Author Topic: [GB] Fox Lab - Key 65  (Read 752289 times)
Offline senter
Re: [GB] Fox Lab - Key 65
« Reply #150 on: Fri, 27 September 2019, 22:49:57 »
Good news, E-Clear finish has been upgraded.
We've added an additional process before applying E-Clear so it will look cleaner!
Offline Lil
    • designedbydark
« Reply #151 on: Sat, 28 September 2019, 01:43:20 »
Also please take a picture of the sides of one of the prototypes, I want to see how the middle piece looks in regards to the top and bottom so I can decide on a colour, thanks!
To add to this request, would it be possible to take a side pic with the middle piece being a different color than the top and bottom?  It would help determine if I would want to just match it with the top or experiment with the color.
This !
Sure. I'm working on it. Here's an example. I'll update more when I get time.
Sick, please dm me, I'd like to pay early
Sent from my G8341 using Tapatalk
Offline Vyndem
« Reply #152 on: Sat, 28 September 2019, 03:00:30 »
Is it possible to see a render/picture of the full PC keyboard (top, middle and bottom case), without the left blocker and with the kanji logo on both top and weight?
Offline Adelscott
« Reply #153 on: Sat, 28 September 2019, 03:03:15 »
Wait you're showing an ISO compatible plate ! Is that the new plate for this GB ?
Edit : nevermind can't be, there's one vertical row missing
« Last Edit: Sat, 28 September 2019, 03:07:06 by Adelscott »
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline Lisinge
« Reply #154 on: Sat, 28 September 2019, 05:16:13 »
Hey senter, why doesn’t the universal plate have the relief cuts like the 7u plate?
Offline holy panda
« Reply #155 on: Sat, 28 September 2019, 06:14:08 »
How heavy will alu/pc be?
Bauer 2 |U80-a | Fjell | Think6.5v2 | Alu XO V2 | Orion v2.5 | Prophet |
Offline olsen34
« Reply #156 on: Sat, 28 September 2019, 07:03:11 »
This !
Can you provide a pic of the front and sides of the board? I want to know how mixed colors of top and middle case look.
Offline thecheeselouise
« Reply #157 on: Sat, 28 September 2019, 08:51:46 »
I'm definitely thinking about joining this GB. Ive been eyeing up a PC board for awhile now. My main question is with the Key Logo in the upper right. If I understand correctly, the actual key logo is a separate piece of aluminum that is inserted into the board. Is the cutting process for this going to be handled well by the poly carbonate making up the board?
Offline TheNamesTy45
« Reply #158 on: Sat, 28 September 2019, 11:46:55 »
"I'm done with buying new boards this year."
Well that was a fun thought.
Offline happycamper87
« Reply #159 on: Sat, 28 September 2019, 12:11:45 »
Just realized I didnt receive a copy of the google form I filled out and sent. Now I'm not sure if my submission went through. :-[
Offline JacobTN
« Reply #160 on: Sat, 28 September 2019, 12:13:17 »
Send Senter a Msg. The first few orders didnt recieve a confirmation, you'll have to have him reset it.
Offline OmniSzron
« Reply #161 on: Sat, 28 September 2019, 14:58:55 »
Sent my order out. This is going to be my first custom build. I'm pretty excited. Went for a mostly white with a bit of black all-aluminium set with the key logo and I'm putting KAT Milkshake on it. :)
Is shipping to Poland going to cost ~$40 too?
Fox Lab Key 65 split space
Offline keys
  • waves && keyboards
« Reply #162 on: Sat, 28 September 2019, 17:17:53 »
have any pics of the split spacebar?
Offline senter
« Reply #163 on: Sat, 28 September 2019, 19:34:33 »
The Key logo is screwed on.
Offline senter
« Reply #164 on: Sat, 28 September 2019, 19:36:05 »
I've added an album in OP with more photos.
Offline senter
« Reply #165 on: Sat, 28 September 2019, 19:38:04 »
I don't quite understand your question. Do you mean fully assembled keyboard with split spacebar layout and caps on? The answer is no if that's what you asked.
Offline badboy731
« Reply #166 on: Sat, 28 September 2019, 20:15:22 »
Do you have a Picture of pc with kanji in the top right?
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline BserLarry
« Reply #167 on: Sat, 28 September 2019, 20:19:52 »
Hi Senter,
Can you comment on the amount of flex in aluminium and PC plate choice?
Is it indeed noticeable?
Offline o3okevin
« Reply #168 on: Sat, 28 September 2019, 21:10:01 »
Really appreciate the attention to all questions Senter!
Offline jooobe
« Reply #169 on: Sat, 28 September 2019, 21:36:41 »
Nice touch with the album, much clearer view now
Sent from my iPad using Tapatalk
Offline senter
« Reply #170 on: Sat, 28 September 2019, 21:40:38 »
No as we didn't make a prototype like that  :-X
Offline senter
« Reply #171 on: Sat, 28 September 2019, 21:41:42 »
Hi Senter,
Yes, it's noticeable. The sound is noticeably different as well.
Offline fault_lin3
« Reply #172 on: Sat, 28 September 2019, 23:13:18 »
When you get pictures of the hotswap pcb, can you take a pic of both front and back? I'm trying to picture what you mean when you say leds strips can be added later. That said, are underglow smd's absolutely off the table? I saw a prior post where you say they have a high failure rate but a lot of the other high end boards(e6.5 and think6.5) as well as lower end boards have underglow with no obvious issues. I've been intrigued by gasket mount and PC cases so this checks all my marks except the missing underglow.
