Author Topic: -  (Read 13690 times)
Offline Noveltty
« on: Wed, 23 October 2019, 10:33:38 »
« Last Edit: Thu, 16 July 2020, 10:56:02 by Noveltty »
Offline Sup
Re: Retooled Gateron Issue
« Reply #1 on: Thu, 24 October 2019, 15:06:54 »
I know the old milky yellow had these problems could be that you got a old batch of milky yellows.
current
Coming soon
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Thu, 24 October 2019, 15:43:15 »
It's the stem of the keycap catching it's edge on the northside of the housing. Not sure what could be done to fix it either than using caps that have a thinner stem?
Offline Cara1way
« Reply #3 on: Mon, 23 December 2019, 06:10:26 »
Gateron will be retooling the ink switches to help out with the loose leaves. This is not a recall, and they are not replacing switches LiteBlue Login.
Offline Steezus
  • Keeper of Facts
« Reply #4 on: Mon, 23 December 2019, 07:43:19 »
They have already retooled the inks and supposedly fixed the loose leaf issue. That is not the same issue as what Noveltty is experiencing.
Offline Rob27shred
« Reply #5 on: Mon, 23 December 2019, 07:44:06 »
Are you sure they have really decided to retool to fix the loose leaf issues? I have heard a ton of conflicting info on that & was under the impression that they were not gonna do anything about it. Hopefully they do fix it cause it really is a problem, even for those who do not mod their switches.
Offline Rob27shred
« Reply #6 on: Mon, 23 December 2019, 07:45:19 »
Good news here, I guess disregard my previous post!
Offline Steezus
  • Keeper of Facts
« Reply #7 on: Mon, 23 December 2019, 08:13:16 »
1upkeyboards made a post on r/mm saying they have the retooled inks where the issue was resolved and confirmed by Gateron:
https://www.1upkeyboards.com/shop/switches/set-packs/gateron-ink-switches/
However, on that reddit post, a moderator just recently posted saying that he confirmed that the issue was not fixed. So now I honestly don't really know.
Offline Rob27shred
« Reply #8 on: Mon, 23 December 2019, 08:35:04 »
Ah, thanks for clarifying. Yeah it's kinda nebulous as to what Gateron is gonna do about it. First I heard they were gonna fix it, then I heard they were claiming that it was not an issue & they were not gonna retool, since then it's just been in the spin cycle of the rumor mill so I don't know what to think either. I did some searching, but couldn't find anything else that could confirm a fix or not beyond what you linked also. Personally gonna keep steering clear of Inks till we get some reviews of this new batch.
