Author Topic: [HELP] KBP V60 MQS left modifier keys switched & "C" not registered  (Read 1853 times)
Offline kagamineryuki
Hi, i'm new in this forum. I'm sorry if i posted this in the wrong room but please, i need your help.
recently, i bought KBP v60 MQS (around 3 months ago).
all smooth sailing until someday almost all of the modifier keys swapped and 1 of alphabet isn't working.
here are the list of keys that got swapped or not working :
fn >> doesn't work
left ctrl >> tab
left win >> alt
left alt >> windows
caps lock >> doesn't work
left shift >> doesn't work
tab >> doesn't work
C >> doesn't work
weird enough, the right modifier keys work just fine. i already did firmware reflash, reset all the dip switch to default (off) and restart my PC.
last time that i did to this keyboard was mod click it and clipping bottom part of the dampener but im very sure that the switch leaf are not damaged (because i inspect it one by one and i see nothing damaged).
please guys i need your help. thx
« Last Edit: Sat, 05 October 2019, 13:19:18 by kagamineryuki »