Offline iJeeSung
« Reply #173 on: Sun, 29 September 2019, 03:48:32 »
So if it’s screwed on that means we could opt in for it and unscrew it to remove it if we wanted too?
Offline Xantus
« Reply #174 on: Sun, 29 September 2019, 05:04:36 »
« Last Edit: Sun, 29 September 2019, 05:11:42 by Xantus »
Offline Klyback
« Reply #175 on: Sun, 29 September 2019, 05:26:18 »
Is there midnight green Brass-Electrophoresis plate option?
Offline Omnomnominous
« Reply #176 on: Sun, 29 September 2019, 05:56:36 »
Midnight green is an anodised colour, so I doubt it.
Offline SuddenlyDonkey
« Reply #177 on: Sun, 29 September 2019, 09:35:30 »
seconded!
Offline noodleman
« Reply #178 on: Sun, 29 September 2019, 09:48:33 »
The blocker will still be there. Just the logo portion is screwed in for a seperate colour.
Offline senter
« Reply #179 on: Sun, 29 September 2019, 14:29:42 »
Sure. I'll post later when I receive the prototype.
I mean something like this
The difference is that you don't need to solder the wire on the MCU.
Here's a photo of a Leaf 60 PCB.
Can you see the VOG pads? They are for soldering the WS2812 LED strips.
Offline senter
« Reply #180 on: Sun, 29 September 2019, 14:30:56 »
If you remove it, there's a slot on the top right.
Offline senter
« Reply #181 on: Sun, 29 September 2019, 14:31:31 »
There's no Electrophoresis midnight green option.
Offline aydio
« Reply #182 on: Sun, 29 September 2019, 14:52:29 »
When I choose PC plate, Is there anything that speaks against the rubber sheet between the plate and PCB look-wise?
Offline Gumberculese
  • Man, Machine, Scientist?
« Reply #183 on: Sun, 29 September 2019, 15:13:24 »
Am I looking at the layouts correctly that the hotswap PCB does not support split backspace?
Offline fault_lin3
« Reply #184 on: Sun, 29 September 2019, 16:12:12 »
Got it, so looks like it'll be simple but a bit ghetto looking compared to presoldered smds. Totally understand tho, thanks for the reply!
Offline OmniSzron
« Reply #185 on: Sun, 29 September 2019, 18:54:46 »
I'm pretty sure the sockets would interfere with the mounting holes if they were to accommodate both layouts. They had to go with either one of them and they chose full backspace.
Offline jooobe
« Reply #186 on: Sun, 29 September 2019, 20:31:10 »
You got a fully built one with sound clips? Maybe send one to taehatypes
« Last Edit: Sun, 29 September 2019, 20:33:13 by jooobe »
Offline iJeeSung
« Reply #187 on: Sun, 29 September 2019, 20:32:13 »
You got a fully built one yet and sound clips? Maybe send one to taehatypes
That man can even make a Tofu sound amazing.
Offline jooobe
« Reply #188 on: Sun, 29 September 2019, 20:34:25 »
I’m fighting the urge to buy right now, spent a lot of money this past two and a half weeks
Offline senter
« Reply #189 on: Sun, 29 September 2019, 21:49:50 »
The hotswap prototype PCB is finished as well. Will test it later.
Offline senter
« Reply #190 on: Sun, 29 September 2019, 21:56:01 »
I haven't decided yet on the exact material of the sheet. The original plan was to use some kinds of foams. It turned out to be very difficult to cut the foams precisely. Laser doesn't work well on most foam materials. My last choice is clear rubber sheets which will work without problems.
The optional sheet will change how the plate looks when you use PC plates.
Offline senter
« Reply #191 on: Sun, 29 September 2019, 21:57:26 »
This. The split-spacebar can only be either 6.25u or 7u, not both. We chose 6.25u.
Offline olsen34
« Reply #192 on: Sun, 29 September 2019, 23:01:48 »
I can't decide on the top and middle case colors. Should I go for Teal/Teal or Teal/Black?
Offline thecyangiant
« Reply #193 on: Sun, 29 September 2019, 23:57:32 »
Additionally this means that you cannot have a split spacebar and wkl top, due to the wkl top not supporting 6.25u spacebar.
Sent from my SM-N950U using Tapatalk
Offline SlamMakanen
« Reply #194 on: Mon, 30 September 2019, 10:30:45 »
Am I being totally blind?? I cannot find the order link
Offline Lil
    • designedbydark
« Reply #195 on: Mon, 30 September 2019, 10:40:15 »
It's a Google form, then the gb runner invoices you for your order via email
Offline SlamMakanen
« Reply #196 on: Mon, 30 September 2019, 11:00:07 »
Awesome. Can't find that either though....
Offline suparnemo
« Reply #197 on: Mon, 30 September 2019, 11:40:54 »
It's immediately under the photos. Look for "Google form for placing orders"
Offline nicx
« Reply #198 on: Mon, 30 September 2019, 18:03:56 »
In for a board for sure, but would love to see a PC top with the Kanji logo. Any hope to see an example before hand? Like others have said, I would love to have that option but only if it looks good and not look janky.
Offline Topernicus
« Reply #199 on: Mon, 30 September 2019, 18:07:20 »
I have a couple questions...
First, have you had a chance to weigh the weights?
I'm curious about the weight difference between brass/aluminum, although the lack of a space grey brass option might make that a moot point.
Second, if we make multiple orders, will they be shipped together?
Just wondering if I'll be paying shipping twice if I order two boards, or if they can be combined to save on shipping costs.
