Author Topic: [IC] Acrylic Discipline 65% Case (On hold - COVID 19)  (Read 42621 times)
Offline alanskiii
Re: [IC] Acrylic Discipline 65% Case (updated 11/27/19)
« Reply #50 on: Tue, 24 December 2019, 16:54:20 »
Just finished building my discipline! I wanted to try out some winnja hotswap sockets, I think some rigidity would do this board real nice. Can’t wait to see what color options too! Although I might be more fond to straight clear.
Offline HoodrowThrillson
« Reply #51 on: Tue, 24 December 2019, 21:15:40 »
Prototype built! Need to take photos tomorrow maybe?
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline paintbeat
« Reply #52 on: Tue, 24 December 2019, 21:28:05 »
Super exciting!! Also Merry Christmas!
Offline Funkzilla
« Reply #53 on: Wed, 25 December 2019, 01:28:48 »
Newsletter somewhere? Or just eye this thread? Haha
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #54 on: Wed, 25 December 2019, 05:34:22 »
Woo!! Christmas prototype pictures! I'm excited to see them! And Merry Christmas!! (:
Offline alanskiii
« Reply #55 on: Tue, 31 December 2019, 14:24:18 »
Just thought of something, will the plate support different bottom row layouts?
« Reply #56 on: Sun, 05 January 2020, 09:28:08 »
Yup, just added it to the original post, also you can sign up here
Yup, that's one of the fixes that will be done for the GB.
Good morning from the sunny East Coast of USA. I've updated the IC with pictures of the completed proto (yes, my left alt key is crooked because i didn't fully seat the switch. And yes, it's a little dusty. And yes, I took it outside since my apartment gets terrible inside lighting).
GB date for this is TBD, I've added a survey to figure out what color they would like for the layer between the PCB and plate as well as a notification form to be notified when GB is live.
If you have any questions, feel free to ask away!
« Last Edit: Sun, 05 January 2020, 09:40:29 by HoodrowThrillson »
Offline xchangmanx
Re: [IC] Acrylic Discipline 65% Case (updated 12/5/2020)
« Reply #57 on: Sun, 05 January 2020, 13:23:42 »
Awesome, I've been searching around for this build but glad the GB is starting up again so I can attain one of these boards.
Offline Ensaum
« Reply #58 on: Sun, 05 January 2020, 20:49:53 »
I wish you luck with the group buy. Unfortunately, I'm going to have to back out if high profile is no longer a consideration. I'll just have to keep looking for another case.
Offline break
« Reply #59 on: Sun, 05 January 2020, 21:22:22 »
Bummer - was excited for this but the news (elsewhere) that it won't be compatible with future Discipline GBs means I'm out. Best of luck with this GB, and hope to see more rounds in the future!
Offline Zeelobby
« Reply #60 on: Sun, 05 January 2020, 21:33:14 »
Yeah. In the same boat. Love the discipline board. Love the simplicity of this case. But will have to wait for the next round of both (which hopefully comes soon!)
Sent from my Pixel 3 XL using Tapatalk
Offline alanskiii
« Reply #61 on: Sun, 05 January 2020, 23:15:21 »
What’s not compatible?
Offline Zeelobby
« Reply #62 on: Mon, 06 January 2020, 05:14:09 »
"I talked to him and he said he's planning on running a few other keyboards he's design first before rerunning Discipline. He also mentioned that the mounting for the diodes and such will be slightly shifted so please note that this is for boards that have already ran (as of 12/5/2020)"
From the most recent post about this case on Reddit. So the layout for future Discipline 65% may be different enough that this case won't work. So this is really just a buy for those who already ordered a pcb from the first run.
« Reply #63 on: Mon, 06 January 2020, 06:18:57 »
So we will be offering PCBs (just the PCBs but a link to where you can purchase the diodes, etc.) also. Which means if you want a Discipline and want a case, it's possible to do so.
What's different is how the very top acrylic piece covering the diodes, MCU, etc are mounted. He said he's switching to 6 mounting points rather than the 4.
Offline Zeelobby
« Reply #64 on: Mon, 06 January 2020, 08:03:19 »
Ah. Ok. So this case doesn't use the original mounted cover? Or should fit the new one without issues?
