Author Topic: [GB] BIOI G60BLE 60% PCB R2 (Extended to Oct 31st)  (Read 54448 times)
Offline PlayKeyboardTW
    • Shop
« on: Sat, 21 September 2019, 22:31:44 »
Hello community!
This is a round 2 groupbuy for BIOI G60BLE PCB.
BIOI G60BLE PCB is a USB/BT dual mode 60% PCB. It's originated from Scott's G60 keyboard kit. The bluetooth PCB was combined with a mother board and a daughter.
After some modifications, it become a bluetooth PCB with general specifications suitable for stock 60% keyboard parts.
Contents:
  • PCB
  • Two SH to PH adapter cables with inverted sequences
  • SMD LED for a charging indicator position
Features:
  • QMK firmware
  • USB C connector
  • BT4.0, available on most devices and systems like Win10, iPad and iPhone. Super power saving.
  • Supports USB/BT devices switching.
  • 1.0mm SH connector for battery socket
  • VIA Configurator supported (Thanks for help from Wilba and Olivia)
  • Full guide by Scott Wei: https://scottywei.github.io/bioi-g60ble/
BIOI G60BLE PCB will come with two PCB versions in this groupbuy.
A default one which you have to solder switches, and a hotswap one for easier installation.
Default (55USD):
  • South facing LED position
  • Multi layout support
Hotswap (60USD):
  • North facing LED position
  • Kailh hotswap sockets
  • 7u Spacebar layout only
Default Version Groupbuy Product Page: https://play-keyboard.store/products/bioi-g60ble-pcb-default-version-custom-60-bluetooth-pcb
Hotswap Version Groupbuy Product page: https://play-keyboard.store/collections/group-buys/products/bioi-g60ble-pcb-hotswap-version-custom-60-bluetooth-pcb
Build Guide: http://bit.ly/319wECR
GB period: 2019.9.21 ~ 2019.10.31
Estimated shipping date: 2019.12
Please feel free to leave comments if you have any question to this product.
Thanks! :thumb:
« Last Edit: Mon, 14 October 2019, 01:58:07 by PlayKeyboardTW »
Re: [GB] BIOI G60BLE 60% PCB R2
« Reply #1 on: Mon, 23 September 2019, 12:49:36 »
Approved :thumb:
Offline KingOfMemes
« Reply #2 on: Mon, 23 September 2019, 13:54:11 »
What kind of battery/extra battery accessories would I need to buy to use with this board?
    • Shop
« Reply #3 on: Mon, 23 September 2019, 23:09:32 »
Any 3.7v Li battery that suits the case you are going to use will do the work. ;)
Offline Icypetal
« Reply #4 on: Tue, 24 September 2019, 05:58:37 »
I am a bit confused. So... does it suppor QMK or not?
The description says it supports QMK, but the guide says the firmware is to be done.
As it is a R2 GB, I found the R1 thread in Reddit and you had written there the board is to be edited only by VIA configurator.
https://www.reddit.com/r/MechanicalKeyboards/comments/c4lryd/comment/ez8y2ji
I just want to make sure if it supports QMK now or not. :o
« Last Edit: Tue, 24 September 2019, 06:06:33 by Icypetal »
Offline rooski15
« Reply #5 on: Tue, 24 September 2019, 10:18:53 »
Grabbed one to give it a shot. Am curious, as are others, if it supports QMK.
Cheers!
    • Shop
« Reply #6 on: Wed, 25 September 2019, 02:07:54 »
Although the firmware is not opened for to compile freely at the moment, it still uses QMK firmware.
Scott is working on editing a version of source file for everyone to use.
As it's contains code of BT function, it's not as easy as other USB only PCBs.
Just need some time to achieve it. :)
Cheers!
Thanks a lot! :thumb:
Offline bball2
« Reply #7 on: Wed, 25 September 2019, 11:52:54 »
Anyone know any cases that would support this pcb with the bluetooth battery? Or have any pics of a completed setup with the batteries and wiring in place?
