Author Topic: [IC] Strawberry Lemonade PBT | NOVELTIES ADDED & MODS REVERSED!  (Read 12461 times)
Offline Dazon
« on: Wed, 16 October 2019, 21:05:59 »
228275-0
Hey,
This is Strawberry Lemonade, a set based off one of my favorite drinks.
As the name suggests, I am considering running this set in Dye Sub PBT, but am open to suggestions on what process i should do.
Strawberry lemonade uses three colors.
Pantone 2346 C for the legends on mods and alphas, and for some of the cap colors, to represent the pinkish-red color of strawberry lemonade
Pantone 122 C for the mod cap color and legends on some caps, to represent the color of lemons
GMK WS1 for the alpha cap, to represent sugar
228277-1
Current Kits:
228335-2
228341-3
228337-4
228339-5
Deskmats and renders are currently in the works.
Join the IC form here!
https://forms.gle/Be1sFccDmuQnNqRg9
TODO:
  • Make Novelties
  • Make Deskmats
  • everything else
History:
Oct 17: Initial Post
Oct 18: Novelties added, Mod colors reversed
« Last Edit: Thu, 17 October 2019, 22:41:45 by Dazon »
Offline Boy_314
Re: [IC] Strawberry Lemonade PBT
« Reply #1 on: Wed, 16 October 2019, 21:17:09 »
« Last Edit: Mon, 04 August 2025, 02:24:29 by Boy_314 »
Offline Dazon
« Reply #2 on: Wed, 16 October 2019, 21:18:17 »
Hey, its me again, the one who starts IC's and completely abandons them after a month.
who?
i should probably remove that,  i posted two ics a while ago that never went anywhere.
Offline Mcnos
    • GMK Fuyu
« Reply #3 on: Wed, 16 October 2019, 21:32:52 »
Offline Dazon
« Reply #4 on: Wed, 16 October 2019, 23:04:44 »
I'm confused
Sent from my SM-G973U using Tapatalk
Offline Kistler125
« Reply #5 on: Wed, 16 October 2019, 23:20:43 »
Love the colors! Reminds me of that chain "Hot dog on a stick" that was rampant throughout malls in the 90's. I really dig the coral/pink and I think the set could use more of it, after all if it was to be put on a 60% then you'd only have 3 keys in that color even if you opt for the space bar kit. How does it look if you were to swap the yellow with the pink? And how bout some novelties?
Offline Dazon
« Reply #6 on: Wed, 16 October 2019, 23:22:03 »
my fear with swapping yellow and pink is it looking too much like noel. I'll try it though, thanks! for novelties, they are in the works, but should be up soon!
Offline Kistler125
« Reply #7 on: Thu, 17 October 2019, 00:01:48 »
Awesome! Great job with the set so far, looking forward to the novelties!
« Reply #8 on: Thu, 17 October 2019, 08:42:03 »
Lemonade?
I now have a craving for an orange/strawberry popsicle ... :)
Offline Dazon
« Reply #9 on: Thu, 17 October 2019, 08:55:40 »
Lemonade?
thanks!
