Author Topic: [IC] KN2.10² (GB Thread Submitted)  (Read 25899 times)
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
« on: Sun, 13 October 2019, 08:33:51 »
Hey Geekhack friends, I am louis and today I want to bring our new project to the community: KN2.10² by thesiscamper.
Some renders by thesiscamper:
Some renders by myself:
Specs:
Make with 6063 aluminum for the case and brass for the weight.
4mm alum plate with a fixed layout.
Sandwich Mounting Designed.
The typing angle is 5 degrees.
Type C for PCB(QMK).
(Top case has 3 options: WK, WKL, and HHKB.)
Colors:
1)   E yellow + Black + E white
2)   Dark Grey + Cyan + Dark Grey
3)   Silver + Dark Red + Silver
Supported Layout:
Fixed Layout, compatible with stepped caps and split BS.
Timeline:
GB: end of Oct.
(The prototype will be ready in 1 week.)
Total spots we are offering: TBD
Follow our Instagram for the latest updates for the first time:
iLouis_07: https://www.instagram.com/ilumkb_com/
Thesiscamper: https://www.instagram.com/thesiscamper/
Discord Link: https://discord.gg/7upp2Xr
Updates:
Oct 24th, Prototype assembled with 205g0 lubed tangerines
« Last Edit: Mon, 28 October 2019, 14:22:23 by ilouis_07 »
Offline ilouis_07
    • ILUMKB
Re: [IC] KN2.10²
« Reply #1 on: Sun, 13 October 2019, 08:34:15 »
14th/Oct updates:
All the anodizing colors are customized, Dark Grey Pantone 432C, Cyan Pantone 7710C, Dark Red Pantone 7621C.
« Last Edit: Sun, 13 October 2019, 18:42:51 by ilouis_07 »
Offline pcire
Re: [IC] KN2.10²
« Reply #2 on: Sun, 13 October 2019, 08:35:56 »
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: [IC] KN2.10², 60% keyboard kit in WK, WKL and HHKB.
« Reply #3 on: Sun, 13 October 2019, 09:05:15 »
What a striking design! I really love the yellow/black/white case (I'm a Yinzer what do you expect? :)))! I think it would go perfect with JTK Yolch or GMK Serika. Gonna have to keep an eye on this one for sure. While I have gotten away from using 60% boards lately, I always wanted a high end custom 60% as those are the boards that really drew me into this rabbit hole. I've seen a few designs lately that really caught my eye, but this one might be enough to get me to reach for my wallet!
Offline CodeMayhem
« Reply #4 on: Sun, 13 October 2019, 09:47:12 »
how long will the gb last? bc i just joined key65 and have to wait til the end of oct. to join dracula so i'm gonna need til about the 9th to have the money...and i think other ppl are in a similar spot. September and October have been rough on our wallets.
Offline TheArcticFox_27
« Reply #5 on: Sun, 13 October 2019, 12:52:48 »
I've seen thesis post a picture of a half plate, will that be an option?
Offline jaang
« Reply #6 on: Sun, 13 October 2019, 17:30:02 »
love this!
Offline nasp
« Reply #7 on: Sun, 13 October 2019, 17:33:37 »
Does this take a universal 60% PCB or will it be a custom for the case itself?
Offline Sissy
« Reply #8 on: Sun, 13 October 2019, 18:34:35 »
Would love a green and Purple version but regardless super clean and interested.
Offline ilouis_07
    • ILUMKB
« Reply #9 on: Sun, 13 October 2019, 21:01:31 »
Yeah, I'd like to bring the half plate in.
Offline ilouis_07
    • ILUMKB
« Reply #10 on: Mon, 14 October 2019, 03:29:01 »
Yes, universal 60% PCB will fit it. But since it is a fixed-layout keyboard, so we prepared PCB with fixed switch footprints. We think it looks simpler and nicer.
Offline lanyusea
« Reply #11 on: Mon, 14 October 2019, 03:34:43 »
will the manufactory be Percent Studio as luo mentioned before?
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline ilouis_07
    • ILUMKB
« Reply #12 on: Mon, 14 October 2019, 06:54:16 »
Nope, this project will handle by me and the manufactory behind is faster and better.
Offline caronte0
« Reply #13 on: Mon, 14 October 2019, 07:19:50 »
The design looks stunning, i really like it. Would love to see it in regular 60 or 65%. Also would be great if you could add to increase the height (for my personal taste 5º is a little bit low)
Offline Mcnos
    • GMK Fuyu
« Reply #14 on: Mon, 14 October 2019, 08:20:41 »
What plate options will be available?
