Author Topic: [IC] WRISTBREAKER TKL  (Read 367600 times)
Offline bisoromi
  • Formerly Duwang
  • owo
Re: [IC] WRISTBREAKER TKL ** ON HOLD **
« Reply #50 on: Mon, 14 October 2019, 17:29:22 »
Sometimes hollow boards can sound good, and other times they sound bad. This seems to be the latter. Is the interior parallel with the plate and pcb? If it's not, that could explain the sound.
This is a cross section view of the board
The PCB and plate are parallel with the bottom case. I wonder if using a 1.2mm PCB has anything to do with it? Although I'm skeptical of how much a .3mm difference would make in terms of sound. I think the biggest factor to the sound might be because of the keycaps. I'm planning on making another typing test soon with PBT caps instead.
What plate material are you currently using with that prototype, aluminum? I honestly don't think that sounds bad.  Just an idea but, I'm curious if variances in the how "hollow" the bottom half of the case is from the inside could affect the quality of sound. Since the board has such a high angle, there is a lot more material on the bottom case to work with. If anything comes of it you could even go to try providing more of a cavity behind the alphas similar to the concept of a half-plate. Granted, there are a lot of other factors that play into sound quality such as switches, keycaps, plate, case material, etc.
FYI, I am only hearing sound out of the left channel on the video.
The plate is 1.5mm brass. I use a 'standard' 9mm distance from top of plate to bottom case. The bottom case only has a depth of 3mm. Are you saying that you think increasing this depth would improve the sound? My thinking is that that would make it sound hollower, but I don't know how sound works at all so you might be right.
Also I'll fix the video soon, I didn't catch that the audio was only on the left channel >.>
« Last Edit: Thu, 30 January 2020, 17:50:46 by bisoromi »
(credits to Kokaloo)
Offline Steezus
  • Keeper of Facts
« Reply #51 on: Mon, 14 October 2019, 17:36:33 »
That is correct in what I was trying to portray. I am in no way knowledgable on sound myself either. It could very much sound hollower if the depth is increased. I was imagining more of an echo. It's just food for thought as I personally have never seen any board design to improve acoustics in such a way. Perhaps nobody has done it because it is pointless.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #52 on: Mon, 14 October 2019, 17:53:49 »
i want you and this
Offline cspirou
« Reply #53 on: Mon, 28 October 2019, 15:28:06 »
Finally a keyboard for my hunt-and-peck style!
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #54 on: Wed, 06 November 2019, 13:19:14 »
this board sounds more hollow than my social life
Offline DoctorNunu
  • Masterworks
« Reply #55 on: Thu, 07 November 2019, 03:54:12 »
As a cheery on top you just had to use SA caps  :))
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #56 on: Thu, 07 November 2019, 10:07:33 »
:c
I love SA!!
Offline vaughno
« Reply #57 on: Sat, 23 November 2019, 15:09:56 »
silver and i buy!!!
Unikorn | Orion v3 | GSKT-00
Offline papayapyjamas
« Reply #58 on: Mon, 13 January 2020, 01:43:40 »
no update? :(
Offline SUB01
« Reply #59 on: Mon, 13 January 2020, 11:01:37 »
The maker's wrists are broken so he can't type anymore :c
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #60 on: Thu, 30 January 2020, 17:39:41 »
Hi all!
I apologize for the lack of updates.
Unfortunately I'm going to have to indefinitely put this project on hold as there are other projects I'm working on right now that I want to focus on. I will definitely come back to this project but right now I'm not sure when.
If anyone has any questions please don't hesitate to send me a message!
Thanks for understanding!
Offline Tonkatonk
« Reply #61 on: Thu, 30 January 2020, 17:46:08 »
Hi all!
I think you should sell the design to a vendor, I think this tkl design could become as iconic as something like the gh60
Noxary PC268.2 | Red Nunu | Purple PC Nunu | Ogre | Vulcan Pro
« Reply #62 on: Thu, 30 January 2020, 17:46:57 »
i love u biso
Offline meiosis
  • Time
« Reply #63 on: Sun, 07 March 2021, 01:03:18 »
Keyboards:
Aripeko TKL
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #64 on: Sun, 07 March 2021, 01:03:43 »
Offline long_qt_pie
« Reply #65 on: Thu, 09 June 2022, 16:27:43 »
And we’re back!
