Author Topic: Scuffed my DZ60  (Read 4647 times)
Offline sowon
Scuffed my DZ60
« on: Mon, 07 October 2019, 08:44:29 »
Hi, sorry if this is in the wrong sub but I'm in a bit of a pickle with my new $350 board and I'm getting increasingly nervous about bricking my new PCB.
I got my new keyboard with a DZ60RGB-ANSI PCB all installed, and I tried flashing QMK Firmware using QMK Toolbox, and it told me to do Esc + input cable and at that point was when my PCB stopped working.
Windows now spits out an error saying unrecognised device on both my PC and my Manjaro Linux laptop  :(
Any help is much appreciated!
Offline rxc92
Re: Scuffed my DZ60
« Reply #1 on: Mon, 07 October 2019, 09:11:52 »
Is there a hard reset button on the PCB itself? If not, you can manually reset it by connecting the two leads with a paper clip.
Offline Sup
Re: Scuffed my DZ60
« Reply #2 on: Mon, 07 October 2019, 15:46:38 »
The new DZ60 has a reset button you need two connect the two pins it's somewhere in the middle of the PCB. It's best to compile a new hex file and flash it. Everything should work again like normal after that.
« Last Edit: Tue, 08 October 2019, 12:21:51 by Sup »
current
Coming soon
