Author Topic: [GB] Fox Lab - Key 65  (Read 753133 times)
Offline senter
« on: Wed, 25 September 2019, 09:15:54 »
Google form for placing orders
Order information
Follow me on Instagram for most prompt updates: https://www.instagram.com/fox_lab_keyboard/
Key 65 is featured with the three-layer case and dual-gasket structure. The plate mounting system is an improved version of the gasket sandwich on Leaf 60. In addition, we add gaskets between the middle case and the bottom case. There's an optional rubber sheet between the PCB and the plate. The numerous options will offer you the most freedom to make the keyboard look and feel as you wish.
This GB is the most sophisticated one we've run so far. It could also be the most sophisticated GB in the keyboard history. For each of the three layers of the case, you can choose from 3 materials, 3 finishes, and 9 colors. There are two versions of weights and 6 versions of the top cases. If we count all the options available to choose, the number of possible combinations is around 400 million. We are crazy enough to run the GB in this way. Now we invite you to be a part of this historical crazy GB.
Price:
  • The price for the regular kit is $295 excluding PayPal fee and shipping
  • Upgrade to brass plate: $27
  • Upgrade to titanium plate: $40
  • Upgrade to brass weight: $35
  • Extra PCB: $36
  • The estimated shipping fee for a regular kit is $40. You'll be inviced again before shipping.
Timeline:
  • GB opens for two weeks.
  • The lead time is estimated to be 3 months after GB closes. There might be delays due to the complexity of this GB.
QA
Q: Color samples?
A:
E-White: https://imgur.com/WR1gW3B
E-Yellow: https://imgur.com/rQMhw50
E-Red: https://imgur.com/TReEOoE
E-Black: https://imgur.com/WFypGrT
E-Pink: https://imgur.com/xgr0992
E-Teal: https://imgur.com/BYFr4cK
Anodizing Blue: https://imgur.com/EjaqDG8
Anodizing Grey: https://imgur.com/7rl51AR
Anodizing Midnight Green: https://imgur.com/9tSLeDU
POM Red: https://imgur.com/4jlSRpw
POM Yellow: https://imgur.com/5TVyYd0
PC clear: https://imgur.com/WNGRVpm
Q: What does the XXX combination will look like? Can you make a prototype or render with this combination?
A: No. I understand it's not easy to imagine how your combination will look like and it's important to you. I'll update some more photos and renders in one day or two. However, we are not able to do this for everyone. I suggest you choose the same color for the top and middle cases.
Q: What are the top case layouts?
A: WKL cases have the left blocker and WK cases don't.
6.25u spacebar layout -> choose WK top case
7u spacebar layout with left blocker -> choose WKL top case
7u spacebar layout without left blocker -> choose WK top case
Q: What are the logo options on top case?
A:
Above is the No logo version
Above is the Key logo version (sorry for the upsidedown plate)
Above is the Kanji logo version
Q: What's the difference between POM and PC?
A: They are very similar in terms of density and finish.
Q: Does E-coating brass parts look the same with E-coating aluminum?
A: Very similar.
The weight on the bottom is E-white brass. The case on top is E-white aluminum.
Q: How can I choose the plate materials?
A: The sound and feel are all subjective. If you don't have a preference, aluminum is the safe choice.
Q: What is Electrophoresis Clear?
A: E-clear is a clear Electrophoresis coating. It's clear so the part will show its original color. This is how it looks on brass parts.
Q: What does the titanium plate look?
A:
Q: What are the plate layouts?
A:
7u spacebar version plate.
6.25u spacebar + split spacebar version plate.
Q: Do I need to customize the top right Key logo if I chose Kanji/No logo top? Do I need to customize the key logo on the weight if I chose the Kanji weight?
A: No and no.
Q: What are the weight versions:
A:
Above is the Kanji version weight
Above is the Key version weight
Q: Can I order an extra weight/logo/top case?
A: No, for the sake of simplicity. We are dealing with 400 million possible combinations and we don't want to add more.
Q: Can I order more than one extra PCBs/plates?