When the PCB without hardware is offered will links be provided for a baseplate that's compatible with this case along with the other components?
Is it going to be the original pcb or the new one, or is the new one only going to be available in the future as a kit?
Sorry for all the questions, but they're important for anyone who didn't manage to get in on the first run of Discipline.
« Reply #65 on: Mon, 06 January 2020, 17:24:32 »
Email notification signup link is broken for me
« Reply #66 on: Mon, 06 January 2020, 18:04:00 »
It will not use the original cover (the prototype has 2 extra holes around the USB-C area)
I will need to double check about the base plate (I presume it's the very bottom piece you're talking about?)
Original PCB that is compatible with this case.
And the questions are fine, I concur with your sediments (allows anyone interested to know the information they need)
Sorry about that, fixed it.
Offline Zeelobby
« Reply #67 on: Mon, 06 January 2020, 18:30:26 »
All great to hear! Thank you! And yeah, you were right about base plate. Sometimes getting a re-release of a pcb can be easier then getting the hardware that matches it. Not that I couldn't commission out to get one, but it's nice when it just fits the same footprint and the holes match up.
Offline break
« Reply #68 on: Tue, 07 January 2020, 14:36:59 »
This is all very interesting...looking forward to more news soon!
Re: [IC] Acrylic Discipline 65% Case (updated 1/21/2020)
« Reply #69 on: Tue, 21 January 2020, 18:27:42 »
Updated IC with GB date.
We will be offering the PCB and bottom piece at an additional cost as well as a link to where you can find all the through hole components.
Offline Zeelobby
« Reply #70 on: Tue, 21 January 2020, 18:59:15 »
Wish I hadn't missed buying the board. I'd love a plaid case somewhere down the road.
« Reply #71 on: Wed, 22 January 2020, 07:58:13 »
With this GB, you'd be able to buy the board.
Offline Zeelobby
« Reply #72 on: Wed, 22 January 2020, 08:07:17 »
Ah. Awesome. I didn't know. I know it's sold out online, but I'm definitely in now if the PCB and components are available as part of the GB.
Offline cosmo10292
« Reply #73 on: Mon, 10 February 2020, 13:50:45 »
Have you considered adding a num pad aka Discipad to the GB? Id love to get both for work
« Reply #74 on: Mon, 10 February 2020, 16:48:49 »
I have considered it but Worldspawn is very busy running his own GBs so we're trying to keep it simple this time around.
Offline alanskiii
« Reply #75 on: Mon, 10 February 2020, 16:59:42 »
Will these cases come with new hardware? My discipline came with a couple wonky screws.
« Reply #76 on: Wed, 12 February 2020, 09:05:13 »
That is the plan. And to try to source gold colored hardware to match.
Offline StanleyLelnats
« Reply #77 on: Sun, 01 March 2020, 08:57:47 »
Is this still slated to open today?
« Reply #78 on: Sun, 01 March 2020, 11:47:11 »
Sorry, won't open today. Been busy with my other GB. I'm planning on having it open up March 9th and having it open till the end of the month. I will have a GB thread made when final launch date is set and I gather all the details.
Offline i luv chuletas
« Reply #79 on: Sun, 01 March 2020, 21:06:08 »
Oh this is awesome, glad to hear this will come back!
Will definitely pick one up when the time comes!
« Reply #80 on: Tue, 03 March 2020, 09:54:51 »
GB date determined, we will be offering another type of case alongside this one as well. Be on the lookout for it.
Offline alanskiii
« Reply #81 on: Tue, 03 March 2020, 12:36:22 »
So ready for this! Thank you for update!
« Reply #82 on: Tue, 10 March 2020, 06:33:10 »
GB date got pushed back since Worldspawn needs a little bit more time to cut the acrylic case uploaded by Cosey. Once I receive the case and take nice photos, we can begin GB.
Re: [IC] Acrylic Discipline 65% Case (On hold - COVID 19)
« Reply #83 on: Sun, 15 March 2020, 21:10:40 »
Project on hold as materials and shop are both closed due to COVID 19
Offline wakaward
« Reply #84 on: Fri, 24 July 2020, 07:50:28 »
Has there been any updates from the shops since March?
