Author Topic: [GB] GMK Dracula (CLOSED) — Shipping!  (Read 383577 times)
Offline pikku-allu
  • IG: @kinnalek
« on: Fri, 04 October 2019, 12:54:11 »
$ gmk install -g @dracula/core-module
$ gmk install -g @dracula/highlight-module
$ gmk install -g @dracula/nightmode-module
$ gmk install -g @dracula/whitespace-module
$ gmk install -g @dracula/minify-module
$ gmk install -g @dracula/localization-module
$ gmk install -g @dracula/command-module
$ gmk install -g @dracula/err-module
$ gmk run deploy
> Starting 'deploy' ...
> Uploading: geekhack/group_buys/gmk-dracula/master.tar.gz
> [=============================] 100% 0.0s
> Initializing GB ...
Welcome to the GMK Dracula group buy thread! ▓▒░
Introducing GMK Dracula, a keyset based on the glorious Dracula Theme color-scheme. GMK Dracula turns the software aesthetic into keyboard keyset form, expanding the theme even further with add-on modules. The set features dark greyish blue tones with dark blue-purple-gray alphas. The default legend color is a contrasting neutral/cool white, which adds to the overall legibility of the classic text + icon legends. In addition, the Core and add-on modules include legends and accent keys in various pastel and neon colors, all based on selected Dracula Theme colors.
> Setting up proxies ...
> Proxy set to 'Dixie Mech' ...
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ GB_INFO.txt ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
├── GB_vendors/
│ └── proxy_list/
│     ├── NA - Dixie Mech [link]
│     ├── EU - Mykeyboard.eu [link]
│     ├── Oceania/Asia - Daily Clack [link]
│     └── China/Asia - iLumkb [link]
└── GB_date/
    ├── Group Buy - October 4th – 31st 2019
    └── Shipping Status -
Shipping! [September - October 2021]
Modules
Core【 MODULE】
The Core Module is the starting point of the set, featuring classic multicolored syntax highlighting of the Dracula Theme. The module offers compatibility for most layouts, while keeping the cost down by not bloating the kit with too much options.
5 new keys included @1500 orders! R2 Home, R3 1.75u stepped Control, R3 1u Code, Home, and End keys.
Highlight【 MODULE】
Spice up your set with fully colored accent keys for extra highlighting, featuring cherry-picked theme colors.
Nightmode【 MODULE】
If you enjoy a CLEAN look, it's time to turn on the nightmode for GMK Dracula.
Tone down the look of your set with a unified modifier color-scheme with the Nightmode Module.
Whitespace【 MODULE】
Whether you like to use spaces or tabs for indentation, that's up to you …
Here's some whitespace inserting blocks for everyone to use, including accent colored ones.
Minify【 MODULE】
Here it is! The ultimate kit for 40%, ortholinear, and split layout keyboards. But wait, there's more! Even a second B key is included in case your dog eats the other one.
Localization【 MODULE】
Language support for Nordic (Danish, Finnish, Swedish, Norwegian), German, and UK layouts.
Command【 MODULE】
What did you think it was going to be called? Support for macOS specific keys. Starting at $999.
> 'deploy' encountered an error after 120 ms
> gmk ERR! Error: Fatal: access denied
> gmk ERR! @dracula/err-module not found
░░░░░░░░░░░░░░░░░ ERR! ░░░░░░░░░░░░░░░░░
├── IC/
│ └── GMK_modules/
│     ├── core-module
│     ├── highlight-module
│     ├── nightmode-module
│     ├── whitespace-module
│     ├── minify-module
│     ├── localization-module
│         └── EU.eww
│     ├── command-module
│     └── err-module/
│         └── vim-arrows
├── .ic.config
├── .ne-iso.avail
├── .ne-icon-mods.avail
├── FAQ
└── __feedback__/
    └── form
ERR!【 MODULE】
ERR░R█░▓▓▒░▒▓▒██RR█R!
Deprecated Module Versions:
RAMA Keycaps
  • Finish: Lightly Bead Blasted + Anodized/E-White processed + Laser Etched + Enamel Fill (colors matched to keyset colors)
  • Profile: Cherry Profile - Escape Row (R1)
  • Stem Type: Cherry MX
GMK Dracula x RAMA — Eye, Aluminum E-White + Dark Blue Gray Enamel Fill
GMK Dracula x RAMA — ERR!, Aluminum Anodizing + Dark Blue Gray Enamel Fill
Deskmats
Dracula Eye & ERR! Deskmats
  • Size: 900x400x4mm
  • Rubber bottom
  • Stitched edges
  • Cloth top
> Starting subtask 'rebuild' ...
> Starting subtask 'renders' ...
Renders
Bauer by Dixie Mech
Album with all the Bauer renders: https://imgur.com/a/QURe7BY
TGR Alice
TGR Jane V2 CE
TGR-910
Album with all the TGR renders: https://imgur.com/a/Kk1WKmF
'Wickle Tickle'
board and renders by Kingk22
More renders coming soon …
Colors
The colors are to be matched as close to the Dracula Theme colors as possible using custom colors, the base colors are very dark grayish blue. A GMK stock color may be used for the white alpha legend color.
The plan is to match the colors to Pantones first, then order plastic color chips, which GMK can then match their plastics to. I think this method allows for a great range of colors to choose from, but still retains the color matching accuracy with plastic chips from Pantone.
A color comparison with other popular/similar GMK sets:
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ COLOR_COMPARISON.md ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
├── The colors are represented as accurately as possible using the correct color codes, using neutral lighting.
└── The second version has a neutral background color instead of a stylized one for an even more accurate comparison, as perception of color is relative to the surroundings after all.
Gloomy Colors™
│   Color   │   Hex    │     RGB     │      HSL      │   │
│ Modifiers │ #282a36  │    40 42 54 │ 231° 15% 18%  │ ■ │
│ Alphas    │ #44475a  │    68 71 90 │ 232° 14% 31%  │ ■ │
│ Legends   │ #f8f8f2  │ 248 248 242 │ 60° 30% 96%   │ ■ │
│ Pink      │ #ff79c6  │ 255 121 198 │ 326° 100% 74% │ ■ │
│ Purple    │ #bd93f9  │ 189 147 249 │ 265° 89% 78%  │ ■ │
│ Cyan      │ #8be9fd  │ 139 233 253 │ 191° 97% 77%  │ ■ │
│ Yellow    │ #f1fa8c  │ 241 250 140 │ 65° 92% 76%   │ ■ │
│ Green     │ #50fa7b  │  80 250 123 │ 135° 94% 65%  │ ■ │
│ Red       │ #ff5555  │   255 85 85 │ 0° 100% 67%   │ ■ │
FAQ
> ne icon mods avail
> At least not in the base kit
Changelog
│                 Commit                  │     Date     │ Branch │
│ feature: added color comparison         │ [2019-06-08] │ master │
│ feature: announced vendors              │ [2019-05-30] │ master │
│ feature: added feedback form            │ [2019-05-22] │ master │
│ fix: added Full HHKB layout support     │ [2019-05-22] │ master │
│ (2x R4 1u Ctrl/Alt + 2x R4 1.5u Super)  │              │        │
│ feature: added initial IC               │ [2019-05-15] │ master │
  • Added color comparison [2019-06-08]
  • Announced vendors [2019-05-30]
  • Added feedback form [2019-05-22]
  • Added full HHKB layout support (2x R4 1u Ctrl/Alt + 2x R4 1.5u Super) [2019-05-22]
  • Added initial IC [2019-05-15]
TODO
  • More renders!
Acknowledgements
  • Huge thanks to Oblotzky for advice and suggestions regarding the kits and everything else.
  • Shout-out to Qlavier for feedback on the project!
  • Big thank you to Dixie for everything!
  • Thank you Yuktsi for providing the TGR board models for rendering
  • Thank you Kingk22 for the 'Tickle Wickle' renders
All the renders, kit designs, novelties and graphics are done by me, if not stated otherwise.
« Last Edit: Fri, 17 September 2021, 13:07:00 by pikku-allu »
Offline pikku-allu
  • IG: @kinnalek
Re: [GB] GMK Dracula — Group buy is live!
« Reply #1 on: Fri, 04 October 2019, 12:54:29 »
reserved
« Reply #2 on: Fri, 04 October 2019, 14:28:19 »
Approved! :thumb:
Offline lee jeong woo
« Reply #3 on: Fri, 04 October 2019, 14:34:26 »
Is there a price adjustment according to Moq?
Offline Pizza_on_Pineapple
« Reply #4 on: Fri, 04 October 2019, 14:59:33 »
I'm so excited to get my hands on this. Dracula theme is the best :)
Offline art3mis
« Reply #5 on: Fri, 04 October 2019, 15:08:26 »
Considering the amount of GMK Sets running the past months, when is this expected to be produced? I am wondering, how long does it take GMK to produce one group buy run? :)
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #6 on: Fri, 04 October 2019, 15:21:46 »
This is one of the best executed ICs/GBs I've seen in ages. Best of luck, altho I'm sure you won't need it!  :thumb:
Offline nephlock
« Reply #7 on: Fri, 04 October 2019, 15:56:57 »
Already in. Very well done Pikku, can't wait to see this set crush it!
Offline Starius
« Reply #8 on: Fri, 04 October 2019, 19:12:41 »
Sorry if I'm missing something obvious here, but where exactly is the link to buy it?
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #9 on: Fri, 04 October 2019, 19:21:18 »
https://dixiemech.store/products/gmk-dracula
in for base, nightmode and err. can't wait
Offline Starius
« Reply #10 on: Fri, 04 October 2019, 19:27:45 »
Offline norb
« Reply #11 on: Fri, 04 October 2019, 19:48:47 »
this is the cool version of Dolch, fight me! :eek:
Offline pikku-allu
  • IG: @kinnalek
« Reply #12 on: Fri, 04 October 2019, 19:58:17 »
Oops, added the links now.
Offline Saga
  • Pew Pew Particle Accelerators
« Reply #13 on: Fri, 04 October 2019, 20:26:03 »
Stupid question but can someone tell me how purple the alphas are? I'm slightly colourblind and there's a range where I know I may have an issue but I (obviously) can't tell if it's really, really blue/grey or actually quite purple.
Offline maly149
« Reply #14 on: Fri, 04 October 2019, 21:25:21 »
I would say it has a very slight purple tint- but definitely still gray!
Offline sevenseacat
« Reply #15 on: Fri, 04 October 2019, 22:43:22 »
Already put in my order at DailyClack for base, err, nightmode, and highlight 👍
I know I said this in Discord already but I think alphas + err + nightmode is going to be a very popular combo - perhaps if this runs again that could be made into a second base kit?
Offline Saga
« Reply #16 on: Fri, 04 October 2019, 23:15:19 »
I definitely added those and Norde to my cart before balking at $300+
Offline click clack jack
« Reply #17 on: Sat, 05 October 2019, 08:46:25 »
In for base and accent! Woot! Set of the year imo!