Q: PCB layout
A:
Universal PCB
Hotswap PCB
Q: ALPS support?
A: Supported by the universal PCB but not by plates. I'll share the plate file before the GB closes.
Q: ISO support?
Structure diagram
For more photos, check this album.
Update 1: https://geekhack.org/index.php?topic=102609.msg2838182#msg2838182
Update 2: https://geekhack.org/index.php?topic=102609.msg2842873#msg2842873
Update 3: https://geekhack.org/index.php?topic=102609.msg2856492#msg2856492
Update 4: https://geekhack.org/index.php?topic=102609.msg2872063#msg2872063
Update 5: https://geekhack.org/index.php?topic=102609.msg2881104#msg2881104
Update:
  • Default firmware hex files are attached.
  • QMK firmware builder json files are attached. To use the json files, you need to access https://kbfirmware.com/ and upload the json file for your PCB version. You can also download the QMK codes after uploading the json files.
[/s]
About the PCB reset button:
If the PCB you received has a physical button, it may not work after fully assembled. It happened because the PCB supplier changed the BOM after the prototype was tested. The button will be pushed against. the bottom case so the PCB doesn't work. We have removed the physical reset buttons for most PCBs. Only the first 40 or so PCBs still have the physical reset button. You can simply remove it with a wirecutter or soldering iron. It's not a necessary part for the PCB (Leaf60 PCB didn't even have the button). If it bothers you, I can issue a full refund&return.
Update on the firmware:
I've tested the VIA firmware. It works great.
« Last Edit: Wed, 03 June 2020, 14:41:46 by senter »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Fox Lab - Key 65
« Reply #1 on: Wed, 25 September 2019, 10:40:27 »
Approved!
Offline sapphyr
« Reply #2 on: Wed, 25 September 2019, 10:47:19 »
Can we get a photo of the PCB too, please?
And yes, let's go!!
Offline Soraie
« Reply #3 on: Wed, 25 September 2019, 10:47:59 »
Yes!!! Been waiting for this!! So many combinations, this is such a tough choice...
Offline Dennyroxsox
  • a.k.a. Lollipopsaurus
« Reply #4 on: Wed, 25 September 2019, 10:52:21 »
Awesome! I'm really pumped!
Are renders/samples available for all of the colors? There are way more colors here than I anticipated.
Offline Helpingly
  • Hiya! I'm Helpingly
« Reply #5 on: Wed, 25 September 2019, 10:54:41 »
Super excited for this, now to spend hours thinking about what colors and combinations I want.
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #6 on: Wed, 25 September 2019, 10:55:46 »
What firmware will the PCB use?
Offline anatworkaccount
« Reply #7 on: Wed, 25 September 2019, 10:57:23 »
Seconded. Doesn't need to be exact but I'm super curious what shade of green we are talking.
Offline badboy731
« Reply #8 on: Wed, 25 September 2019, 11:01:39 »
Nice! I gotta make sure not to screw up what I want 😂
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline happycamper87
« Reply #9 on: Wed, 25 September 2019, 11:04:52 »
Form filled and submitted!
Went with black top and middle, white bottom, and black weight. WK Kanji logo and PC plate.
Shipping when.
Offline senter
« Reply #10 on: Wed, 25 September 2019, 11:07:01 »
Offline senter
« Reply #11 on: Wed, 25 September 2019, 11:07:45 »
And yes, let's go!!
will have the hotswap version on Sunday.
Offline JacobTN
« Reply #12 on: Wed, 25 September 2019, 11:08:30 »
I am in for WKL hotswap, Full PC case, teal plate, teal weight, with Brass key logos on both sides  :D stoked
Offline senter
« Reply #13 on: Wed, 25 September 2019, 11:10:03 »
I should have photos/renders for all the colors except the midnight green. will post later.
Offline senter
« Reply #14 on: Wed, 25 September 2019, 11:10:28 »
Offline minimin
« Reply #15 on: Wed, 25 September 2019, 11:14:42 »
wanna know the degree and what the middle plate part is.