I was thinking of this one:
https://drop.com/buy/npkc-60-percent-wooden-wrist-rest-keyboard-case
Offline rockydbull
« Reply #8 on: Wed, 25 September 2019, 12:25:20 »
That doesn't have a battery compartment. Look at tofu and 5 degree cases
Offline kriscables
    • kriscables.com
« Reply #9 on: Wed, 25 September 2019, 22:13:00 »
I would be more interested if you would have a confirmation of QMK support.
Offline kriscables
    • kriscables.com
« Reply #10 on: Sat, 28 September 2019, 07:21:17 »
1) How many Amps (operating current) does it consumes while connected wirelessly at about 1-2 Meters from the PC in a plastic case and all the lights off?
2) Is it possible to be used while the battery is charging ?
3) (Dumb question) Does the PCB detects when the battery is fully charged and stops charging it ?
4) Does it have anti ghosting (NKRO) wired and wirelessly? If yes, how many keys in each mode?
5) The BT 4.0 works on both iOS and Android devices with 4.0 ? Normally there must be a manual switch telling the pcb to which OS i want to connect.
6) Does it need a dongle to be bought separately like the Anne Pro 2 ?
Apologies for making so many questions, but i am really interested in supporting the project.
A full build log also would be nice.
Offline kriscables
    • kriscables.com
« Reply #11 on: Sat, 28 September 2019, 08:34:38 »
Just noticed here it says 10mA operating current, which answers to my question n1.
So if connected a 2000 mAh rechargeable battery and making the by the formule the division of 2000mAh/10mA = 200hours.
If using 8h/day it means the battery will approximately last 25 days and that imo is pretty good.
Meanwhile another question:
7) How do we turn off the keyboard in order to preserve battery life ? Only by turning the BT switch mode to off ?
Offline Adelscott
« Reply #12 on: Mon, 30 September 2019, 06:52:21 »
In !
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline scottwei
« Reply #13 on: Thu, 03 October 2019, 03:49:44 »
Sorry for the late reply
1) 6ma when typing, 1.9~2ma when not typing.
2) Of course, once the USB cable is in, the charging will start and you can use the keyboard as a USB keyboard.
3) There is a battery management chip on board, it will control the charging current and voltage, or it can be very dangerous to charge a Li-Po battery directly by the USB voltage.
4) Currently, the NKRO feature is not enabled yet, it will be enabled by a future firmware update, and I'm quite sure that it won't work in Bluetooth mode.
5) You would check this with your device vendor, as I know, Most Apple devices you can buy nowadays(later than iPhone 4S) will support BT4.0, Android devices after 4.3 will support too, but it might not means all the devices will do.
6) It depends if there is a Bluetooth adapter on your computer. If not, you certainly need to buy a Bluetooth dongle to enable Bluetooth on your computer.
« Last Edit: Thu, 03 October 2019, 03:53:34 by scottwei »
Offline solemnly
« Reply #14 on: Fri, 04 October 2019, 07:12:13 »
bluetooth is agnostic of the OS its implemented on, so it shouldn't require a switch to pick iOS or Android or etc so long as the device physically supports the version
Offline beekey
« Reply #15 on: Sat, 05 October 2019, 04:41:56 »
Would it be possible to do split backspace by soldering the pads ourself? Looks like the pads are available next to the backspace socket.
    • Shop
« Reply #16 on: Sun, 13 October 2019, 01:22:53 »
Yeah sure if you have hotswap sockets. ;)
Offline Willhurt2008
« Reply #17 on: Sun, 13 October 2019, 11:04:37 »
I'm trying to order two PCBs with shipping to Kazakhstan, but country is not listed among the ones you ship to. Is it possible to ship here? Thanks
    • Shop
« Reply #18 on: Mon, 14 October 2019, 01:51:25 »
Hi guys, build guide uploaded.
Please check it here: http://bit.ly/319wECR
Hope that this guide will help more people know how to play with it and get more interests. :)
    • Shop
« Reply #19 on: Mon, 14 October 2019, 01:56:25 »
Hi, we just edited the rate for Kazakhstan.