Jetfire | Mech 27 v1 | Mira SE | Singa | Orion 2.5 | Eo87 | Lubrigante | MGA | IBM F XT | AEKII | Lightpad | Exent | Dolphin Rev 2 | F1-8x | Mr Suit
Offline megaforce
« Reply #66 on: Thu, 09 June 2022, 17:07:15 »
while ur breaking your wrist, bisoromi is breaking my back
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline phinix
« Reply #67 on: Fri, 10 June 2022, 03:08:04 »
what are those keycaps?
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline wigol2506
    • Instagram
« Reply #68 on: Fri, 10 June 2022, 03:15:16 »
Those are SA Biso.
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline phinix
« Reply #69 on: Fri, 10 June 2022, 03:48:45 »
Those are SA Biso.
Aaah, right, that one, I remember. Such a nice colors, but design is crap. I wish you could pick those sets without face, just alphas in beige and dark mods.
« Reply #70 on: Fri, 10 June 2022, 04:08:04 »
damn he's back
Offline carlfink
  • metal rectangle enjoyer, @carl.#1208 on discord
« Reply #71 on: Fri, 10 June 2022, 09:04:11 »
revive this i need it now
Offline granola bar enthusiast
« Reply #72 on: Fri, 10 June 2022, 10:18:42 »
"our keyboards are designed with ergonomics in mind to give you the best typing experience possible"
« Last Edit: Fri, 24 June 2022, 23:49:07 by granola bar enthusiast »
Offline DaaDaa
« Reply #73 on: Fri, 10 June 2022, 15:07:10 »
big, burly, and heavy, and high is good, but why so butt-ugly?
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline Ansenki
  • Keybort
« Reply #74 on: Fri, 10 June 2022, 22:15:03 »
Will you take refunds if people don’t break their wrists from this…
also BEEG screws omg
Offline warmbidetaqua
« Reply #75 on: Fri, 10 June 2022, 22:35:53 »
hotdamn you can ski on that keyboard! glwic
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #76 on: Mon, 13 June 2022, 19:41:00 »
Offline hali
    • hali.studio
« Reply #77 on: Tue, 14 June 2022, 22:28:43 »
big supporter please make pink
Offline ankit
  • Formerly ankit-sachdeva
« Reply #78 on: Tue, 14 June 2022, 22:29:10 »
+1 for pink
Offline Riizmaa
« Reply #79 on: Tue, 14 June 2022, 22:30:11 »
+2 pink  :p
Offline Tree_
« Reply #80 on: Tue, 14 June 2022, 22:43:32 »
+3 pink
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #81 on: Fri, 24 June 2022, 20:26:07 »
+4 pink
Offline ThreadyKeycaps
    • ThreadyKeycaps
« Reply #82 on: Fri, 24 June 2022, 21:44:31 »
seems like angle is not adjustable. may be abit worried if it doesn't feel comfy. just my 2 cents!
Offline hali
    • hali.studio
« Reply #83 on: Fri, 24 June 2022, 22:46:45 »
this tkl is not for the weak
« Reply #84 on: Sun, 26 June 2022, 15:21:00 »
the old school solution for high angle is to put a shim under the front part of the board to flatten out the typing surface. obviously this will raise the front height.
but this is a board you buy specifically because of the high angle, because high typing angle is for chads
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #85 on: Sun, 26 June 2022, 17:16:43 »
Where we're going you don't need comfort...
Offline darthcapn
« Reply #86 on: Fri, 15 July 2022, 21:15:29 »
I had a dream that I was searching on mm for SA Biso for my wristbreaker. Woke up sad cuz I don't have a wristbreaker yet. Pls gib.
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline r4bbl3d4bbl3
« Reply #87 on: Sat, 01 October 2022, 10:38:20 »
Is this still going to be a thing? I need it
Offline singabore
« Reply #88 on: Thu, 16 February 2023, 18:29:01 »
where's my wristbreaker
Offline TheGreenLion172
« Reply #89 on: Fri, 17 February 2023, 00:32:21 »
And I thought 11 degrees was high :))
GLWIC!
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #90 on: Sat, 26 August 2023, 21:02:47 »
getting used with duck orions lately, i think id be ready for the 14degrees
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