Offline o3okevin
« Reply #16 on: Wed, 25 September 2019, 11:25:38 »
Looks amazing, so many options! Really looking forward to seeing this in person
« Reply #17 on: Wed, 25 September 2019, 11:28:05 »
So since you don't have photos/renders of midnight green, could you describe it for me?
Is it Kelly green?
https://www.canva.com/colors/color-meanings/kelly-green/
Is it midnight green like this hex?
https://www.colorhexa.com/004953
or is it something else entirely.
Offline Tyson
« Reply #18 on: Wed, 25 September 2019, 11:38:45 »
Just filled out the GB form! Can't wait for this board, going with an all pink board with black inserts and a PC plate! I'll either use this board with GMK Blink or  another keyset I have in mind that I need to IC first.
Offline thecyangiant
« Reply #19 on: Wed, 25 September 2019, 11:41:22 »
Looks really cool! With split space is 6.25 or 7 better?
Offline Tyson
« Reply #20 on: Wed, 25 September 2019, 11:41:36 »
Yeah, I'm curious by what the middle case is, I filled the form out and had trouble on choosing a color for that part. Hopefully I made the right choice because I'm not sure if I can edit the form.
Offline o3okevin
« Reply #21 on: Wed, 25 September 2019, 11:43:05 »
Oh one thing, a rubber layer between pcb and plate was mentioned in the OP but I can't find it on the form. How much would it cost extra?
Offline ILoveMinivans
« Reply #22 on: Wed, 25 September 2019, 11:45:29 »
How much is the additional plate?
Offline senter
« Reply #23 on: Wed, 25 September 2019, 11:49:25 »
Is it Kelly green?
updated in OP
Offline senter
« Reply #24 on: Wed, 25 September 2019, 11:50:18 »
Split space is only for 6.25u spacebar layout.
Offline senter
« Reply #25 on: Wed, 25 September 2019, 11:54:48 »
The degree is 7
Do you mean the middle case?
It's the part in the left bottom.
side view
Offline Morgan3Wheeler
« Reply #26 on: Wed, 25 September 2019, 11:57:18 »
I think there is not Anodizing Blue color sample.
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline senter
« Reply #27 on: Wed, 25 September 2019, 12:02:31 »
« Last Edit: Wed, 25 September 2019, 12:04:09 by senter »
« Reply #28 on: Wed, 25 September 2019, 12:03:02 »
So no WKL for split spacebar?
Offline senter
« Reply #29 on: Wed, 25 September 2019, 12:05:06 »
Here is the universal PCB layout: https://i.imgur.com/MQTZV0o.png
Offline endsession
« Reply #30 on: Wed, 25 September 2019, 12:05:42 »
Is there an order limit or is this GB open for two weeks with no cut-off?
Looks attractive, but I'm still debating on options.
Offline senter
« Reply #31 on: Wed, 25 September 2019, 12:05:57 »
It's free and everyone gets it.
« Reply #32 on: Wed, 25 September 2019, 12:06:15 »
The 'customize' the plate field indicates the 6.25u is not compatible with WKL top
Offline xchangmanx
« Reply #33 on: Wed, 25 September 2019, 12:07:30 »
I'm a noob here.  I'm looking fwd to this as to hopefully be my first custom build.  It looks amazing.
Offline senter
« Reply #34 on: Wed, 25 September 2019, 12:09:09 »
I don't think the sale will go beyond our ability but if it happens I may close the form.
« Reply #35 on: Wed, 25 September 2019, 12:10:57 »
When does invoicing begin?
Offline Fnzzy
« Reply #36 on: Wed, 25 September 2019, 12:14:12 »
Here is a crappy mock up how the PC case could look with the yellow PCB inside. Maybe someone will find this helpful in their decision making.
« Last Edit: Wed, 25 September 2019, 12:16:25 by Fnzzy »
Offline PremierMushroom
« Reply #37 on: Wed, 25 September 2019, 12:23:38 »
Wow! the number of options is mind-blowing!