You can now see the shipping price when checking out. :thumb:
« Reply #20 on: Tue, 15 October 2019, 13:37:12 »
Thanks, ordered!
Are kbdfans 60% plates compatible with that pcb? For example, this one: https://kbdfans.com/collections/plate/products/dz60-cnc-aluminum-plate?variant=2208864436237
Offline nilpt
Re: [GB] BIOI G60BLE 60% PCB R2 (Extended to Oct 31st)
« Reply #21 on: Wed, 16 October 2019, 06:14:06 »
Is it possible to configure for "SpaceFN" layout?
Reference: https://geekhack.org/index.php?topic=51069.0
IBM 1391410 / Qume terminal keyboard (teensy 2++)
    • Shop
« Reply #22 on: Thu, 17 October 2019, 00:27:11 »
Yes!
Thanks, ordered!
Yes they are.
Offline bananathock
« Reply #23 on: Thu, 28 November 2019, 19:15:35 »
Hello! Are we on schedule for a decemeber shipping for those who joined the R2 GB?
Thank you!
Offline IvarLJ
« Reply #24 on: Mon, 02 December 2019, 11:57:47 »
Do any (or both) of these support underglow?
Sent from my iPad using Tapatalk
Offline Lionell95
« Reply #25 on: Tue, 03 December 2019, 21:28:10 »
Thank you!
Unfortunately, they said that it won't be shipping out until early 2020... Huge bummer.
Check out their Instagram about it: https://www.instagram.com/p/B5kF-3dHVdV/
Offline AlexG
« Reply #26 on: Wed, 04 December 2019, 09:56:24 »
What's the polling rate? Is it different in blue tooth vs wired?
Offline ninjinphu
    • Music to Clack to
« Reply #27 on: Wed, 04 December 2019, 12:38:07 »
Will this fit a Klippe or are those cases PCB specific
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #28 on: Wed, 04 December 2019, 13:42:21 »
Does the Klippe have space for a battery?
The hi-profile R3 case doesn't look like it does.
Offline Arrythmia
  • CouchSurfer Designer+Custom Wood Cases
    • Keyboard Cottage
« Reply #29 on: Fri, 10 January 2020, 00:38:24 »
Any word on these shipping out this month?
The CouchSurfer - wireless 60% lapdesk for gaming and HTPC's
Offline rooski15
« Reply #30 on: Fri, 10 January 2020, 00:51:06 »
Just saw this on their Instagram.
https://www.instagram.com/p/B7IDN_AHQQI/
Offline bball2
« Reply #31 on: Fri, 10 January 2020, 10:20:34 »
What kind of case is everyone planning on using?
Offline sortofsleepy
« Reply #32 on: Tue, 14 January 2020, 17:43:32 »
I know this was awhile ago but came on to check on status for this  GB saw the comment.
I can confirm Klippe R3 won't fit a battery with this PCB :( (I have an R1 version). That being said, I've tried the hot-swap version, you could MAYBE fit one if you had the solderable version? but yea, the clearance is pretty tight; spacers or something to give a little more clearance between the PCB and bottom is needed.
« Last Edit: Tue, 14 January 2020, 17:45:36 by sortofsleepy »
Offline wd9001
  • Whoms't | 22nd century schizoid man
« Reply #33 on: Fri, 17 January 2020, 18:40:30 »
Unfortunately, a battery won't fit at least for a R1 klippe case  :(. However it is possible to still build it with one, but everything would be sitting up and the components wouldn't be entirely parallel to the case due to the battery pushing on the pcb. Personally, I chose to take the battery out because it was not a great typing experience.
Lunar AEK| Klippe R1 |
Klippe S (production)|
GSKT (Pre-Invoice)
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #34 on: Tue, 10 March 2020, 04:07:18 »
ngl but a few things here are more than fishy to me...
First: why the secrecy around the QMK support? Bluetooth support is not a valid reason for this. QMK supports bluetooth of it's own very well.
Second: why are you advertising a bluetooth enabled pcb as VIA compatible when the VIA documentation pretty clearly states that it is not compatible with any bluetooth functions?
we already had a few people ask questions about this pcb on the qmk discord now and we couldn't help any of them because of this.
Offline Draic
« Reply #35 on: Tue, 10 March 2020, 04:31:00 »
is there a specific reason, why you cant offer split spacebar support?
Offline MajorKoos
« Reply #36 on: Tue, 10 March 2020, 08:30:28 »
Mine arrived pre-flashed with a VIA Configurator compatable build of QMK.
Programmed it over USB using the app.
Offline elmo
    • Elmo's keyboards
« Reply #37 on: Tue, 10 March 2020, 08:46:51 »
Yeah apparently they are redistributing a modified version of QMK and an older version of VIA with the board.
Which btw. violates the license of the QMK project since playkeyboard does not provide the modified sourcecode anywhere. :-X
« Last Edit: Tue, 10 March 2020, 09:10:08 by elmo »
Offline rooski15
« Reply #38 on: Tue, 10 March 2020, 10:32:49 »
Neato. Mine arrived, haven't had a chance to mess with it, but this thread is making me think I might just sell it.
Offline Blue_Ninja0
« Reply #39 on: Sun, 26 April 2020, 07:03:56 »
I'm worried about this. I'm on the verge of buying this PCB but I need it to be fully compatible with QMK. Why wouldn't they release the source code for this? Are there any news?
Anyone knows any alternative PCB or keyboard that ticks these boxes:
-Fully programmable
-60%
-Wireless
-USB-C
Offline MajorKoos
« Reply #40 on: Sun, 26 April 2020, 08:15:44 »
2 of the 3 PBC's I ordered let the magic blue smoke out when I plugged in a battery.
Offline Blue_Ninja0
« Reply #41 on: Tue, 28 April 2020, 05:35:30 »
Could you please elaborate? Was the battery the correct voltage?
Offline MajorKoos
« Reply #42 on: Tue, 28 April 2020, 14:37:39 »
Yup.  Correct voltage.  Correct polarity.
The PCB's still work over USB at least.
Offline Blue_Ninja0
« Reply #43 on: Tue, 28 April 2020, 15:04:54 »
Did anyone get you a replacement?
Offline MajorKoos
« Reply #44 on: Tue, 28 April 2020, 19:31:31 »
Haven't bothered asking yet with everything going on.
At some point I'll pull out my multimeter and try to figure out what I fried.
At present I'm more interested in seeing if it's just me or other people are also running into issues.
« Reply #45 on: Wed, 29 April 2020, 09:30:31 »
Ah yea,  that happened to me as well with one of my pcbs from them, was a little shocking to say the least.
I don't know if anything important got fried cause I don't know what to look for but when you get around to examining I'd be interested to know your findings.  I did leave it on battery power for almost a full day just to see if anything would happen(under supervision of course) but nothing got hot or anything like that, still works fine over bluetooth. The only thing unusual I've found, when compared to other PCBs is that I can't wake my computer with the PCB but other than that all appeared fine.
Thing still works though, not using it at the moment but was using it for a few months, albeit on USB not battery since I don't have a case that'll hold a battery.
« Last Edit: Wed, 29 April 2020, 09:34:07 by sortofsleepy »
Offline MajorKoos
« Reply #46 on: Wed, 29 April 2020, 11:25:33 »
I think I figured out my problem.
The two pig-tails have different polarities and I must have used the wrong one.
Offline Blue_Ninja0
« Reply #47 on: Thu, 30 April 2020, 07:03:06 »
Ok, that explains it and relieves me.
« Reply #48 on: Thu, 30 April 2020, 08:37:39 »
I noticed that a little too late as well but in my case I'm reasonably certain I used the right one... :/ In any case good to hear that's all it likely was
Offline Blue_Ninja0
« Reply #49 on: Wed, 06 May 2020, 04:30:21 »
Can any G60BLE user confirm to me if I can pair more than a single Bluetooth device to this PCB and switch between them without having to re-pair?