Offline blakstealth
« Reply #18 on: Sat, 05 October 2019, 10:38:33 »
congrats on the massive day 1!
https://www.facebook.com/dixiemech/photos/a.321006258330250/774999656264239/?type=3
Core: 219
Highlight: 121
Nightmode: 75
Whitespace: 75
ERR!: 115
Command: 26
Minify: 30
Localization: 15
Offline futurecrime
  • Get Zooted
« Reply #19 on: Sat, 05 October 2019, 12:49:19 »
Love this colourway and the whole presentation of it. First GMK kit I’m going in on for ages. Considering not getting nightmode but then I remember how I didn’t get mono mods in Oblivion and ended up spending ages trying to get them aftermarket for a decent price/trade. Better to be safe than sorry I guess. GLWGB.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #20 on: Sun, 06 October 2019, 00:32:39 »
Core: 219
Highlight: 121
Nightmode: 75
Whitespace: 75
ERR!: 115
Command: 26
Minify: 30
Localization: 15
« Last Edit: Mon, 07 October 2019, 15:00:41 by dvorcol »
Offline b3nkei
« Reply #21 on: Sun, 06 October 2019, 08:57:29 »
50 euros just for the f13 key is going to hurt.
Offline IOVERCALLHISTIOCYTES
« Reply #22 on: Sun, 06 October 2019, 10:06:28 »
I’m sure I’m not the only person interested in ERR who wouldn’t want the f13 key? Can you split with someone on your side of the Atlantic?
« Last Edit: Mon, 07 October 2019, 16:10:20 by IOVERCALLHISTIOCYTES »
Offline nguyenhimself
« Reply #23 on: Sun, 06 October 2019, 11:13:16 »
Just noticed the ERR module's MOQ is 250. Is that because of the custom legends?
That set is like one huge novelty kit, huh?
Offline forevermadrigal
« Reply #24 on: Sun, 06 October 2019, 13:00:45 »
Actual moq is 100. Ideal moq is 250
Offline geewiz
Re: F13 key
« Reply #25 on: Sun, 06 October 2019, 13:20:35 »
I can ship you mine from Ireland.
Offline 1391401
  • MX CLEAR
« Reply #26 on: Sun, 06 October 2019, 15:26:48 »
I'm a simple man: I see a keyset that uses the same color scheme I've come to enjoy using in terminal and i3wm as well as vim style hjkl keys so I buy it.
People I've given money to from this webform who never respond to me and have not shipped me anything: ctrlalt.io 1 2, Team Readline Reputable alternatives to GH group buys: http://pimpmykeyboard.com, https://www.massdrop.com,
Offline Saga
« Reply #27 on: Sun, 06 October 2019, 15:57:10 »
*cries in Solarized Norde*
Offline LevelSteam
« Reply #28 on: Sun, 06 October 2019, 17:25:31 »
Crap now I'm worrying if I need those too.
Offline pikku-allu
  • IG: @kinnalek
« Reply #29 on: Mon, 07 October 2019, 10:47:02 »
> Starting 'update' ...
> Uploading: geekhack/group_buys/gmk-dracula/update.tar.gz
> ERR! Error: outdated proxy numbers
░░░░░░░░░░░░░░░░░ GB_STATUS.txt ░░░░░░░░░░░░░░░░░
├── GB_units_ordered/
│ └── All proxies/
│     ├── Core --------- 423
│     ├── Highlight ---- 190
Nightmode ---- 111
│     ├── Whitespace --- 112
│     ├── Minify -------- 57
Localization -- 21
│     ├── Command ------- 54
│     └── ERR! --------- 197
└── GB_status_date/
  └── October 7th [2019-10-07]
Amazing numbers in the first few days!
« Last Edit: Mon, 07 October 2019, 11:04:13 by pikku-allu »
Offline hineybush
  • student of error
« Reply #30 on: Mon, 07 October 2019, 12:08:46 »
│ └── All proxies/
Nightmode ---- 111
Localization -- 21
└── GB_status_date/
unreal. glad to be a part of it  :thumb:
Offline dvorcol
« Reply #31 on: Mon, 07 October 2019, 14:59:02 »
│ └── All proxies/
Nightmode ---- 111
Localization -- 21
└── GB_status_date/
Looks like we're gonna need a bigger graph...
<-- history to date
« Last Edit: Fri, 11 October 2019, 23:38:56 by dvorcol »
Offline fabryrock
« Reply #32 on: Mon, 07 October 2019, 15:22:01 »
for the 2k goal there is gonna be a raffle for a free base kit or more keys in the kit eventually? anything in mind on that regard? thanks
« Reply #33 on: Mon, 07 October 2019, 16:06:49 »
Such fantastic numbers, truly one for history here!
« Reply #34 on: Mon, 07 October 2019, 16:07:59 »
Like the eponymous character, this set is a monster.
Anyone want Minify but not the 2.25u/2.75u split spacebars?
Offline b3nkei
Re: F13 key
« Reply #35 on: Mon, 07 October 2019, 17:54:52 »
Thanks, i'll send you a message if i remember when we get the sets. I'm from Spain  :thumb:
Offline MrFurrior
« Reply #36 on: Tue, 08 October 2019, 11:41:56 »
Localisation kit is pretty pricey for just 4/5 keys I might use. Nearly 20 euros more than other GMK localisation kits?
Offline pikku-allu
  • IG: @kinnalek
« Reply #37 on: Tue, 08 October 2019, 13:46:12 »
That's because the MOQ for that is only 50, which is achievable. No profit is being made from that kit either. You could always find someone who'd need other keys to split the kit with.
Offline AlcoholEnthusiast
« Reply #38 on: Tue, 08 October 2019, 14:27:21 »
In for Core, Nightmode, Highlight and Err. Super excited about this one. Great job on the IC/GB and excited to see how well this one does by the end.
Offline sevenseacat
« Reply #39 on: Tue, 08 October 2019, 20:30:35 »
wait, GMK has MOQs less than 100? and we still couldn't have Colemak??? 😂
Offline jizzaztartist
« Reply #40 on: Wed, 09 October 2019, 07:15:02 »
in for 1 of each, except localisation
Offline mlnr
« Reply #41 on: Wed, 09 October 2019, 09:28:50 »
this feels like armed robbery
« Reply #42 on: Wed, 09 October 2019, 10:08:52 »
If you pool Git, regular, monochrome, and assembly, GMK oblivion sold 3000 kits, and colevrak sold 61 there. I think the 50 MOQ is still hard.
Offline supermunny
« Reply #43 on: Thu, 10 October 2019, 12:08:16 »
Anyone interested in splitting the Localization kit? Here's the keys I wouldn't need: https://imgur.com/a/1dhB4I4. Guess I could split the Highlight & Command kits too, I'd be happy with about 1/3 of the keys on those.
Offline steezkeez
« Reply #44 on: Thu, 10 October 2019, 12:22:31 »
This set really grew on me the more I looked at it. I went from hard pass (never had a great affinity for blueish hues) to in on Core + Nightmode + Highlight + ERR!
Offline art3mis
« Reply #45 on: Fri, 11 October 2019, 13:01:37 »
The MOQ of 50 will be hard enough to reach as it is  :)) everyone who needs it should buy their own xD
Offline KingOfMemes
« Reply #46 on: Fri, 11 October 2019, 13:08:55 »
What local are you in?
Offline KingOfMemes
« Reply #47 on: Fri, 11 October 2019, 13:17:47 »
What locale are you in?
Edit: sorry for the double post
Offline pikku-allu
  • IG: @kinnalek
« Reply #48 on: Fri, 11 October 2019, 15:58:04 »
│ └── All proxies/
│     ├── Core --------- 569
│     ├── Highlight ---- 255
Nightmode ---- 145
│     ├── Whitespace --- 154
│     ├── Minify -------- 79
Localization -- 28
│     ├── Command ------- 74
│     └── ERR! --------- 263
└── GB_status_date/
  └── October 11th [2019-10-11]
We are breaking records left and right!
Enjoy this new render of GMK Dracula on a black TGR Alice:
Offline LXVRGS
« Reply #49 on: Fri, 11 October 2019, 17:09:19 »
mama mia