So, I ordered 4 sets (4 form responses). However, I haven't got any confirmation emails from Google forms (I guess you set it that way?).
Is there any way I can see the forms I filled? My paranoid self is quite afraid that I might have made a mistake or two.
Offline DrLove
« Reply #38 on: Wed, 25 September 2019, 12:41:34 »
Are there any renders that show some side views for non clear materials? I would like to see how much of each layer is visible.
Offline SuddenlyDonkey
« Reply #39 on: Wed, 25 September 2019, 12:44:16 »
Offline MK47
  • Don't talk to me
« Reply #40 on: Wed, 25 September 2019, 12:44:47 »
Do you have a discord server?
Offline //gainsborough
  • MATRIXの日常
« Reply #41 on: Wed, 25 September 2019, 12:49:24 »
will the hot-swap PCB have sockets for both alps and MX?
edit: nvm just read alps is only on universal PCB
« Last Edit: Wed, 25 September 2019, 12:52:54 by //gainsborough »
Offline zian_
« Reply #42 on: Wed, 25 September 2019, 12:52:58 »
Form filled out! In!
Offline infamousvincci
« Reply #43 on: Wed, 25 September 2019, 13:01:09 »
How do i delete my order?
Was tryjng to order 2pcs and i messed up both of them. :/
I want to start fresh.
Sent from my GM1915 using Tapatalk
Offline JacobTN
« Reply #44 on: Wed, 25 September 2019, 13:12:25 »
Curious as to how I can double check/edit my order
Offline Jinnnxxu
  • U only live once
« Reply #45 on: Wed, 25 September 2019, 13:12:44 »
Innnnn! I really like the FOX logo and many styles that we can choose!  :thumb:
Ins: Jinnnxxu     Discord:Jinnnxxu#9644
Exclusive: E8V1 | E7V1 x14 | E7-VX | E6V2 x1 | E6V2 PE x7 | E6.5 x9 | E7SE x3 | E8.5 x5
Matrix: 1.0RE | 1.2RE | Abel | Abel+ | Cain | 2.0 x8 | 2.2 x8 | Abel-x x4 | M6 x2 | 1.2OG x15 | Project F x2 | 2.0AD x15 | Noah x3 | Mr. Hat x3 | 2.0VK x1
Rama: M60-A x4 | M65-A x2 | M6-A 88edition | M6-B | KOYU x3 | M60-A SEQ2 X4 | M6-C x2 | U80 x5 | M10-C | M6-C | M60 LNY x2 | M60 Olivia x2 | M65-B x5
FOX: Leaf 80 x4 | Leaf 60 x4 | Key65 x5      TGR:Jane V2 | 910RE | Jane V2 CE x2     Percent: Canoe x3 | Maze x2 | Skog lite | Canoe FE x2
Others: Mira SE x2 | Jermini | C225 x2 | INETT Cross x2 | Kira 80 | Kira 60 | Zephyr 65 R2 | Space 65 x2 | Volcano 660 x3 | INETT Square80 x4 | INETT Square68 x6 | FMJ 80 x2 | Keycult No.2 x1 | Thermal x2
« Reply #46 on: Wed, 25 September 2019, 13:28:50 »
Anyone have experience typing on a titanium plate?
To OP:  It would be great to see a profile or 3/4 view of the board with different top, middle, and bottom colors so we can all see precisely how the transition between the 3 elements looks.  Similar to the PC side view pic.
« Last Edit: Wed, 25 September 2019, 13:30:47 by SuddenlyDonkey »
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #47 on: Wed, 25 September 2019, 13:30:45 »
+1 :)
Offline fatboycarney
« Reply #48 on: Wed, 25 September 2019, 13:30:52 »
Agreed on the profile view with 3 different colours
@OP this is just Wow impressive. GLGB!
Offline Lil
    • designedbydark
« Reply #49 on: Wed, 25 September 2019, 13:37:49 »
What is the cost for the extra plates? I realise the cost to upgrade, but not the cost for the extra.
