Author Topic: E8.5 - 80% custom keyboard.(Groupbuy open)  (Read 181453 times)
Offline excluisve
  • Making & Thinking.
« on: Sun, 13 October 2019, 09:59:29 »
Group buy
https://geekhack.org/index.php?topic=103520.msg2836592#top
Hello everyone Excluisve here
In the past three years, I have had a lot of sadness and tears. I am very glad that have been here for three years. also very grateful to my friends who have supported me for three years and hope that my keyboard can get your love. This time brings a new TKL design it is a completely different design. The key color may a little different
Make sure to fill this form if you are interested
  https://docs.google.com/forms/d/e/1FAIpQLSeqotHS9bl-miuGGcGjW9q_LLOMJxWq5iDRtkZsTwqapAmq3g/viewform?usp=pp_url&entry.1934590305=Reddit
Some new features:
                                       *7 slop/6063Alu/QMK Type-c /WK &WKL
                                       *Inner middle and top case seprate design  we will see structure below
                                       *change usb port to right side not middle as previous
                                       *add titanium plate and open new E color like :yellow /pink https://i.imgur.com/9Hj3Dhx.jpg
Improvements:
                                       *E coating :As we know since sandblasted brass stuff easy leave stains and Finger print so we have do the e coating on brass
                                        it will keep brass color and surface clean when you touch it
                                       *E-black   : In E6.5 GB  e black turn out not so good on some case  so i have change another e black this time
                                       *Poly case : when screw up case repeatedly the screw hole easy be slackly so we find a way to avoid this problem (TBD)
Structure:
                                       *We have separate the bottom step as a inner middle for gasket mount so that you could choose the material
                                         of middle (Brass/pc/alu).
                                       *but this time step not include in default kits .that is mean if you want get gasket you can grab the
                                         middle, on the contrary is none.
                                       *Top case color matching design you could think is a different tag.
                                       *About gakset we will find more soft oring and fix issue on screw stabs
Layout:
About colors :
                                                         E coating :Yellow/Black/White/Pink
                                                          Anoding  : Green/Grey/Purple https://imgur.com/a/bqUVdNA
Estimated price :                    $365
Third Anniversary Version FE    10 kit Raffle ($888)
Prototypes were manufacturing.
Each boards cant be 100% but i will try my ability do it perfectly .
if you cant accept a little Inevitable ,especially PVD stuff (Quality is hard to control )please thinks twice before purchanse
For some orders i will consider to sale .thanks evryone : )
Free to leave suggestion and question.---
Thanks all!
Fellow me on Ins  https://www.instagram.com/exclusive1993/
Updated on 17 th :
finished the black whit pink combo .
Updated on 2th Nov
1.split backspace
2.hot swap pcb and standard pcb two options
« Last Edit: Fri, 22 November 2019, 11:21:57 by excluisve »
Offline excluisve
Re: E8.5 - 80% custom keyboard.
« Reply #1 on: Sun, 13 October 2019, 10:00:08 »
Reserved
Offline dimo
« Reply #2 on: Sun, 13 October 2019, 10:04:35 »
yes
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #3 on: Sun, 13 October 2019, 10:07:47 »
Been eyeing on this ever since teasers
Can't wait for GB! :))
Offline lolafineday
« Reply #4 on: Sun, 13 October 2019, 10:08:18 »
Alu gasket? I didnt understand the gasket mounting
Sent from my SM-G975F using Tapatalk
Offline ptiede
« Reply #5 on: Sun, 13 October 2019, 10:19:27 »
This looks incredible! So excited to get one!
Offline Capsy
« Reply #6 on: Sun, 13 October 2019, 10:24:21 »
I'll be in if the backspace could be split. Form filled out.
Offline Smoff
  • 817 785
    • Youtube
« Reply #7 on: Sun, 13 October 2019, 10:31:00 »
owo
Current boards: Matrix 1.2 OG | Matrix 8xv2.0 | Cherry g80-1000 | Cherry g80-3000 | Matrix 2.0add | Matrix Noah
Boards on the way: Duck Orion v2.5 | Matrix Falcon
Previous boards: BOK.CP | Duck Orion v3 | Mech27v2 | HHKB pro2 x3 | Cherry g80-11800 | NIU mini | Klippe r1 | Brutal60 | Duck Unicorn x Legend | Duck jetfire | Cherry g80-1800 | IDB60 | PC Salamander | Lin Whale r2 | LZ Physix | Duck Viper v3 |
Offline mrkantz
« Reply #8 on: Sun, 13 October 2019, 10:35:33 »
Can't wait!
