Author Topic: [Question] What's the best wireless ergonomic keyboard?  (Read 9779 times)
Offline tuananh_bkk
« on: Mon, 28 October 2019, 02:08:37 »
I know of the microsoft sculpt one only; preferably without any wire, 1 piece, like the sculpt. Is there any other board available ?
« Last Edit: Mon, 28 October 2019, 03:19:53 by tuananh_bkk »
Offline ergonaut
Re: [Question] What's the best wireless ergonomic keyboard?
« Reply #1 on: Mon, 28 October 2019, 02:30:07 »
I know of the microsoft sculpt one only; preferably without any wire, like the sculpt. Is there any other board available ?
I think Falbatech sells a wireless version of the Redox. That would be my pick for best wireless ergo.
EDIT: Here's a link:
https://falba.tech/19644-2/
Their website is a bit annoying, as the only way to gather information about their boards seems to be to pretend that you want to buy one :)
« Last Edit: Mon, 28 October 2019, 02:32:02 by ergonaut »
« Reply #2 on: Mon, 28 October 2019, 09:58:28 »
There is also the Goldtouch Go!2. There are a couple wireless versions, with bluetooth or dongle.
The Goldtouches are not strictly one-piece, but the hinge can be locked rigid.
BTW, there are wireless microcontroller board designs on Github, which are pin-compatible with the Pro Micro, and which could therefore (with some effort) be used in many DIY keyboards ... But I don't know if you could buy them anywhere. I suppose there have been limited runs of them on local boards here and there.
« Last Edit: Mon, 28 October 2019, 10:03:17 by Findecanor »
