodized.
« Last Edit: Sun, 29 September 2019, 04:22:41 by elli »
