Author Topic: [GB] Fox Lab - Key 65  (Read 752285 times)
Offline BserLarry
Re: [GB] Fox Lab - Key 65
« Reply #100 on: Thu, 26 September 2019, 06:51:22 »
@senter
For the question
Customize the Key logo on the weight (optional): material-(finish)-color
Option
I didnt order the Key logo top case
The option ought to be “I didnt order the Key logo weight”
Correct?
Offline orim23
« Reply #101 on: Thu, 26 September 2019, 07:17:00 »
are multiple orders going to be shipped as one package?
Offline JacobTN
« Reply #102 on: Thu, 26 September 2019, 08:14:37 »
What is the cost for the extra plates? I realise the cost to upgrade, but not the cost for the extra.
You can get 1 extra plate, Alu or PC for $10. Add extra cost for brass/Ti.
Offline .rgaindwal
« Reply #103 on: Thu, 26 September 2019, 08:41:29 »
Hey! Is there no option to get a white POM? Like sirius60 or something like that?
Offline Vigrith
« Reply #104 on: Thu, 26 September 2019, 08:57:44 »
What is the weight difference between the brass and aluminium weight?
Weight.
Offline olsen34
« Reply #105 on: Thu, 26 September 2019, 10:13:15 »
Weight.
He's asking the number, not what difference. I'd like to know too.
Offline Xantus
« Reply #106 on: Thu, 26 September 2019, 10:25:41 »
Weight.
1+
Offline R4WBIT
« Reply #107 on: Thu, 26 September 2019, 11:31:00 »
I can't see information about it, but is this USB-C or Mini USB?  :confused:
Offline Vigrith
« Reply #108 on: Thu, 26 September 2019, 12:14:00 »
That makes more sense, yea would be nice to know.
Speaking of which is there a price difference between the key logo(s) being brass as opposed to not? As per what is written in OP and in the form it appears not but rather get confirmation.
Offline senter
« Reply #109 on: Thu, 26 September 2019, 15:13:17 »
Is this how the layers are arranged?
I've added some structure diagrams in the OP. Hope the diagrams explained it well.
Offline senter
« Reply #110 on: Thu, 26 September 2019, 15:15:30 »
Offline senter
« Reply #111 on: Thu, 26 September 2019, 15:17:46 »
Hi senter, how will the key logo top look like on polycarb version?
Will it be color as well as the alu? Or will it be just engraving?
No poly prototypes with Key logo has been made so I can't answer.
The key logo is a separate part.
Offline senter
« Reply #112 on: Thu, 26 September 2019, 15:22:20 »
1. can we ask to undervalue the package?
2. whats the weight difference between brass vs alu weight?
3. if i choose brass weight will the shipping get more expensive due to the increased weight?
4. you may want to change the "I didn't order the Key logo top case" option under key logo weight question
also need confirmation on this pls, is this example using ANO BLUE as the top and middle, and ANO GRAY as bottom?
1. PM me for answers.
2. I haven't weighed it yet. A reviewer is sending the prototypes to me. I'll have the numbers when I receive them.
3. Possibly. The shipping fee is more expansive for every 500g.
Offline senter
« Reply #113 on: Thu, 26 September 2019, 15:22:43 »
What is the thickness on the plates (in mm)?
1.5mm
Offline senter
« Reply #114 on: Thu, 26 September 2019, 15:24:08 »
Sorry this may be a stupid question as this is my first GB board. Does the hot swap PCB support 7U, 6.25U or both types of space bar?
Hotswap PCB normally can only support one layout. The layout we chose was the 7u spacebar layout.
Offline senter
« Reply #115 on: Thu, 26 September 2019, 15:25:20 »
Will the teal more or less look like this?
On the bottom case yes I guess.
Offline senter
« Reply #116 on: Thu, 26 September 2019, 15:25:59 »
How much would it cost to get an Alps plate cut? And where could I get it done?
PM me for ALPS questions.
Offline senter
« Reply #117 on: Thu, 26 September 2019, 15:27:44 »
Any chance we can order 1 extra front and back logo in different colors?
It would help when matching different keysets.
Cheers!
No for this GB. You know, this is a GB with 400 million different combinations.  :eek:
Offline senter
« Reply #118 on: Thu, 26 September 2019, 15:28:33 »
Will there be any additional details about the pcb, like rgb led support (same as leaf60?) and firmware?
Yes, same with Leaf60 except the layout.
Offline senter
« Reply #119 on: Thu, 26 September 2019, 15:30:08 »
Q: ISO support?
A: Supported by the universal PCB but not by plates. I'll share the plate file before the GB closes.
im pretty new to this hobby but this keyboard looks sick, I need iso. what can i do with the plate files if you release them?
[/quote]
It depends on where you live. You should try to find some local or online laser cutting services like https://lasergist.com. Just order the 1.5mm thick plates.
Offline senter
« Reply #120 on: Thu, 26 September 2019, 15:32:30 »
@senter
For the question
Option
Correct?
Yes. And this question is optional. You don't need to choose any options. Even if you choose other options and you ordered the Kanji logo, it doesn't change anything.
Offline senter
« Reply #121 on: Thu, 26 September 2019, 15:33:59 »
No price differences.