Offline barcodee
« Reply #9 on: Sun, 13 October 2019, 10:39:02 »
This looks awesome. Hell yes.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #10 on: Sun, 13 October 2019, 10:45:58 »
I'll second this^ Split BS is basically a necessity for me.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #11 on: Sun, 13 October 2019, 10:47:20 »
Oh if there is purple I’m very interested
Offline Sic_Alpha
« Reply #12 on: Sun, 13 October 2019, 10:48:18 »
No split backspace? :(
Offline gasp
  • Formerly 'boop' (NTBCW Booper)
    • none
« Reply #13 on: Sun, 13 October 2019, 10:48:58 »
This may seem silly, but are there any plans to change the color of the o-ring or pcb? One of the only things that bothered me (and many others I talked to) with the polycarb e6.5 was how visable that peachy-red gasket was on every board I built. That plus the mustard yellow pcb was not very good looking, especially when compared to a pretty pcb like the PC singas.
Offline Helpingly
  • Hiya! I'm Helpingly
« Reply #14 on: Sun, 13 October 2019, 10:51:00 »
Looks very pretty. Might be my first custom TKL purchase.
Offline andrewregal
« Reply #15 on: Sun, 13 October 2019, 10:54:43 »
I love my E7 and E6.5 so there's no way I'm missing this!  ;D
Discord: andrewregal#7830
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #16 on: Sun, 13 October 2019, 11:00:12 »
+1
If it's possible for this to be implemented, I would also love to see a split BS.
GON NerD TKL DTA Edition
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #17 on: Sun, 13 October 2019, 11:05:36 »
Yo that yellow is lit
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline Abstand
« Reply #18 on: Sun, 13 October 2019, 11:12:34 »
I love this design, tons of options and overall looks really nice. I am in for sure.
Offline Steezus
  • Keeper of Facts
« Reply #19 on: Sun, 13 October 2019, 11:13:39 »
Fingers crossed the light blue is chosen for one of the anodization options. I'm a big fan of the design. :thumb:
Offline flippanteer
« Reply #20 on: Sun, 13 October 2019, 11:17:16 »
That accent corner is amazing
Current boards: FLX Virgo w/ NK Drys, E8.5 w/ NK Drys, LZ Physix w/ H1s,  Moon TKL w/ MX Zilents, HAD66 [Alice layout] w/ NK Creams, KBD75v1 w/ Zealios 67g v1
Purchased boards: Infinitum
Past boards: Trinity w/ Tealios v2, Lubrigante w/ Holy YOK Trash Pandas, Kumo w/ Novelkeys Cream, Diverge 2 w/ MX Browns, Planck w/ MOD-H, Anne Pro w/ MX Blue
Offline vicissitude
« Reply #21 on: Sun, 13 October 2019, 11:19:13 »
+1
Love keebs made by Exclusive so much.   :thumb: :thumb:
Offline Diedier Remedy
« Reply #22 on: Sun, 13 October 2019, 11:21:15 »
I'm in for the Group Buy regardless of the price. This is the type of  board you'd sell your soul for.
Offline Tommicorn
« Reply #23 on: Sun, 13 October 2019, 11:24:04 »
Omega nut. Please consider light blue!
Offline Surefoot
« Reply #24 on: Sun, 13 October 2019, 11:26:13 »
In for a dark blue or a green.
Offline vaughno
« Reply #25 on: Sun, 13 October 2019, 11:53:01 »
e-black and nameplate I am not a fan
Unikorn | Orion v3 | GSKT-00
Offline catamscott
« Reply #26 on: Sun, 13 October 2019, 12:10:14 »
that pc/pink render looks stellar  :cool: super interested in this!
Offline happycamper87
« Reply #27 on: Sun, 13 October 2019, 12:41:47 »
Filled out the form but forgot to mention that split backspace is a must. Hope you can include split bs.
« Reply #28 on: Sun, 13 October 2019, 12:56:53 »
Very interested depending on price and filled out the GD form. Hoping TKL plus gasket is the next big thing!