Would love a Polycarb or Half Plate option
Offline VXQN
« Reply #15 on: Tue, 15 October 2019, 06:27:11 »
I would say leave the height as-is, so many boards are 7, 8, 9 degrees, and having it a little lower helps to differentiate. The user can always prop the board up a little more if they want to, but you can't "prop it down".
Offline ilouis_07
    • ILUMKB
« Reply #16 on: Tue, 15 October 2019, 09:29:52 »
PC plate nope, we are thinking about half plate with the universal layout as add on.
Offline tonny950111
  • valar morghulis valar dohaeris
« Reply #17 on: Wed, 16 October 2019, 09:32:34 »
What is the vender in US (Please not Kono Store)
Offline LuiKang
« Reply #18 on: Wed, 16 October 2019, 09:49:14 »
Would love to see RGB glow, either side or underglow. PC bottom would also be sufficient.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #19 on: Wed, 16 October 2019, 10:29:41 »
It would have been awesome if there were a way to finish the backweight so it would match the accent color (plate)... My only true issue with the case is the the bottom front being raised in relation to the back — I never understood that design choice ever since seing the private GB units. Other than than that I love the design.
Offline victorpre
« Reply #20 on: Sun, 20 October 2019, 17:19:57 »
Hello, is there any chance of adding split spacebar support?
Looking forward to this board
« Reply #21 on: Sun, 20 October 2019, 17:23:16 »
aw I wish the color combo I wanted was available
« Reply #22 on: Sun, 20 October 2019, 18:17:21 »
catchy name
Offline Mcnos
    • GMK Fuyu
« Reply #23 on: Sun, 20 October 2019, 18:52:09 »
Specs:
Colors:
Supported Layout:
Timeline:
GB: end of Oct.
iLouis_07: https://www.instagram.com/ilouis_07/
You got me at 5 degrees
Offline Abec13
« Reply #24 on: Mon, 21 October 2019, 08:11:52 »
That yellow/black/white HHKB is mine! Let's do this.
45-ATS | Adelie | Gentoo | Volcano 660 | Think 6.5 v2 | SKOG | 7V | Hello M0110
[/url]
Offline stoopidsloth
« Reply #25 on: Mon, 21 October 2019, 12:49:30 »
what color combo do you like?
Offline appaboy
« Reply #26 on: Mon, 21 October 2019, 12:51:07 »
interesting
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
« Reply #27 on: Mon, 21 October 2019, 14:04:42 »
dark grey dark red dark grey
Offline Nigolski
« Reply #28 on: Mon, 21 October 2019, 14:29:36 »
this is nice
Offline Draxion
« Reply #29 on: Mon, 21 October 2019, 15:23:42 »
Will we be able to swap plate and case color. So if I wanted to do black case + red plate would that be an option or only the 3 presets given
Offline ilouis_07
    • ILUMKB
« Reply #30 on: Wed, 23 October 2019, 00:10:20 »
Prototype arrived.
Offline hahihuhei
« Reply #31 on: Wed, 23 October 2019, 00:16:16 »
When the prototypes look more rendered then renders  ;D
Beautiful~
Good job.
Offline ilouis_07
    • ILUMKB
« Reply #32 on: Wed, 23 October 2019, 01:02:31 »
Beautiful~
Good job.
Offline Sissy
Re: [IC] KN2.10² (Prototype photos added)
« Reply #33 on: Wed, 23 October 2019, 03:51:29 »
How heavy is the prototype?
Offline Moridin
    • Infinite Diaries
« Reply #34 on: Wed, 23 October 2019, 04:46:07 »
So I guess I need to buy 2 now. One for GMK Phosphorous and one for GMK Lunar. 😉
Love the design, just hoping the price will be in my budget.
Offline ilouis_07
    • ILUMKB
« Reply #35 on: Wed, 23 October 2019, 11:17:03 »
About 1400 grams, assembled and gmk Keycap mounted.
Offline ilouis_07
    • ILUMKB
« Reply #36 on: Wed, 23 October 2019, 20:03:45 »
New Typing Sound Video updated.
Thanks
Offline nasp
« Reply #37 on: Mon, 28 October 2019, 12:28:35 »
GB is live BTW on iLuMKB.com
Your welcome iLouis  :thumb:
« Reply #38 on: Mon, 28 October 2019, 12:50:08 »
Ohhh there ended up being black + red + black! !
but what does eblack look like
edit: pics are up now
« Last Edit: Mon, 28 October 2019, 13:33:25 by Sifo »
Offline Mcnos
    • GMK Fuyu
« Reply #39 on: Mon, 28 October 2019, 13:16:33 »
I'll be joining since I now have extra funds.
Offline ilouis_07
    • ILUMKB
« Reply #40 on: Mon, 28 October 2019, 14:22:01 »
GB post submitted, more details in the GB post.
Hope you love this project.