Offline toanta
« Reply #122 on: Thu, 26 September 2019, 17:03:01 »
Can the Kanji logo be colored in like the Key logo? I don't see any renders of it, but I see options in the form.
Offline Adelscott
« Reply #123 on: Thu, 26 September 2019, 17:07:16 »
Are you still releasing ISO plate file before the GB end ?
Is there any option to buy the keeb without the useless (for us)  ANSI plate ? Can't find it in the form :(
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline cosign_input
« Reply #124 on: Thu, 26 September 2019, 18:32:57 »
Where will the keyboard be shipped from and when is the deadline for the GB?
Offline suparnemo
« Reply #125 on: Thu, 26 September 2019, 18:37:16 »
The options are for the key logo. The Kanji is engraved, not a separate piece.
Offline badboy731
« Reply #126 on: Thu, 26 September 2019, 19:05:48 »
AH i see for someone reason I thought it was gonna be in the yellow color as seen in the pictures. So if I just get a PC case it will be engraved within the clear PC?
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline suparnemo
« Reply #127 on: Thu, 26 September 2019, 19:15:12 »
I assume so, maybe senter can confirm. Not sure how that would look...
Offline kabocha
« Reply #128 on: Thu, 26 September 2019, 21:10:36 »
Is the anodizing grey a dark grey or something lighter like kbdfan's tofu space grey?
Offline senter
« Reply #129 on: Thu, 26 September 2019, 21:31:42 »
The Kanji logo is engraved so the only way to get it colored is to use paint.
Afaik some people use acrylic paint.
There was a post teaching how to do it but it's in Chinese.  https://www.zfrontier.com/post/detail/4245
Here's how the result looks like
Offline badboy731
« Reply #130 on: Thu, 26 September 2019, 22:12:33 »
Do you have a sample of how it would look engraved in the clear PC?
Offline mlnr
« Reply #131 on: Fri, 27 September 2019, 00:42:12 »
overwhelmed by choice
Offline dannyny
« Reply #132 on: Fri, 27 September 2019, 00:54:58 »
how many sold the first day of GB?
Offline muppen
« Reply #133 on: Fri, 27 September 2019, 07:24:53 »
Q: ISO support?
will the files you release be iso or just ansi?
[/quote]
Offline Mechalomania
« Reply #134 on: Fri, 27 September 2019, 11:10:59 »
Also please take a picture of the sides of one of the prototypes, I want to see how the middle piece looks in regards to the top and bottom so I can decide on a colour, thanks!
To add to this request, would it be possible to take a side pic with the middle piece being a different color than the top and bottom?  It would help determine if I would want to just match it with the top or experiment with the color.
Offline Adelscott
« Reply #135 on: Fri, 27 September 2019, 11:37:47 »
This !
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #136 on: Fri, 27 September 2019, 12:05:39 »
Offline chakkii
« Reply #137 on: Fri, 27 September 2019, 12:18:10 »
+1
same here, thinking about adding some color for the middle case, but not sure how this will turn out :) So that would be great :)
Offline suparnemo
« Reply #138 on: Fri, 27 September 2019, 12:58:58 »
Would like this as well. Has anyone seen this done on a PC board before? I want to know if it would look good before deciding to go with the top right blocker on PC.
Offline badboy731
« Reply #139 on: Fri, 27 September 2019, 16:22:39 »
im nervous it will look like I took a knife and made some lines. You know like when you scratch plastic? Hoping it be thick enough to show it’s a design
Offline spring4k
« Reply #140 on: Fri, 27 September 2019, 17:41:44 »
Is pcb compatible with tx65? Or is it compatible with other center usb pcb? becuase i want to rgb led
« Last Edit: Fri, 27 September 2019, 17:45:52 by spring4k »
Offline suparnemo
« Reply #141 on: Fri, 27 September 2019, 18:56:28 »
Yeah I'm going with no blocker since I am not sure it will look good even though I'd prefer the blocker
Offline badboy731
« Reply #142 on: Fri, 27 September 2019, 19:09:14 »
Yeah I think I will be joining you on that one
Offline thecheeselouise
« Reply #143 on: Fri, 27 September 2019, 19:57:30 »
I am in for WKL hotswap, Full PC case, teal plate, teal weight, with Brass key logos on both sides  :D stoked
Is the hotswap and WKL an option? I was under the impression that the hotswap PCB only supported the 7u spacebar? Does this mean a 1u blocker is an option?
Offline o3okevin
« Reply #144 on: Fri, 27 September 2019, 21:44:55 »
1u blocker requires a 7u spacebar, hotswap pcb is 7u spacebar only
just don't put a switch in the winkey position so you can use the blocker :)
« Reply #145 on: Fri, 27 September 2019, 22:01:32 »
Any idea what the connector will be for the PCB? Hopefully usb-c?
Offline senter
« Reply #146 on: Fri, 27 September 2019, 22:41:41 »
No
Offline senter
« Reply #147 on: Fri, 27 September 2019, 22:44:19 »
This !
Sure. I'm working on it. Here's an example. I'll update more when I get time.
Offline senter
« Reply #148 on: Fri, 27 September 2019, 22:46:12 »
I don't think so.
WS2812 LED strips are not that difficult to add.
Offline senter
« Reply #149 on: Fri, 27 September 2019, 22:47:31 »
USB-C
