Author Topic: Need a help  (Read 6808 times)
Offline Kasey00
Need a help
« on: Fri, 11 October 2019, 04:09:32 »
Hi!
I got my new keyboard with a DZ60RGB-ANSI PCB all installed, and I tried flashing QMK Firmware using QMK Toolbox, and it told me to do Esc + input cable and at that point was when my PCB stopped working.
Windows now spits out an error saying unrecognised device on both my PC and my Manjaro Linux laptop.
Thanks for any help.
Re: Need a help
« Reply #1 on: Fri, 11 October 2019, 04:35:39 »
I have to go to work so won't be able to look at your answer but can you post the output for the keyboard from lsusb on Manjaro? (If in doubt unplug the board, run lsusb, plug board board back in, run it again - it's the new line)  This will show whether the keyboard is in standard or bootloader mode.