Offline IOVERCALLHISTIOCYTES
« Reply #29 on: Sun, 13 October 2019, 13:10:07 »
Is there an example of the green somewhere?
EDIT: wait, that's green? NEVERMIND I was looking at the bar
dammit i didn't pick green in my form
« Last Edit: Sun, 13 October 2019, 14:26:48 by IOVERCALLHISTIOCYTES »
Offline AlcoholEnthusiast
« Reply #30 on: Sun, 13 October 2019, 13:10:23 »
Not really a TKL guy, so I probably won't get this. That being said it looks awesome, and the design is fantastic. This should surely do very well.
Offline ComebaX
« Reply #31 on: Sun, 13 October 2019, 13:43:02 »
Yeah... you're probably drunk right now.
Offline pixelpusher
« Reply #32 on: Sun, 13 October 2019, 13:44:36 »
Did you see the second photo?:
228084-0
Offline pixelpusher
« Reply #33 on: Sun, 13 October 2019, 13:46:48 »
That e-white with black looks amazing. Not sure why it's hidden under a "More" tag
Did you say anywhere how tall the board is at the front edge?
Offline Rob27shred
« Reply #34 on: Sun, 13 October 2019, 13:59:07 »
I think because E is still working out a better option for e-black. He's said a few times he was not happy with how the e-black parts for the E6.5 turned out & is looking for an alternative option for e-black.
Edit: Duh, it's a render... LOL! I thought it might have been a pic of a prototype with the old e-black on the plate & accent piece.
« Last Edit: Sun, 13 October 2019, 20:37:53 by Rob27shred »
Offline belgium_waffles
« Reply #35 on: Sun, 13 October 2019, 14:07:00 »
Offline ramnes
  • T fou, mec?
« Reply #36 on: Sun, 13 October 2019, 14:30:38 »
filled the form
Offline ilemondrop
« Reply #37 on: Sun, 13 October 2019, 15:18:58 »
So down for this, can't wait for an e-white TKL, rose gold brass plate would be pretty sick too. Definite buy.
Offline liangalv
« Reply #38 on: Sun, 13 October 2019, 15:22:09 »
gorgeous can't wait to get my grubby hands on this
Offline PotatoTM
« Reply #39 on: Sun, 13 October 2019, 15:23:40 »
Looks pretty sweet, following to see how it turns out by GB time
Offline spyruf
« Reply #40 on: Sun, 13 October 2019, 15:57:53 »
I will be joining for the white and blue combo.
Is the 3 dashes near the nav cluster just an accent or can there be LEDs?
Offline pixelpusher
« Reply #41 on: Sun, 13 October 2019, 16:42:50 »
My dream board would be a matte gray option, similar to mao with the accent corner just a few shades darker.  I'd even settle for white with a medium gray accent corner.
Offline reidd
« Reply #42 on: Sun, 13 October 2019, 17:37:25 »
Hoping dark gray ano comes to GB
Offline SolidCactus
« Reply #43 on: Sun, 13 October 2019, 17:40:44 »
I have an E6.5 and E7 so I'm all over this!
Offline metalliccharles
« Reply #44 on: Sun, 13 October 2019, 17:44:17 »
Cerakote
« Reply #45 on: Sun, 13 October 2019, 17:44:32 »
this with GMK ashes would look sweet
Offline gotham
« Reply #46 on: Sun, 13 October 2019, 18:59:14 »
One of the most beautiful TKLs I've ever seen! As expected from exclusive :thumb:
Offline theedappergamer
« Reply #47 on: Sun, 13 October 2019, 19:59:00 »
Oh how I hope that pc/pink board becomes a reality! that is simply stunning!
Offline cicatriz
« Reply #48 on: Sun, 13 October 2019, 20:07:05 »
Will it be possible to have 2 separate materials for the case i.e alu top and pc bottom?
Offline kronograf
« Reply #49 on: Sun, 13 October 2019, 20:36:10 »
Definitely in for this after the e7 and e6.5! Glad that you’re looking at the small details like PC screw holes and gasket screw stab compatibility. And the brass coating!!!
« Last Edit: Sun, 13 October 2019, 20:40:49 by kronograf »
jane me | 910 me
