Author Topic: [IC] GMK BlauGrau (Blue-Grey) New Kits Posted!  (Read 33740 times)
Offline ABrotherThatIsUndercover
Re: [IC] GMK BlauGrau (Blue-Grey) New Kits Posted!
« Reply #50 on: Tue, 12 May 2020, 04:23:40 »
Here to bump! I hope this project become stale and die  :(
You can buy it here already https://www.originativeco.com/products/denim
Not pocking at this point the thread creator. GMK Denim got probably not enough traction and it flew under the radar for the most people.
Yea, the reason I ultimately decided not to continue with the set in this incarnation is because Denim ended up looking pretty similar to my vision for BlauGrau, and looks really good, so I decided to put the set on hold/move onto other things so that I didn't step on toes.
« Last Edit: Tue, 12 May 2020, 04:28:52 by ABrotherThatIsUndercover »
« Reply #51 on: Tue, 12 May 2020, 17:57:53 »
I'm going to go ahead and lock this thread as the project in this form isn't going to happen and if I want to bring it back in it a different form, I'll make a different thread. Thanks for the support and feedback throughout this whole process ya'll :thumb:
