Author Topic: [IC] GMK Sixes - A reversed Nines.  (Read 180856 times)
Offline candravamsa
Re: [IC] GMK Sixes - A reversed Nines. READ THE OP 11/16/20
« Reply #150 on: Sun, 27 December 2020, 11:13:20 »
Will sell kidney if there is a GB start estimate.
GB will start in February 2021 according to Emir's Laboratory on Discord.
You in the market for a real solid kidney? I mean this thang is premo.
Offline Grindbox
« Reply #151 on: Wed, 30 December 2020, 14:48:59 »
Hype!  Y'all think GMK will have their row 2 texture issues sorted out by then?
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #152 on: Wed, 30 December 2020, 18:18:21 »
Sorry, changed to June not to clash with gmk umka in February. I'll make a separate ic!
Offline candravamsa
« Reply #153 on: Thu, 31 December 2020, 12:10:53 »
Well that is kind of a relief, squirrelling away funds now.
Offline Grindbox
« Reply #154 on: Wed, 06 January 2021, 17:27:46 »
Gives the wallet a second to breath after the holidays, am I right?
Offline candravamsa
« Reply #155 on: Sun, 10 January 2021, 05:37:03 »
Absolutely. Balancing prototypes, GB, general keyboard parts and just life cost has been interesting to say the least.
Offline koolaidpapa
« Reply #156 on: Sun, 10 January 2021, 18:03:57 »
I've got nines, now I need this to feel complete
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
« Reply #157 on: Mon, 18 January 2021, 19:35:29 »
ohmy ohmy ohmy - that makeup set is all I need in life - will join!
Offline DERBS
  • N E 3u bars avail?
« Reply #158 on: Mon, 18 January 2021, 20:40:34 »
3u Bars in both colors Pls!
Offline Grindbox
« Reply #159 on: Wed, 20 January 2021, 13:53:06 »
An extra 2u bar would be great too, imho.  Lots of the new split/ergo/ortho boards use 2x 2u spacebars (e.g. RGBKB Mun and Boardrun).
It would save some from having to double up on kits for one key.
Offline krzank
« Reply #160 on: Fri, 22 January 2021, 04:58:07 »
Is it still alive? Will it happen? When?
I'm very interested: Base+ISO+Makeup *2 and maybe lost nines.
Rows? couldn't find any info so probably 1-1-2-3-4-4 (?) Is there any hope for R0/R5?
Offline whezil
« Reply #161 on: Tue, 02 February 2021, 02:51:59 »
I'm so glad this is going to run, I can't wait!
When I first saw GMK Nines I hoped for an alt alpha set and now I find this.
Offline nasp
« Reply #162 on: Tue, 02 February 2021, 16:15:58 »
GB in June now thanks to Umka stealing the spotlight. See Emil's post a few up from yours.
Offline matthewdias
« Reply #163 on: Fri, 26 March 2021, 20:22:57 »
Excited for this. If you could make these changes to the extension kits to make them cheaper and more attractive to 40s users it would be greatly appreciated:
- remove 1.5u R3 Fn
- remove 1.75u R4 Lock
- remove 1.75u spacebar
+ add 1.25u R3 enter
Thanks for your consideration.
Offline terjerber
« Reply #164 on: Thu, 01 April 2021, 00:36:08 »
This set is soooo clean. I may get in on this as my first ever group buy.
Offline Grindbox
« Reply #165 on: Mon, 10 May 2021, 11:09:22 »
Popping in to check for updates and maybe bump this to build a little hype since we're approaching June.
Looking forward to this set! :D
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #166 on: Thu, 13 May 2021, 12:21:07 »
Woop, finally got the quotes in that were requested in december! must be some sort of a record for getting a quote, but we are on track for june!
Will share pricing asap!
Offline Arithmetics
« Reply #167 on: Thu, 13 May 2021, 12:36:09 »
HYPE HYPE HYPE
Offline IOVERCALLHISTIOCYTES
« Reply #168 on: Thu, 13 May 2021, 19:15:51 »
glad this is still moving along. A tough time for logistics.
Offline prognostics
Re: [IC] GMK Sixes - A reversed Nines. (Finally have the quotes ! 13/05/21)
« Reply #169 on: Mon, 24 May 2021, 19:32:08 »
Is this set still targeted for June?
Offline HungHingDaiLo
  • 無間道
« Reply #170 on: Mon, 24 May 2021, 22:51:43 »
Emir pogchamp wwww
IG: @rayhhdailo
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #171 on: Tue, 25 May 2021, 15:25:16 »
Yes!
Offline Xynerorias
  • Lubin' with glicerin
