Author Topic: KN2.10², Designing to be Simple.(GB ended, TYVM)  (Read 34907 times)
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
« on: Mon, 28 October 2019, 14:19:06 »
Hey, all the friends on Geekhack.
Let me introduce KN2.10² to you, Designed by THESISCAMPER.
Specs for Kit:
Make with 6063 aluminum for the case and brass for the weight.
4mm alum plate in default kit
Sandwich Mounting Designed.
The typing angle is 5 degrees.
Fixed layout PCB with type C connector(QMK).
Top case has 3 options: (Yellow color just for example)
WK
WKL
and HHKB
Extra add on:
Extra Fixed layout PCB
Extra 4mm Fixed layout Plate
Extra 1.5mm Universal Plate
Extra 1.5mm Universal Half Plate
Something More about the Plate, this is not a normal plate but well designed and milled "Accent Plate":
Default Kit comes with this 4mm plate, with the thinner edge(accent) designed.
Also for the 1.5mm plate, there are A LOT of CNC works behind the scenes, with the front view:
and the bottom view:
Exploded View:
Colors Option:
1) E yellow + Black + E white
2) Dark Grey + Cyan + Dark Grey
3) Silver + Dark Red + Silver
4) E Black + Dark Red + E Black
Group Buy Timeline:
Oct 28th to Nov 2nd.
EST Shipping:
within 60 days.
The shipping invoice will send out before the item is ready for the shipment.
Shipping Courier:
FedEx 2-3 days global-shipped, shipped from China. (With 60% discount, It is a collaborating discount price offered by our factory.)
Last but not least, Prototype and Typing Sound Video:
Linear Build, 205g0 lubed tangerines.
Tactile Build, MD stock Holy Panda.
You can Join the GroupBuy through:
https://ilumkb.com/collections/kb-kn2-10
Please note that all the prices listed are SGD. (1SGD = 0.73USD)
Thank you for your time and hope you love our project.
Our Discord Server:
https://discord.gg/SyzhtQf
My Instagram for more updates about this project:
https://www.instagram.com/ilumkb_com/
« Last Edit: Sat, 02 November 2019, 11:26:06 by ilouis_07 »
Offline ilouis_07
    • ILUMKB
Re: KN2.10², by THESISCAMPER x ILUMKB.
« Reply #1 on: Mon, 28 October 2019, 14:20:03 »
29th of Oct, Exploded View Pic added.
31st of Oct, More Renders added:
« Last Edit: Thu, 31 October 2019, 04:30:30 by ilouis_07 »
Offline infiniti
  • I <3 KB
  • Bob was here
Re: KN2.10², Designing to be Simple.
« Reply #2 on: Mon, 28 October 2019, 18:31:53 »
Also, as a reminder to all, CAVEAT EMPTOR :triangle:
GLWGB! :thumb:
« Reply #3 on: Mon, 28 October 2019, 18:45:58 »
Ooo I was wondering why an extra plate cost that much, makes sense now. Is the pcb proprietary too? Who made it?
Offline Mcnos
    • GMK Fuyu
« Reply #4 on: Mon, 28 October 2019, 18:47:19 »
Will we be able to replace the default plate that comes with the kit?
Offline ilouis_07
    • ILUMKB
« Reply #5 on: Mon, 28 October 2019, 19:27:40 »
Yeah, the plate has a lot of cnc works behind. For the PCB, DZ designed it, it is actually a simple version based on DZ60 PCB.
Offline ilouis_07
    • ILUMKB
« Reply #6 on: Mon, 28 October 2019, 19:29:33 »
Hey, sorry nope. The default plate is 4mm fixed-layout.
Offline suparnemo
« Reply #7 on: Mon, 28 October 2019, 21:09:24 »
Will a DZ60RGB hotswap PCB fit? I want to use a hotswap PCB for convenience.
Offline ilouis_07
    • ILUMKB
« Reply #8 on: Mon, 28 October 2019, 22:48:20 »
It should fit but not guaranteed since we have prepared PCB for the kit. The clearance we gave for KN is 2.3mm, hotswap pcb socket thickness is 2mm.
« Last Edit: Mon, 28 October 2019, 22:52:59 by ilouis_07 »
Offline kaisn
« Reply #9 on: Tue, 29 October 2019, 07:34:41 »
Ordered mine :)
Offline thesiscamper
    • Keyrenders
« Reply #10 on: Wed, 30 October 2019, 18:25:19 »
GMK Led Zep on black+red KN2.
229120-0
229122-1
229124-2
"haters are confused admirers"
Offline ilouis_07
    • ILUMKB
Re: KN2.10², Designing to be Simple.(More renders added/31st)
« Reply #11 on: Thu, 31 October 2019, 04:31:51 »
More renders added. (GMK Led Zep and Solarized Dark)
Offline undeadtac
« Reply #12 on: Thu, 31 October 2019, 06:08:15 »
Will there be a 65% version of this in the future?
Offline suparnemo
« Reply #13 on: Thu, 31 October 2019, 11:45:35 »
Does this mean the total PCB thickness including sockets must be 2.3mm? Or just the clearance under the PCB?
Offline ilouis_07
    • ILUMKB
« Reply #14 on: Fri, 01 November 2019, 10:26:30 »
It means all the component's thickness under the PCB must have to less than 2.3mm. From the datasheet, we can see the hot-swap socket thickness is 1.9mm, so it should fit but not guaranteed.
Offline ilouis_07
    • ILUMKB
« Reply #15 on: Fri, 01 November 2019, 10:33:50 »
1st of Nov Update: Tomorrow GroupBuy will end at 24:00 SGT.
