Author Topic: How can I convert a terminal Model M?  (Read 5723 times)
Offline kelvinhall05
    • LinusTechTips
« on: Sun, 20 October 2019, 10:45:06 »
I bought two Model Ms online for really cheap ($30 for the pair) and they appear to be terminal boards ("new line" instead of "enter" as well as other interesting keycaps, which I love lol, and a terminal jack/cable). I was wondering what the cheapest/easiest way would be to convert it to USB or PS/2. I don't have a preference for either as my desktop supports both and that's the only place I see myself using a Model M. I'm in Canada so I'd prefer to be able to buy stuff from ebay.ca or amazon.ca, though if I really have to I can order stuff to a P/O box in the US. How should I go about doing this? I'm comfortable with soldering and whatnot, but I don't have a heat gun or anything, just an iron. Thanks!
tl;dr: What's the cheapest way I can convert a terminal Model M to USB or PS/2? I'm in Canada.
Offline Tactile
Re: How can I convert a terminal Model M?
« Reply #1 on: Sun, 20 October 2019, 11:03:59 »
Was a cable included? I've had a 102 key model M with key labels for terminals, similar to yours, and it turned out mine was just a PS/2 keyboard. Try that first. You may not need to convert at all.
REΛLFORCE
« Reply #2 on: Sun, 20 October 2019, 16:17:12 »
Orihalcon makes very clean and elegant converters but they are pricey (probably $40 approx Canadian) contact him here for an off-ebay price.
You can make one for a less using a Teensy breakout or less than that using a lower board, Pro-Micros seem to be popular.
Look at the thread here in "Making Stuff Together"
https://geekhack.org/index.php?topic=17458.0
- D Trump 2026-09-28
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #3 on: Tue, 22 October 2019, 07:52:36 »
You can also swap controllers and put a standard SDL cable instead. As a matter of fact, I am using that keyboard right now.
That thread is around here somewhere.
    • LinusTechTips
« Reply #4 on: Fri, 08 November 2019, 16:14:19 »
Hey all, sorry for the late reply.
1. The cable is hard-wired into the board and has an RJ45 connector on the end.
2. I'm not dropping $40 on a converter
3. I'm not buying a new controller and swapping it in...at that point I would have a super cheap model m and I could have just bought a "regular" one.
Would something like this work?
https://www.amazon.ca/ATmega32U4-Development-Microcontroller-Leonardo-Bootloader/dp/B07WPCLF8Y/ref=sr_1_4?keywords=ATmega32U4&qid=1573150246&sr=8-4
https://deskthority.net/viewtopic.php?t=8448
Offline OldIsNew
« Reply #5 on: Fri, 08 November 2019, 21:30:38 »
I use a Monoprice  Cat5e Surface Mount Box ( https://www.amazon.com/gp/product/B005E2Y9RY/ ) with a Teensy and Soarer's for my IBM RJ45 terminal boards (removed the white connectors that come with the box and soldered directly to the PCB).   It works well and was simple. I did have to widen the opening in the back of the case to fit the USB plug.
229733-0          229735-1
« Last Edit: Fri, 08 November 2019, 21:37:31 by OldIsNew »
Offline OldIsNew
« Reply #6 on: Sat, 09 November 2019, 23:38:23 »
Oh, BTW, these were some diagrams I found helpful:
229806-0
229807-1
    • LinusTechTips
« Reply #7 on: Sun, 10 November 2019, 12:25:03 »
I have all my wiring figured out except for the "PE" pin. Should that just go to ground? Inside the keyboard it's just screwed to the metal backplate.
Offline Snowdog993
« Reply #8 on: Mon, 11 November 2019, 12:14:31 »
This is the best method by far. Seriously.
Offline OldIsNew
« Reply #9 on: Mon, 11 November 2019, 14:19:14 »
If you're using the Teensy/Soarer's method, you can ignore the PE pin and just wire Vcc, GND, Clock and Data.
The controller swap is definitely a good method too. I like the Cat5e box because I have several RJ45 terminal M's (both 101/102 and 122) and can use them all with just the one box/Teensy  by flashing the appropriate Soarer's config file.
« Last Edit: Mon, 11 November 2019, 14:24:18 by OldIsNew »
    • LinusTechTips
« Reply #10 on: Mon, 11 November 2019, 20:04:57 »
Eh, I ended up just putting PE on the second ground. It makes me feel better ;)