The pie chart shows the percentage of Colors and Layout for entire orders.
Offline Chaselicious17
« Reply #16 on: Fri, 01 November 2019, 20:27:29 »
Just got in late. This board really caught my eye. Is the 2 month turnaround what you're shooting for? Seems too good to be true :D
TBH I'm kinda burnt on huge waits/delays (still waiting on Xeno -.-)
    • Keyrenders
« Reply #17 on: Fri, 01 November 2019, 20:55:04 »
It is indeed what we're shooting for, based on the factory's estimate. Thank you for the support!
    • Keyrenders
« Reply #18 on: Sat, 02 November 2019, 05:30:19 »
Silver body with Cyan plate with Hyperfuse and XA Solaized Dark. Only a few hours left before the buy closes :)
229290-0
229294-1
229292-2
229296-3
Offline ilouis_07
    • ILUMKB
« Reply #19 on: Sat, 02 November 2019, 06:32:00 »
Thank you for joining the group buy, we hope we can fulfill it in 2 months.
Offline ilouis_07
    • ILUMKB
Re: KN2.10², Designing to be Simple.(GB ended, TYVM)
« Reply #20 on: Sat, 02 November 2019, 11:27:22 »
KN2.10² GB ended, 101 boards sold. Thank you everyone for supporting us!
« Reply #21 on: Sat, 02 November 2019, 11:27:47 »
101 nice!
Went for the e-black.
Offline Bubblegum
« Reply #22 on: Sat, 02 November 2019, 11:57:47 »
Really wanted to get in on this, but unexpected economic troubles from nowhere. Maybe next HHKB board. Good luck with the GB. Looks great :)
Offline catamscott
« Reply #23 on: Sat, 02 November 2019, 13:24:13 »
didn't realize this went to gb already, anybody know what the prices were? the gb site doesn't show
« Reply #24 on: Sat, 02 November 2019, 13:57:49 »
about 314 usd
« Reply #25 on: Sat, 02 November 2019, 14:37:37 »
101 boards! Awesome! best of luck to the runner, maker, and everyone else directly involved.
Got in for that yellow and black. Really excited overall. Will updates be posted here in the forum?
    • Keyrenders
« Reply #26 on: Sat, 02 November 2019, 18:25:19 »
Thank you for joining! Updates will be posted here but you'll get more timely updates from Louis' discord server, TianYue_Lab.
Offline ilouis_07
    • ILUMKB
« Reply #27 on: Wed, 27 November 2019, 00:05:26 »
27th of Nov Updates:
Nov 29th Updates for KN:
I still want to improve the finishing for the ano kn2.10, actually I brought the prototypes to Oct Singapore meet-up and ppl all gave very good feedback. I realized that when you zoom in the prototype pics. You can see the sandblasted marks. It feels very smooth but looks rough. Me and thesiscamper worked on this from Oct till last week.
Before the improvement:
OId vs our New ano finishing:
Our Final Ano sample:
Silver is KN2.10, Dark Grey is my personal collection(one of the smoothest kb IMO)
Offline beekey
« Reply #28 on: Thu, 02 January 2020, 13:52:54 »
Any update? Still looking for the 60day after GB close date?
Offline 8six753o9
« Reply #29 on: Thu, 02 January 2020, 14:29:01 »
Not sure why iLouis didn't post this here yet, but they have begun collecting shipping information yesterday.  Quote from ilouis on Discord:
Hey KN fellows, happy new year and we are collecting the shipping info and send out the shipping invoice for KN2.10 soon.
Please fill in this form if you have joined KN2.10 GB,
https://forms.gle/9nxzKociCfdj1R6D8
Offline beekey
« Reply #30 on: Fri, 03 January 2020, 01:51:19 »
Thank you for forwarding this.  :thumb:
Offline kaisn
« Reply #31 on: Sat, 18 January 2020, 13:12:42 »
Arrived saturday and today I build my little beauty.
Very nice groupbuy Louis! Incredible speed and QC.
Awesome design @THESISCAMPER
I will join future GBs run by you without any worry in the world  :thumb:
« Last Edit: Sat, 18 January 2020, 13:14:53 by kaisn »
« Reply #32 on: Sat, 18 January 2020, 17:53:43 »
very nice board and one of the smoothest keyboard GBs i've ever been a part of.
Offline d00deitsnik
  • Grails: SA Olivia, 1800 w/ only Latriualum keycaps
« Reply #33 on: Sun, 19 January 2020, 12:12:22 »
My board arrived, but I didnt realize I was out of stabs. I'm so excited to build mine tho!
Offline GwenAlli
« Reply #34 on: Sun, 19 January 2020, 19:47:54 »
Received mine 2 days after it shipped, super quick! Haven't had a chance to do anything other than test the PCB and inspect the finish. This thing is definitely high quality!
Hopefully I'll have time to build it soon... I just have to decide on what switches I want to use lol.
Offline jshufelt
« Reply #35 on: Sun, 19 January 2020, 20:32:17 »
Easily one of the best GBs I've been in, for speed of execution, care in QC, and quality of result.  Thank you!
233929-0
Offline MK47
  • Don't talk to me
« Reply #36 on: Thu, 23 January 2020, 15:03:44 »
Will there be a R2 in the future?
Offline suparnemo
« Reply #37 on: Thu, 23 January 2020, 15:09:27 »
There should be extras at some point soon. I don't think there is any specific info on when though.
Offline mudcakehoney
« Reply #38 on: Mon, 15 February 2021, 07:00:22 »
Hey people, if anyone I’d looking to sell their KN2.10 please pm me, I’m interested in purchasing one. Thank you!
